Question about Creative Labs ZEN V Plus MP3 Player
Stuck inshutting down mode
My Zenn is stuck in shutting down mode - I'm charging it but I doubt it's taking the charge and it's not recognised by my laptop now either. Any ideas to solve this please?
Everyone probably knows this but I'm a novice! I reset it with the end of a paperclip!! Thanks.
Posted on Nov 16, 2008
Tip
Charging of laptop while shut down may cause the corruption of operating system....
Charging of laptop while shut down may cause the corruption of operating system. While shut down battery level will store in the memory and in the shut down mode, if you are charging, it will store in another memory location. After that if you are switch on the system, it will compare both values. If both are not equal, it may be corrupt the operating system. I had affected by this. It wont happen in all times ..Once happened for me after that for knowing purpose i did the same for three more times.. But not the same result. Better to save laptop life, please dint charge while shut down
on Dec 05, 2009 | Computers & Internet
Battery not recognised/not charging
Turn the computer off, unplug it, take the battery out. Then hold the power button down for 10 - 15 seconds. Plug the ac adapter back in, but do not put the battery in yet. Boot the computer, then shut it back down. Put the battery back in then boot it again. It should recognize the system now.
Jul 31, 2014 | Sony VAIO VPCEA36FM/W Laptop
Nokia 1661 slight water damage - test mode
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Feb 14, 2010 | Nokia 1661 Cell Phone
The camera will not turn on even when connected to the power supply, and the red light stays on indicating is fully charged but when I try to open the dvd disk will shut off and will not work at all
your cam is inshut down protect mode there is
an electronics problem in your power converter inside the cam ;if the cam go on whit the battery its your power supply....
Feb 07, 2010 | Canon DC100 DVD Camcorder
Ok I have a 85 volvo 244 dl 2,3 is there a
THERE IS A SENSE CABLE CONNECTED TO THE ALTERNATOR, UNPLUG THIS CABLE AT THE CONNECTOR THEN START CAR, IF THIS DOES NOT HELP , IF THE CHARGE WARNING LIGHT COMES ON WITH THE IGNITION , BUT IS SLOW TO GO OUT WHEN THE ENGINE IS STARTED , THIS MAY INDICATE AN IMPENDING ALTERNATOR PROBLEM IF SO REFER TO AN AUTO/ ELECCTRICAL SPECIALIST.
Oct 27, 2009 | 1984 Volvo 240 Series
Zen won't charge and continually rebuilds library unsuccessfully
buy a new battery, or try cleaning the connections dist is a big problem at small devices like this...you your vacume cleaner, but BE CAREFUL!!!
Aug 25, 2009 | Creative Labs ZEN V Plus MP3 Player
My creative zen v plus is stuck in shutting down
i think i have a different version of zen but hopefully it'll work for you. i held down the power button and pokes the reset button with a pen tip for about 5 seconds and it finially turnned off! i've had alot of problems with the zen and it sorta happens alot and most times you need to do different things but the same problem usually doesnt come bk. good luck
Mar 12, 2009 | Creative Labs ZEN V Plus MP3 Player
My battery is not recognised and doesn't charge
Check the battery status manually
To accurately measure the condition of the battery, the PC cannot be used during this test. This method will Test the battery by completely charging the battery then will determine how long it takes to discharge the battery. This test is done while the PC is operating in the Safe Mode and not being used for any other action. This test will require 1-3 hours depending on condition of the notebook PC. The PC cannot be used while you perform the following steps. Completing all the following steps will also calibrate the battery so that the power meter reading are accurate.
  1. Connect the AC adapter and allow the notebook to charge until the battery is charged to 99% - 100% of capacity.
    • To determine the percentage of battery power, with the notebook operating normally, right-click on the c00586951.jpgpower icon in the system tray, and select Open power meter . The Power Status is displayed.
  2. Shut down the notebook PC when the battery has charged to capacity.
  3. With the notebook turned off, connect the notebook PC to the AC power adapter that is plugged into a working wall outlet.
  4. Press and release the Power Button to start the computer.
  5. Press the F8 key several times when the HP Logo displays.
  6. When the Windows Advanced Startup Menu displays, select the Startup in Safe Mode option.
  7. Notice and record the current time as the Test Start Time with a fully charged battery.
  8. Remove the AC power adapter cable from the notebook PC.
  9. Allow the battery to discharge completely until the notebook PC turns off.
  10. Notice and record the Completely Discharged Time.
  11. Subtract the Discharged Time from the Start Time to calculate the Elapsed time.
  12. Record the time for future comparison or to provide to an HP support specialist if you suspect the battery is defective. NOTE: As with all batteries, the maximum capacity of this battery will decrease with time or use. Loss of battery capacity will vary depending on the product configuration and usage, including but not limited to: product model, applications running, power management settings, and product features.The battery warranty does not cover natural deterioration of battery capacity. Your battery is only warranted from defects in materials or workmanship resulting in failure.To determine if your battery has had a warranted failure you may be required to run an HP diagnostic.
After performing these steps.
--- Remove the batter and power cord
---After 5-10 mintues insert the batteryu and comment the AC Adapter and then Press the power button on the notebook for about 5 minutes .
If there is any power issue the issue may fix.
Jan 08, 2009 | IBM ThinkPad R40 2681
Tape stuck in an Emerson Model EWV401 VCR
take it to someone who has experience in removing stuck VCR tapes or you will be paying a lot more for a new VCR. They won't charge you much....IF they even charge you.
Apr 04, 2008 | Televison & Video
Creative Labs ZEN V Plus MP3 Player Logo
52 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
