Question about Sony Playstation 3 (PS3) Console
PS3 Display GTA 4 got stuck inside my PS3 so I help down the eject button down and rested the drive, the disc came out. I thought everything was OK but when I turned the system on the them music played and the 'Sony Entertainment' sign appeared and so did the wavy screen saver but the Xcross menu bars didn't appear so I left it for a while and still nothing happened plz help me
  • 5 more comments
  • jaybay797 Nov 18, 2008
    When I turn on my Plastation # the them music plays, the 'Sony Entertainment' sign appears and so does the wavy screen saver but that is all that happens. I can't acces any the Xcross menu bars because they don't appear and neither does the game run...plz help
    it hasn't Frozen the Xcross menu bar doesn't appear...
    the game is not stuck inside anymore, i just can't do anything else read Above^^
    I CANNOT ACCESS ANYTHING BECAUS ALL THAT DISPLAYS IS THE WAVY SCREEN SAVER, NO XCROSS MENU BAR OR ANYTHING...
    THERE IS NOTHING WRONG WITH THE DISPLAY SETTINGS THE WAVY SCREEN SAVER IS ALL THAT APPEARS...
    Yes i will thank you, finally a solid answer...
  • jaybay797 Nov 19, 2008
    I did and they told me to do a system restart and the screen went blank...
  • 541 Answers
I would call sony up and they will tell you how to do a full reset on your ps3
Posted on Nov 18, 2008
  • Lee Reynolds
    Lee Reynolds Nov 18, 2008
    let me now you get on with it if no joy then i will read up on it for you and get back to you
  • 1,879 Answers
Issue:
-Freezing when doing anything
-No Hard Drive activity
-Freezing when trying to use on-board keyboard or bringing up keyboard
-Game/Movie Disc freezes system
Solution:
Factory Reset / Hard Reset the PlayStation 3
Prior to doing the hard reset try the following things:
(If applicable)
-Restore default PS3 settings via System menu
-Restoring PS3 system and a quick format via System menu
-Full format via System menu
If you still can, backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to Sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
  • 10,515 Answers
Hey, Try all this....
Hold the On/Off button till the system turns off. Once the unit is off, on the back of the PLAYSTATION 3, turn the main power switch off. Wait approximately two minutes and turn the PLAYSTATION 3 back on
If it works, than g8, unless try 2 more options:-
1.
  • Check that the input mode of the TV is appropriate for the connector in use on the PLAYSTATION®3 computer entertainment system.
  • There may be a problem with the cable in use. Try using another cable that is compatible with the PLAYSTATION®3.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • 2.
    If you are changing cables or cannot see an image on the screen, you may need to reset the video output to default settings. To reset the video output:
    1. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
    2. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
    I hope this wld slve ur cncrn :)
    • taran_2005
      taran_2005 Nov 18, 2008
      Hey,
      As u said that u do not have issues regarding the display, in this case, we may try
      one more solution,
      Format the hard disk and install all the data again.
      You can simply remove the HD and hook it to any standard computer that has SATA Controller on it and format it or use a utility to wipe it clean.
      You can also put it in an external USB SATA case and plug it into any PC and format it also.
      It's just a standard notebook SATA HD.
      And i am sure than this issue wld be be there.
      Master:
      Sergeant:
    • 449 Answers
    Hi!!!
    unplug all and then unscrew
    then unscrew the cover that holds
    the disk and then place it back properly!!
    • Sony Master
    • 19,396 Answers
    REMOVE ALL DISKS FROM THE INSIDE, UNPLUG POWER CORD FOR TEN MINUTES, PLUG BACK, AND RESTART THE PS.
    If the playstation is still freezing, then the internal software had been damaged.
    Give a call to Sony number and tell them what happened, they can offer you a free replacement depending on the circumstances, and if you did not cause the fault by yourself.
    • 1 more comment
    • Ginko
      Ginko Nov 18, 2008
      Check first the controllers cable.
      Try the following procedures:
      1 PS jammed - Do soft reset: hold the front power button for about a minute.
      2 Disk drive faulty. Call Sony Customer Support on the numbers you find on the following websites:Sony USA Sony UK http://au.playstation.com/&sa=X&..." target="_blank" rel="nofollow" >Australia
      Keep ready the serial number that you find on the back of the playstation, right under the bar code.
      3 Connection problems - If you are using HDMI cable, unplug the HDMI connector and connect to the TV with RCA, theng go to settings-display >> setting-video output setting, and changethe setting back
      to AV MULTI/SCART and just follow the messagesthat will pop up
      telling that if the screen goes blank The PS will reset video connection to the original
      settings.
      Connect back HDMI to restore the original connection, or keep PS on RCA.
      4.You may have damaged the lens or the blu-ray diode, in this case call Sony to arrange the repair, or have it fixed at a local repair shop. The cost is around $80 (fifty pounds in UK).
      5. Most important thingg to do is finding Sony phone number and calling them, if you did not cause the fault, and the PS is gone faulty by itstself, without you doing any wrong operation, Sony will offer you a free replacement, they always do as PS has 3 years factory warranty.
      Give them a call.
    • Ginko
      Ginko Nov 18, 2008
      To make it shorter, do the folowing, but do it:
      1. Unplug all PS cable and plug it back.
      2. hold the front power button for about a minute.
      3. Call sony because the image on the HD is damaged, you find the number on the manual, you may be offered a free replacement.
      Do the steps above (but do it) and then get bact to us and report the outcome.
      Thanks.
    • Ginko
      Ginko Nov 18, 2008
      finally a solid answer????
      It is two hours that I am insisting with you to call Sony .
      IU even wasted my time in finding the web contact pages from three continents.
      I wonder if you did see my previous comments.
      What would be the solid answer , please?
      Let me also know if you saw my previous comments.
      Thanks.
      Scholar:
    • 181 Answers
    Just unplug the device for sometime.remove all the connections then reinsert all the connections and the plug in and the ON and check out.
    • fixyy Nov 18, 2008
      Please run through the following, go through in order.
      1) Delete the game's install data. This is done via the PS3
      options. Scroll along the cross media bar until you reach the 'Game' tab, now
      scroll up / down the list until you reach the 'Game Data Utility' Enter this and
      locate the GTA IV option. Highlight this and press triangle once, from the menu
      select Delete. This will delete the game's install information.
      2) Delete the game's save files. To delete any save files
      you will need to do the following. Scroll along the cross media bar until you
      reach the 'Game' tab, now scroll up / down the list until you reach the 'Save
      Data Utility' Enter this and locate the GTA IV option. Highlight this and press
      triangle once, and from the context menu select Delete.
      3) Disable your Internet connectivity for the PS3. To do
      this scroll along the cross media bar until you reach the 'Settings' tab, now
      scroll up / down the list until you reach the 'Network Settings'. Now scroll
      down to the Internet connection option and press x, now select the disable
      option. Once this has been done unplug the ethernet cable if you are connecting
      to the Internet if using this.
      4) Disable the console's information board. To do this
      scroll along the cross media bar until you reach the 'Network' tab, now scroll
      up / down the list until you reach the 'Information Board', highlight this and
      press triangle. From the menu select 'Do not display' Press X to confirm
      this.
      5) Disable Media Server functionality. Scroll to Settings,
      now scroll up / down to 'Network Settings' select Media Server connection. Once
      this has been done press triangle and change the option Disabled.
      6) Delete all of the system's Internet cache. To do this
      up / down the list until you reach the 'Internet Browser', highlight this and
      press X. Once you browser opens press the triangle button once, from the new
      menu highlight the 'Tools' option and press X. Scroll down the menu until you
      reach 'Delete Cookies' and press X. Confirm the files deletion. Repeat this for
      'Delete Cache'.
      7 ) Turn off the PS3 screen saver. Use the cross media bar
      to scroll to 'Settings', select 'Display Settings'. Now highlight 'Screensaver'
      and set this to 'Do not use'.
      8 ) Once this has been done, manually restart you PS3 by
      holding down the power button for 5 seconds it will beep once and then shut
      down. Release the power button and re-press it and hold for about 5 seconds. The
      system will then boot and reset all display settings. You will be prompted to
      reset your display settings to how you require them.
      9) Once restarted please try the game again, you will be
      prompted to reinstall.
      Once the game has started please turn off the following
      features:
      1) The game's auto-save. Press Start, Game, and locate the
      Auto-save option. Turn this off.
      2) Turn off the game's flicker filter. Press Start, Display
      and locate the Flicker Filter option. Turn this off.
      3) Turn off the controller vibration feature. Press Start,
      Controls and locate the vibration option. Turn this off.
    Ps3 slim 129 gb will mot eject mw2 it makes the beebing noise and the another weird noise that sounds like it is stuck and the doesnt work the games does eject from the main menu but it is still in the ps3
    1. First shut down the system by flipping the power switch in the back off.
    2. Hold down the eject disc button.
    3. While still holding down the eject button, flip the power switch to turn back on your PS3.
    4. When the green light comes on, wait a few seconds then tap the eject button a couple times. The fan will run on full power and the disc will eject.
    Nov 23, 2010 | Sony Playstation 3 (PS3) Console
    My game is stuck in my ps3 and is making a clicking noise
    have you tried to tell it to eject from the game disc options using triangle button ? just a thought but it sounds quite critical if its clicking like your ejection drive is having issues hope this helps
    Nov 17, 2010 | Sony Playstation 3 (PS3) Console
    The game got stuck inside,and It doesn't reject it. What I need to do to take it out ?
    Ok please try the following to force eject your disc. Turn off the power at the back of the PS3. Press and hold the eject button. Turn the power back on at the back of the machine. The fan should start to spin very fast but your disc should also be ejected.
    Hope this helps and thank you for using FixYa
    Sep 05, 2010 | Sony Playstation 3 (PS3) Console
    I just recently installed a new blu-ray drive into my PS3 I switched the contoller board and everything, but now the drive wont take my discs... i mean I can push it in but the drive wont grab it and pull...
    ok sounds like you did every thing correctly and switching the board was in the right directio however the controller chip on your daughter board very well could be damaged since these boards rest directly overtop of the gpu and cpu the heat goes smack dab into the metal caing wich in some cases the case toushes the bottom of the daughter board resulting in a over heated controller chip
    possible repair is
    replacing that chip
    with a infectus chip
    i am still working on this problem
    ive had 2 good repairs matching problem..hope this was helpful
    Oct 18, 2009 | Sony Playstation 3 (PS3) Console
    How do I get a stuck disk out of my play station3? It will power up but when i hit the eject button the standby button turns red. We think there are two disc stuck in there but we cant be sure.
    I have seen several suggestions at the playstation*com PS3 forums in the past, such as:
    | Zr0_C00L wrote:Try turning it off from the back,
    | then hold the eject button while you flip the back
    | power switch back on. Worked for my buddies
    | when his died (good thing too, it was my game
    | in there!)
    | i too did the same thing and it worked for me.
    This one with multiple discs jammed it sounds like it may apply to you:
    "If anyone is having any problems, this is what worked for me. What is more amazing is that my son somehow managed to force 3 discs into that tiny slot...no idea how he pulled that one off.
    So after two hours, a pair of tweezers, a fork, and a butterknife, I decided to try one last thing before giving up. I put the PS3 on its nose, disc tray down, held the eject button while it was on, and pushed a disc in and out of the drive. This caused whatever was in there to finally 'catch' as the drive had been trying to force everything out. After 2-3 minutes of play, a disc finally poked out. I pulled what i thought was one and two discs came out. I set it back down flat, tried to put a cheap DVD in (didn't want to test it with a $60 game) and it seemed something was still in there. I hit eject and out came the third disc. I put the DVD in reluctantly and the PS3 took it and loaded it right up. Unbelievable. After all this abuse, it's apparent these things are built like tanks."
    You gotta love children.
    Hope that helps.
    Oct 14, 2009 | Sony Playstation 3 (PS3) Console
    Disk will not go into PS3 appears to be blocked
    Press and hold the eject button for around 15 seconds, this resets the cd drive and will fix your problems. Hope this helps
    Jan 18, 2009 | Sony Playstation 3 (PS3) Console
    Something stuck inside disc drive
    try this, press and hold eject button for around 15 seconds, this resets the cd drive, hope this helps
    Jan 10, 2009 | Sony Playstation 3 (PS3) Console
    Game stuck inside of PS3
    hi you could try holding down the eject button for over 10 seconds, it rests the disc drive. hope this helps
    Jan 22, 2008 | Sony Playstation 3 (PS3) Console
    Help cd stuck in my ps3 console
    hold in ps button on controller, switch off system and restart or quit the game and go to the ps3 main menue, eject it from the menu by going to options on the cd, dont do it manually especially with a ps3 game, it only really works with a dvd.
    Dec 30, 2007 | Sony Playstation 3 (PS3) Console
    PSP Game Stuck in PS3
    1. Unplug PS3
    2. Stand up so as you are looking down into the disc opening.
    3. Fold out the felt that protects the drive.
    4. Look for what resembles a disc. (You should see it)
    5. Take to butter knives from your kitchen and with both hands use it like tongs to go into the drive and pinch the disc.
    6. Pull out the disc and your DONE.
    Worked for me a couple of times.
    GOOD LUCK
    Dec 07, 2007 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    158 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Iron
    Iron
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
