Kenmore 24 in. 16262 Built-in Dishwasher Logo
DAVID EARP Posted on Nov 27, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
KENMORE ULTRA WASH 1626
My clean light is flashing and the washer will not run. If I push the start button nothing will happen. I checked my owners manual and it says there is a problem with the heater circuit. I pulled out the eliment and checked continuity and it was good. This dishwasher is 15 months old.
Anonymous
Level 2:
  • Expert 188 Answers
  • Posted on Feb 20, 2009
Anonymous
Expert
Level 2:
Answers
188
Questions
0
Helped
97531
Points
916
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Kenmore ultra wash dishwasher only half of the lights light up when pressed when press start nothing happens
Do you mean only half of the lights that you push stay on ? If I try to push in too many buttons at the same time, or the cycles I push don't function together, that some of them stay off because they aren't programmed to run at the same time. And the machine is set up to not allow you to expect it to do all the functions during the same cycle.
Jul 19, 2014 • Kenmore 665
2answers
Kenmore Ultra Wash 665 dishwasher: start button not lighing
It sounds like you have a bad control console, and the problem is that your START button (the most critical one!) is bad. You can't replace just that button or key; you have to replace the entire control console.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
2answers
Kenmore Ultra Wash Model 665.1388 problem the normal wash green light is on heated dry light is on and the start resume light is flashing but wont startup helpppp
see your instruction manual and go to the section troubleshooting and fix it.
if you do not have the i.manual download for free www.retrevo.com or www.fitness.manualsonline.com
see the diagram
God bless you
Clean light is blinking, when you shut door and push start cycle nothing happens
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Flashing green ''clean'' light and will not start a wash cycle.
the computer senced that the heater did not work last cycle. Push your sani clean, energy saver button s back and fourth a few times. It will run a self diag cycle. let it run for a few min. If it happens again your heater may have burned out.
1helpful
Kenmore super capacity 3.5 washer won't begin washing
Same thing is happening with mine, what did you do to fix it?
1helpful
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 • Dishwashers
1helpful
2answers
Kenmore Ultra Wash Dishwasher Problem
there is no real way of checking the keypad. Not with a meter but if you push normal wash for example and it does not respond this usually means that you have a bad keypad
18helpful
2answers
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
