Question about Maytag Washing Machines
LAT 9593 I have a Maytag LAT9593 AAW Top loading washer. The washer does not spin on the regular, permanent press cyles, it does however spin on the Delicate cycle. Any ideas what may be broken? The water does not empty out fo the machine in the regular or permanent press cycle but it does in the Delicate cycle. Thanks
4 Suggested Answers
  • 130 Answers
SOURCE: I have a maytag washer # LAT 9593 , washer fills with water very
Take off your hoses and check filters for sediment build up. If this is ok, you may need to replace the water inlet valve.
Posted on Feb 04, 2009
  • 1738 Answers
SOURCE: Maytag PAV2300AWW, ONLY WORKS ON REGULAR CYCLE. ON
Your timer is bad on that cycle. It is okay to use on regular cycle, but I would not use it on the delicate cycle, or will you burn up your timer. You should be home when using this, so if it does act up you can catch it.
Posted on Dec 01, 2009
  • 311 Answers
SOURCE: LAT 9400 AAW no motorized funtions only fills up
The only other thing it would check is your pressure switch. This will case a no agitation issue. If you remove clear pressure switch tub from the tub and blow into it you should hear a click from the pressure switch. With power your motor may agitate. Also check to see if the tube is clogged. If the issue is not in your pressure switch then i would have to assume the problem is in the timer. If you can read the schematic (usually located behind the control panel you could check to see if you timer is sending 120v down to the motor.
Hope this helps _MJ_
Posted on Jan 29, 2010
Spin cyle does not come ,but water drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Maytag PYE2300AY Electric Dryer
My model number is LAT 9593. The machine will fill, wash, but will not spin. I smell a slight electrical burning smell.
It sounds like your motor has failed. Let the washer sit unused for a day. then turn the washer to spin. Sometimes the motor will start cold. Replace motor.
Jul 01, 2009 | Maytag Washing Machines
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Feb 04, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Will not spin
If the motor is not running, it could be a faulty timer. If the motor runs, it could be the transmission. Check to make sure the pump belt is ok and the pump pulley is not seized by tilting the machine back and checking.
Jan 31, 2009 | Maytag LAT3600A Top Load Washer
Does not agitate
in the top of the agitator is 6 little dog ears very inexpensive and some what easy to remove your local appliance parts store should be able to show you how to replace them. just pull the agitator out and take it with you....goodluck
Jan 04, 2009 | Maytag LAT2300 Top Load Washer
Washing Machines Logo
114 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
