Question about Canon PIXMA iP1800 InkJet Photo Printer
Printer could not print
My printer could'nt print, if i attemp to print a document the printer will process it but the paper could'nt in the printer untel the printer will stop without output
  • Anonymous Mar 14, 2014
    Computer says printer is on line. Printer says processing. Won't print.
I don't know to install paper in printer
Posted on Nov 22, 2008
WHEN TRAY EMPTY PRINTS OUT OF OTHER TRAY
The user cannot select a paper tray for a print job from within an application. It is also not possible to configure a default paper tray in the Document Defaults, Printing Preferences, Printing Defaults driver options.
This problem may be experienced with an HP PCL5e, PCL5c, or PCL6 LaserJet printer driver on any of the following Operating Systems:
  • Windows NT 4.0
  • Windows 2000
  • Windows XP/.NET
Typical symptoms of this issues include:
  • Paper tray selection grayed out.
  • Cannot select paper tray, only size and type.
  • Not possible to select tray.
SOLUTION: Perform the following steps to clear the NT Forms configuration.
  1. Go to the Printers folder by clicking Start , Settings , and Printers .
  2. Right-click the printer and go to Properties .
  3. Go to the NT Forms tab.
  4. Click the Clear All button.
  5. To save and exit, click the OK button.
SUMMARY: This is expected printer driver behavior. The NT Forms feature allows a user or system administrator to configure a so-called "form-to-tray assignment" for the printer. When this feature is enabled it is not possible to select a specific paper tray for a print job, or to set it as default, because the system is aware of the specific paper size and type loaded in the various printer trays, which makes the source selection redundant. Some applications or environments may require a "form-to-tray assignment" in order to take advantage of certain features. For instance, in an Active Directory environment, this feature has to be enabled for the operating system to be able to report the available paper sizes in the printer to the Active Directory
Nov 22, 2013 | HP LaserJet 5000 Printer
Blank page feeding during print job
Please adjust paper size in printer properties.
Oct 09, 2008 | HP Deskjet 6940 InkJet Printer
My hp deskjet says there is a paper jam when there is none and will not print
If your printer for any reason reports a paper jam, withput going through the "clearing paper jam" procedure it may not respond to print command. So follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Good luck & God bless!
Mar 01, 2011 | HP Deskjet 3845 InkJet Printer
Power went off when I tried to print
Would be helpful to know which operating system you are using and whether there where any warning light flashing. For starters review the following solutions.
Printer Does Not Start or Stops During Print Jobs
Inner Cover was open when you started printing.
Close the Inner Cover and press the RESUME/CANCEL button on the printer. The printer resumes printing.
Inner Cover was opened while printing is in progress.
A page of print data being sent at the time of the error will be erased, so print that page again.
The printer has been printing continuously over a long period.
If the printer has been printing continuously for a long time, the Print Head may overheat. To protect the Print Head, the printer may stop printing at a line break for a period of time and then resume printing.
In this case, interrupt your print session at a convenient time and turn the printer off for at least 15 minutes.
Additionally, if the printer has been printing graphics or photos with intense colors continuously over a period of time, the printer may stop printing to protect the Print Head. In this case, printing will not resume automatically. Turn the printer off for at least 15 minutes.
i_expl.gif Caution
The Print Head and the surrounding area can become extremely hot inside the printer. Never touch the Print Head or nearby components.
Out of paper.
Make sure that paper is loaded in the selected paper source.
Reload paper if no paper is found in the selected paper source (Auto Sheet Feeder or the Cassette).
If the same paper is loaded in the other paper source, you can switch the paper source with the Paper Feed Switch or the printer driver to continue printing.
If both paper sources have run out of paper, confirm the selected paper source and load paper there.
Printing documents with plenty of photographs or illustrations.
When the POWER lamp is flashing green, the printer or the computer is processing data. Printing large data such as photos or graphics takes time for the printer and the computer to process, during which the printer may appear to have stopped operating.
In addition, when printing data that uses a large amount of ink continuously on plain paper, the printer may pause temporarily. In either case, wait until the process is complete.
i_note.gif Note
If you are printing a document with a large printing area or printing multiple copies of a document, printing may pause to allow the ink to dry.
Dec 08, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Printed text is very small, not legible and does
Go to to print menu box i.e. press ctrl P. Look for zoom. There you will see "scale to paper size." Here select from the drop down list "no scaling" or "A4" depending your paper size. This shoule correct it.
In case you do not see these on your print menu click "properties" on your printer. In the box that appears look for "scale" and make it 100%. These are the components that control percentage size of original documents printed.
Dec 08, 2009 | HP DeskJet 930c InkJet Printer
My HP C7250 inserts a blank page between every printed page. Windows Vista PC.
Perhaps this is a characteristic of the document being printed: Manual paper feeds in addition to the automatic paper feed characters? Use the word processing program matching the document to remove the unwanted paper feeds.
Aug 22, 2009 | HP Photosmart C7250 All-In-One Thermal...
Problem printing a word document
Go to the printers folder & right click on the printer icon & select properties, under advanced click on print processer & change it to Winprint & Ntemf 1.008 & then try printing
Jun 04, 2008 | Lexmark X5470 All-In-One InkJet Printer
Printer will not print
Firstky u need to make sure that the printer drivers are nt corrupted, i wuld suggest u reinstall them, make sure u do nt have any paper jam, check 4 small paper pieces inside, listen if the printer tries to pull the paper in.
Feb 22, 2008 | Epson Stylus Photo R260 InkJet Printer
Won't print on normal paper
Refer to my previous post about manual under head cleaning and follow the routine through. This will most likely get you going as sounds like classic blocked nozzles. http://www.fixya.com/support/t137335-problem_print_outs_from_printer
Jul 01, 2007 | Canon i860 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
old marine
old marine
