Question about Infinity Reference 1600a Car Audio Amplifier
Infinity 1600a cuts out wit real low bass when turned up load
The box i have is wired to 2 ohms this amp sould beable to handle the load
This amp is 2ohm stable, but if you use a dual sub setup and use both sets of output terminals it is automatically wired parallel at 2 ohms if you then have 2 subs that are dual voice coil and the voice coils of both are wired in parallel then the load become .5-1 ohm and the amp is unstable (solution) wire 2 dual voice coil subs individually one from each terminal, and then wire the voice coils in series rather than parallel
Posted on Jan 26, 2009
  • 631 Answers
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts on either terminal when you drive the amp hard, you need to check the wiring feeding whichever line is dropping too low.
Posted on Nov 17, 2008
How do I connect my nitro 1000 watt amp to get thr most bass .i have two 15 vx kickers
If you have the Nitro bmw-482 running it at 2 ohms will give you the max output (its not 1ohm stable so don't run it that way). First run your two dvc speakers parallel (run both negative out puts together and both positive out puts together on each speaker). After this you should have 1 positive and 1 negative wire from each speaker (4 wires altogehter). This will give you a 1 ohm load which your amp can't handle, so you have to run the 4 wires in series to create a 2 ohm load. Now take the positive wire from 1 speaker and connect it to the negative wire from the opposite speaker. Thats how to run in series. Now you should have 1 positive wire from 1 speaker and 1 negative wire from the other speaker which is 2 ohm load. Your amp sould be bridgeable, so connect the positive wire into the correct terminal of your amp and the negative wire into the correct terminal of your amp according to where to bridge it (positive into left positive, negative into right negative) . That will give you a 2 ohm load bridged which is the most power you can get out of your amp 300 watts. Medium quality amps are over rated so you will never acheive the 1000 watts as advertised.
Dec 01, 2011 | Car Audio & Video
My brand new Kappa One amp is powering 2 brand new Kappa 100.9w subs at a 2 ohm load. The Ground an Power are both 4 gauge wire. The problem is my amp is just getting so hot that I can only touch it for a...
Sometimes these amps have been known to get hot very easily. That said, I would first confirm the resistance on your speakers at rest is 4 ohms each, so that your amp is seeing a 2 ohm load. Be sure that the smart switch on each sub is flipped to the 4 ohm mode, and measure each separately.
Be sure that you've properly set the filters, gain, and bass boost so that your amp is not being over driven. Your HP filter should be set no lower than 20Hz--most music is never going to go that low so there is no point. A narrower frequency band is always going to be healthier for your subwoofer. The LP filter should be set no higher than 90 to 100 Hz at the most, depending on how much midbass your speakers can handle, so that you don't have too much of a sonic gap between the subs and mids. As for the gain, a good place to start is with your radio set at it's highest comfortable, distortion free setting, minus 25%, then start with the amp's bass boost all the way down, and the gain set to the minimum level at which you can just begin to hear music. Choose a bass heavy track if you ever listen to bass heavy music, so we can prepare for the most stress that the amp will experience. Slowly turn up the gain until you start to hear distortion during heavy bass hits, and back off 20% - 25%. This should be the highest volume you ever push your amp to, and from here, you can ever so slightly turn up the bass boost if you absolutely must, but not to the point of any distortion, if you hear any, back it off a bit.
Jun 22, 2017 | Infinity kappa one Car Amp
I have two audiobahn aw1206t 12in. subs in a box hooked to a 100.1 american bass amp its 1000 watt mono block. i also ran a capacitor due to my lights dimming. but for some reason my amp keeps kicking over...
This could be caused due to the impedance load being to low. Your amp is stable to 2 ohm load however its very possible that you have your subs wired to a 1 ohm load that would cause the amp to go into protect mode. The subs you have are dual 4 ohm voice coils and would need to be wired in series/parallel. I've included a link that will show you how the subs should be wired.
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2-DVC-4-ohm-mono-low-imp.jpg
May 16, 2011 | AudioBahn AW1206T Car Subwoofer
How do i wire a single sub at 4 ohms? which speaker terminals would i use?
If your single sub is a 4 ohm sub, you just connect + and - on the amp to the corresponding + and - terminals on the sub.
If it's a dual voice coil sub, it would have to be 2 ohms per voice coil or 8 ohms per voice coil to be able to achieve a 4 ohm load.
This will show you exactly how you'd need to do it:
http://www.soundkraft.com/Subwoofer_Wiring.htm
Mar 07, 2011 | Infinity Reference 1600a Car Audio...
How do I hook up my infinity 1600a at 2ohms with 2 4ohm speakers?
Placing the speakers next to each other face down, you will notice that the connection points run in sequence +- and +-. Now connect the - (negative) from the one speaker, to the + (positive) of the other speaker. Now connect the open + from the one speaker and the open - from the other speaker to your amp. Your amp should have a bridging indication. On the connection points of the amp, you should see a mark pointing to the first + and the last -. That will be your bridge and thus utilizing the full potential of your amplifier
May 21, 2010 | Infinity Reference 1600a Car Audio...
Cuts out at high volume.
and that's fine with the ohm load. But if you have them wired all together or in parrelel it changes the ohm load. You need to wire them all together in parreallel or in series to get the correct ohm load. Check the wiring diagram at www.the12volt.com to see what your options are. the mrp amps are at a 2 ohm load smallest stable so makesure they are wired above or right at
Jun 08, 2009 | Alpine MRP-F300 Car Audio Amplifier
I have an Infinity 1600a amp pushing two Rockford
Try the head unit settings as depending on the head unit it can controll the amp sepratly
Apr 06, 2009 | Infinity Reference 1600a Car Audio...
12 w 3 v3 2 cut off
Again as I have stated in my other answer to you. You can not wire two SVC 2 ohm subs to acheive a 2 ohm load. more than likely you are running your amp at 1 ohm mono and this is why it is clipping and shutting off.
Jun 19, 2008 | Jl Audio 12W3 Car Subwoofer
Amp Issues
1) Make sure a bridged load of no less than 4 ohms is applied.
2) make sure both the left & right channels are working.
Jan 29, 2008 | Rockford Fosgate Punch P2002 Car Audio...
Installation
Hi JJerky,
I suggest we go for 2 ohm to preserve the amp and not heat things up so bad.
Your Subs are Dual Voice Coil(DVC) and 2 ohms each coil. I am going to tell you the wiring to insure you get balanced response from both Subs. We will wire the Subs Voice coils in Parallel to make them 1 ohm each. Then we will wire the Amp to the subs in series to make the total load on the amp 2 ohms. When you have series to both subs each sub gets the same current.
Example of my coding :SUB1VC1+ = Subwoofer 1 Voice Coil 1 Postive terminal.
SUB1VC1+ to SUB1VC2+
SUB1VC1 - to SUB1VC2-
SUB2VC1 + to SUB2VC2 +
SUB2VC1 - to SUB2VC2 -
AMP + to SUB1VC1 +
SUB1VC1 - to SUB2VC1 +
SUB2VC1 - to AMP -
This should give you a good repsonse.
Adjust your Bass Gain down very low at first. Also cut you LPF to about 60 hz. Crank up the volume on a bass test Audio track, Adjust the Bass Gain up unitl you get distortion. The turn it back a little. This is proper setting for your Gain.
Dec 01, 2007 | Lanzar OPTI1222D Car Subwoofer
Infinity Reference 1600a Car Audio Amplifier Logo
548 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
