Question about Dometic Refrigerators
Dometic RM 7851 L indicator led led light not visible when on the 12 volt position
22yooper
  • 828 Answers
SOURCE: Dometic Caravan Fridge 7271
Your refrigerant may have completely separated in the system. Shut of the gas, disconnect the electrical and remove refrigerator from the coach or if you have sufficient room inside set it on a clean area. This operation is what is called burping the system.
1. From the base roll it onto the door and wait five minutes.
2. roll it onto the top and wait five minutes.
3. Roll it on the back and wait five minutes.
4. Return it to the base and wait five minutes.
Reinstall it or test it on electrical. It should show signs of cooling in about 30 minutes in the freezer compartment if the system is not plugged in the boiler.
Posted on May 26, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: My dometic frig will not work no power. Has 12 volt and 110 volts
Replace the bulb and also check the relay and the sensor in the back of the unit. But first try replacing the bulb
Posted on Feb 13, 2009
  • 103 Answers
SOURCE: Model 211 Dometic, can not keep pilot lit, do I
Dometics work on propane, 12 volt or 110 volts, if pilot won't stay lit then you prob have a control board defective. Apply 12 volts and see if pilot stays lit, then you will know.
Posted on Oct 17, 2009
Testimonial: "Thanks, in the middle of changing out the 12v adapter from the trailer thanks"
motor1258
  • 6674 Answers
SOURCE: cant find the fuse for the refrig. no power
Check connection for 12 volts, at back of fridge behind vent cover .(outside) Make sure 12 volts getting to the lugs where they join. If you have 12 volts to there, unplug fridge at receptacle usually on left side by back of fridge, just to be safe. Remove cover on circuit board and look for a blown (glass type fuse in there.)
Posted on May 09, 2010
motor1258
  • 6674 Answers
SOURCE: 9 year old dometic will not get12 volt power.
There should be 12 volts connected at lugs near bottom of back of fridge, behind vent cover. Not there?
Dometic fridge not working on 240 volts gas ok and 12 volt ok
The AC heater element is most likely open. Replace it and it will restore AC operation.
Sep 21, 2016 | Dometic Refrigerators
Dometic rm 2353
pull off back panel make sure 12 volts and check fusible links
Apr 11, 2014 | Dometic Refrigerators
My dometic rm 2612 stops working at least once a day the check light goes on.
Your 'frige has either; a 12 volt power supply or, a gas flame to circulate the refrigerant gas to cause absorption refrigeration to work; check or, replace your power supply as it 1. holds open the gas valve relay, 2. heats the gas with a heating element.
Mar 30, 2010 | Dometic RM2620 Refrigerator
How many amps does a unit like this use?
The RM2652 is rated at 120VAC @ 2.7 amps.
Jul 15, 2009 | Dometic RM2652 Refrigerator
No propane
Yes it can also run on 120 AC and 12 volt DC
Here is the website. If you need help in understanding let me know
http://www.campingworld.com/shopping/item/dometic-rm2193-compact-refrigerator/13473
Apr 21, 2009 | Dometic WA3210 Compact Refrigerator
Refrigerators Logo
90 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
