Question about Philips DVD727 DVD Player
Sound but no picture
All of my connections are correct, from my DVD player to my television. When I try to play a DVD I get sound, but no picture. I also used new RCA (red, white, and yellow)cables and I still encountered the same problem.
  • Anonymous Jan 02, 2008
    I have the same problem and am also using red, white and yellow cables. I get sound but no picture. WHY? Please let me know.
  • 26 Answers
Try making sure that the video cord is plugged in to the video out port on the dvd player and that the other side of the video cord is plugged in to the video in port on the tv
Posted on May 02, 2009
SOURCE:
Im trying to connect my coby dvd player to my samsui tv
Hi Maria,
You can hear the sound means your TV and the DVD player are working well. May be the video connecting cord ( yellow connector) between the TV and DVD player has gone bad. Please try replacing it. For testing, you can interchange it with any of the two sound connecting cords which have white and red connectors. I hope it helps.
Jan 23, 2016 | Sansui 19 in. LCD TV
My techwood tv will not play sound and the colour is not right. how do I fix this?
see the charts troubleshooting and fix it. God bless you
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
  1. Disc is dirty or damaged. Clean the disc or try another disc.
  2. Reset the color system of the player or the TV set.
Try a direct connection from the DVD player to the TV set, instead of via other components.
Oct 14, 2013 | Gemini 1 Device Universal Television...
No picture, no sound
see the troubleshooting index:God bless you
No sound
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Sep 23, 2013 | LG 32cs460 32" Inch Widescreen 720p 60hz...
TV after removal of picturetube for playing music from DVDplayer
Why use the TV in hearing the sound from DVD
player. You can use some small speaker and connect it at the back of the DVD player.
Jan 07, 2010 | Televison & Video
Has sound but no picture
try a different rca cable, or even putting into a different input. Example, if you have dvd player hooked into input 2, and you have a input 3, try your connections there and see if you have the same problem. If so, use a different rca cable or whatever your cable maybe that you are using :-)
Apr 07, 2009 | Akai LCT3701AD 37 in. LCD Television
Only dvd plays properly but vhs will not show picture.
Most likely you have the dvd part connected through component or svideo cables. Despite the fact that this is one unit, like other vcr/dvd combo units it acts as two separate units in the same box. The vcr will probably not play through those cables. As you have audio coming through I'd imagine that the audio is connected using red and white composite cable. Connect the video on the vcr side with composite yellow cable or run direct to tv with a coaxial cable.
Feb 04, 2009 | Sansui VRDVD4005 DVD Player/VCR
Dvd plays can see picture but no sound
Check all your connections.
Also please let me know how you have it connected currently, what is the model of the dvd player and the television. Are you running through an AV receiver?
one ting to try is connecting ONLY the red and white audio connectors from teh dvdplayer to the correct input on the tv while it is on. if you hear a slight "pop" [not harmful] you have the right input and there might just be a problem with the dvd player itself.
be sure you have the right audio track selected or try playing a cd.
May 02, 2008 | Televison & Video
Phillips Projection TV
make sure you have the correct video input connected, play a movie in the dvd player do you get anything, can you use a different video input?
if all is correct go to the menu and see if the menu screen comes up.
Dec 02, 2007 | Philips Magnavox 51MP392H Rear Projection...
I can't hear any speech when I play a DVD, but I have all other sound.
Yes what you heard is correct,look for center speaker connection.If it is correct then connect it thru coaxel or digital out and see.
Feb 09, 2007 | Eltax DV-100 DVD Player
Philips DVD727 DVD Player Logo
130 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
