Sound volume the volume of the speakers or the sound coming from the speakers is weak. i have adjusted the volume control using the accessories->entertainment->volume command but to no avail. i looked at the computer from every angle but i don't see anything i could adjust manually to increase audio volume.
  • baylene Nov 16, 2008
    no sound
  • ramkumar97 Dec 14, 2008
    I have the same problem .. the onboard speaker volume on my dell vostro 1310 is very feeble . any help possible
    Problem Solver:
  • 17 Answers
Have you tried a different set of speakers? you should be able to plug them into the headphone jack. speakers without a power supply are softer. my laptops the same way. i use vlc player when i play videos because you can turn the volume up to 200%.
Posted on Nov 17, 2008
No sound on left front speaker
you need to set up the individual volume levels for each speaker.
do a sound test tone which will check for a signal from each speaker.
if you hear the speakers at different volumes you know you need to adjust the ones that are too weak. hope this helps
Mar 27, 2014 | Yamaha RX-V420 Receiver
I am having problems adjusting volume
What type of laptop HP , ASUS , COMPAQ , ACER ?..........
Up the Volume on My HP Laptop
Open the "Start" menu and click on the "Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either "Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the slider.
If you need to decrease the volume, simply move the slider bar down.
Click on "OK" when finished and close the "Control Panel" window.
Click on the speaker icon in the bottom-right corner of the screen for a faster volume adjustment. Simply move the slider bar up to increase the volume and move it back down to decrease the volume.
Volume on an Acer Laptop
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop.
If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume.
Be sure the speaker icon below each control is not accidentally muted.
Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category.
Aug 10, 2013 | Computers & Internet
Sound is not coming
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Oct 27, 2011 | VIA ASRock K7VM3 Socket A/...
Speakers were working,then i pressed something to see if was gonna sound different and now i cant find my way back to what it was...sound is coming from the computer to the tv,,but external speakers have...
also
hope it helps
Sep 22, 2011 | Logitech X-230 Computer Speakers
My laptop is a acer extensa 5220, sound is not coming on, so what will i do or how will i install the sound device
also
Sep 20, 2011 | Computers & Internet
There is no sound coming from the logitech x-240 speakers. How do we trouble shoot this problem?
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume adjustment you will need to right click on the volume icon depending on your operating system select adjust volume
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 22, 2011 | Logitech Audio Players & Recorders
Owned sound stix II for 3 years. not alot of heavy use. now no sound. blue light in sub weak. may need repair shop.
If you are having problems with you sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar:
Jun 29, 2011 | Harman Multimedia T9078 2.1 Speakers
I just connected my Logitech lS11 speakers. How do I tell my computer that I now have these? When I click on my volume icon in the tool bar to adjust my volume does not work? thank you
Windows does not detect specific models of speakers. I would adjust your Windows volume all the way up and then adjust the sound on your volume knob on speakers. This way the sound volume is easier to adjust on speaker than using the volume control in the toolbar.
Mar 06, 2011 | Logitech LS11 Speaker 2 Speakers
My Mic is on all the time it is also coming through the speakers so when i turn external speakers on there is an huge feedback
See Adjust volume below
To use any microphone with your computer you will need to enable it in control panel. Instructions are for Windows XP but are similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and the volume slider is at the top of the scale.
Ensure the MUTE ALL box isn't checked before closing window.
Click VOLUME button in SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. The same applies to 'Internal MIC' if you are using a laptop with built in microphone - this must be enabled/ disabled separately to the external MIC.
To adjust audio volume.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You can also put a check mark in the box to show the volume control icon on the Task Bar so you can go straight to it to in future
Feb 10, 2011 | Toshiba (P000257700) Microphone
Can't find the hands free speaker button
In an increasingly hands-free world, the external speaker feature of cell phones has increased the usability of cell phonesmag-glass_10x10.gif in the car, public transportation and at work. The volume controls on the external speaker controls can be somewhat difficult to find and manipulate.
  1. Step 1 Make sure the speaker setting is actually on. If the speaker is turned to off, the volume you hear will be coming from the earpiece and will be very low indeed. Sometimes there is a button on a cellphone which you can simply press and hold to activate the speaker function. You will notice a difference immediately.
  2. Step 2 Check to see if you have external volume controls. On some models, there is a button or two buttons that adjust the volume of both the handset and the speaker volume. If you have these buttons, use them to adjust these controls while on calls. Remember that adjusting the speaker volume will subsequently adjust the handset volume once you've turned off the speaker mode.
  3. Step 3 Access the sound controls in your phone. If your phone does not have external speaker control, it can be accessed by adjusting the controls saved on your phone. Also, the main settings can be controlled even if you do have external controls. Phones are different, but in your menu of options, choose sound and sound controls. This should give you options for ring volume, alarm volume and handset volume.
  4. Step 4 FInd volume controls for all settings. If you wish yo have multiple settings for each function---alarm, calls and speaker---you should be able to adjust these accordingly. Search through the control options until you've found speaker controls. Choose the setting you desire and save the settings.
  5. Step 5 Using the main volume as a foundation, use the external controls (if applicable) to adjust the levels.
Nov 15, 2009 | Cell Phones
Computers & Internet Logo
242 people viewed this question
David Payne
David Payne
