Question about Lexmark X3550 All-In-One Printer
Wireless card???? What wireless card do I need for this printer to make it WI-FI?
  • Anonymous Jan 06, 2009
    I have the same problem, as i just got the printer and am unable to print wifi and with a lead.
I think you can use this wireless card, not sure which printer models it works with though.
http://www.lexmarkonline.co.uk/product_info.php/tab/Customer_reviews/info/p449_Lexmark-N2050-802-11b-g-Wireless-Network-Card.html#tabs
Posted on Nov 25, 2008
DELL Latitude E6510, wifi button was OFF, now it is not working.Wifi is showing red cross. Please help how t0 turn it ON? I think it is Hardware issue. Can I fix it through Windows? Windows 7
Information Technologies
Share
Enable / Disable an Enterprise Laptop's Wi-Fi
Wi-Fi, short for Wireless Fidelity, is networking technology that allows you to connect to the Internet. If you have a wireless-enabled Latitude computer you can connect to the Internet when in range of an access point called a hotspot.
When not in use your Latitude's wireless card should be disabled. By disabling Wi-Fi, you will receive two benefits:
Start-up times will be much faster.
If the wireless card is ON and you are out of the office (not connected to your normal, wired connection), the laptop will try to use the Wi-Fi network during the login process to run the various start-up scripts, etc. It will eventually time-out (fail). By having the wireless card turned OFF, the start-up process will be much faster.
Computer will not continually search for a wireless network (and waste battery life).
If you are in the office (connected to your normal, wired connection) or in a location where there is no wireless hotspot, you don't need to have the computer waste processing power by looking and looking for a wireless hotspot. By disabling Wi-Fi, you will gain a little more power for your other tasks. In addition, you will maximize your battery operating time by disabling wireless activity.
NOTE: After your Latitude has started up completely, you can ENABLE the wireless card and connect to a wireless hotspot. For example, a wireless router at your home or at a local coffee shop. If you have connected to this hotspot previously, the wireless card should connect automatically for you.
NOTE: Once you have the wireless card enabled, before you shut down the computer, you should again DISABLE the card. The computer will then be ready for the next time you turn it on with wireless turned off.
Enable / Disable with Hardware Switch
The more recent Latitude models have a wireless switch to enable or disable wireless network devices and the
Wi-Fi Catcher Network Locator.
Dell Latitude E6420 and E6520 Series
These laptops have a small switch on the RIGHT side of the keyboard. The switch is toward the front of the laptop. The Wi-Fi Catcherâ„¢ icon will is above the keyboard. You will see a lit radio tower if the wireless switch is enable
Oct 17, 2016 | Dell Latitude E6510 Notebook
Computer can not find a wi-fi singnal of printers
You need to connect it to a router before connecting it to PC
Apr 12, 2013 | Brother Sealed Mfc-j430w Wireless Printer...
Can i make a hp officejet 6110 printer wireless
SETTING UP A WIRELESS PRINTER WITHOUT A WIRELESS ROUTER - WINDOWS 7
Install Virtual Router first "Turn any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot Spot."
EditByBSEditor: Virtual Router turns any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot SPOT using Windows 7's Wireless Hosted Network (Virtual Wifi) technology.
The Wireless Network Create/shared with Virtual Router uses WPA2 Encryption, and there is not way to turn off that encryption. This is actually a feature of the Wireless Hosted Network API's built into Windows 7 and 2008 R2 to ensure the best security possible.
You can give your "virtual" wireless network any name you want, and also set the password to anything. Just make sure the password is at least 8 characters. http://www.brothersoft.com/virtual-router-327895.html Then install Connectify-Me Connectify is an easy to use software router for Windows 7 computers. After downloading and installing the lightweight application, Connectify utilizes your computers' built in Wi-Fi card to wirelessly share any available Internet connection: a cable modem, a cellular card, or even another Wi-Fi network. Other Wi-Fi enabled devices including laptops, smart phones, music players, and gaming systems can see and join your Connectify hotspot just like any other Wi-Fi access point and are kept safe and secure by password-protected WPA2 Encryption. http://www.connectify.me/ Then reboot computer
Aug 18, 2012 | HP OfficeJet 6110 All-In-One InkJet...
How to set up wireless printer on windows 7 net book
I have just bought an epson sx435 wireless printer. I have set it up on my xp desktop with usb cable. How do I set it up to be wireless on xp
and how to I set it up on my Acer Aspire one 522 netbook running windows 7.
Home > Printer Wi-Fi Setup Setting up a Printer Wi-Fi Network Using the Control Panel Using the Wi-Fi Setup Wizard with LCD panel WPS setup You can set up a Wi-Fi network for your printer by using the printer's control panel. Using the Wi-Fi Setup Wizard with LCD panel If your printer has an LCD panel, you can use the Wi-Fi Setup Wizard to simplify manual setup. mark_no.gifNote: This setting is not available for all printers or may not be enabled. Make sure that the Wi-Fi is enabled on your computer in advance. Check the SSID and password for your network as these are required during Wi-Fi setup. If you do not know the SSID and password, check with your network administrator. For step by step information on setting up a Wi-Fi connection using the Wi-Fi Setup Wizard, click the following link. This feature is not available for all printers or may not be enabled.
exlink.gif../p_body/panel/wizard/manual_01.htm
Well to start with xp look at the following.
http://support.epson-europe.com/onlineguides/en/sx430sx435w_nwg/html/index.htm
May 30, 2012 | Computers & Internet
Printer is not responding to wifi network. everything has been checked but i may have missed something
To set up a wireless printer in your system, your computer needs Wi-Fi hardware and the Wi-Fi connectivity enabled. If you face any issues with the Wi-Fi hardware or your Wi-Fi driver, you will have issues in setting up your Wireless printer. You need to make sure of the compatibility of your driver with your Operating System. An incompatible or a corrupted driver will also create issues in running the set-up.
Jan 11, 2011 | Office Equipment & Supplies
What year was toshiba satellite 2410-S203 pc notebook first launched?was it equiped by WIFI?
My sources indicate 2003.
It has > Optional
http://www.csd.toshiba.com/content/pr/html/Satellite%201410%20and%202410%20Press%20Release%20%289-24-02%29.html
The Wireless Antenna On-Off switch is on the Right side. The Wireless Antenna LED is to the left of the On-Off switch. It glows when the wireless antenna is in use.
It has to have an > optional
Turn the laptop over, Front facing you.
The Battery Compartment is on the Front Right corner.
The Wi-Fi Compartment Cover is on the Back Left corner.
Remove the single screw in the right middle of the cover. (Philips head)
See if a Wi-Fi PCI Mini Card is installed.
No?
You'll have to obtain a Wi-Fi PCI Mini Card for your Toshiba.
From a quick search just now, (Not advertising for this website),
http://www.impactcomputers.com/p000339520.html
(Remember to remove ALL power to the laptop Before installing. AC adapter {Charger} and Battery.
Also remember to observe Anti-Static Precautions before handling the Wi-Fi card, and when installing)
Here is the Toshiba Satellite 2410-S203 Notebook PC User Manual, also,
http://www.fixya.com/support/p265858-toshiba_satellite_2410_s203_pc_notebook/manual-14885
Nov 16, 2010 | Toshiba Satellite 2410-S203 Notebook
I have a compaq presario F756nr with an Atheros wireless wi-fi card in it. Can I replace the wi-fi card with a Broadcom 802.11 b/g wireless LAN card?
no you cannot replace the built-in wi-fi card...
if you try to change the drivers for atheros wi-fi to Broadcam driver, your wi-fi card will not function anymore.... but you can always install another WI-FI card in your laptop... you can buy a USB Adapter or a Cardbus(PCMCIA) adapter for this purpose...if you want your wi-fi signal strenth and range to be higher, you can opt to buy an adapter which comes under N standard....N standard wi-fi adapters are capable of connecting at a speed of more than 300mbps(practically) to any N standard device like router....
Mar 29, 2010 | HP Compaq Presario F756NR Notebook
My msi mini note pad will can up to the internet when plugged directley in to the modem but not via wireless router, how do i enable the the laptop to pick up the wireless signal
First make sure wi fi switch on laptop is turned on.
MAke sure wi fi network adapter driver installed and enable.
Right click on my network places so you can see your wi fi network adapter there if it is installed .
Right click on it then enable.
Then again right click on it then click on view for available wi fi networks.
Then it find network if any wi fi router is in range.
Then click on connect.
Let me know if you need further assistance.
Thanks.
Nov 04, 2009 | MSI Graphics Card - ATi RADEON 9550 250MHz...
Driver of buffalo airstation wli-pcm-l11g
Dear anicet, here are the driver you need for your buffalo wifi card
Website:
www.buffalotech.com/wireless
Email:
Sales - sales@buffalotech.com
download it and refer you buffalo wifi card to this downloaded driver
Oct 17, 2008 | Buffalo Technology Buffalo AirStation...
About wi-fi
Windows XP has a built in wifi configuration tool, previous versions of windows dont have this feature. But if you were to buy a wireless card it comes with software for wireless to work on all versions of windows from 98 - XP most if not all new laptops have wifi built in & that will be able to share your broadband connection through the netgear router. You can configure the laptop & pc to share files & printer between each other, easy way of doing that is by using the wireless network setup wizard which can be found in Start -> All Prograns -> Accessories -> Communications -> Wireless Network Setup Wizard.
Feb 10, 2008 | Computers & Internet
Lexmark X3550 All-In-One Printer Logo
187 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
