Question about Canon imageCLASS MF8170C All-In-One Laser Printer
MF8180C Check paper size error
Someone has pressed print on a page that is obviously the wrong size. Our printer only prints A4. It has printed this one page about 25 times, only to stop, asking us to "check paper size" WHAT DO I DO!! I cannot cancel this job, as it's disappeared from the printing queue on the PC.
For god's sake don't ring canon customer service as they are useless and just keep directing me to their **** driver which is causing the problem. i could not convince them that my "printer properties" "paper available" was locked on "letter" and won't allow me to change it. even when i go to the "printer preferences" page and set everything to a4 and press "apply" it still is locked on "letter" in the "printer properties" page. Iv'e probably wasted about 20 hours on this and my office has nearly ground to a halt. If i knew it was going to be this much bother i could have just bought another brand printer.
Posted on Jul 06, 2010
Blow the damn printer up. I've spent three hours already trying to stop a page printing 40+ times! Doesn't show in the print queue on the PC, nor in the memory of the printer. I've had over 30 printers and this is quite probably the worst I've ever had to suffer. Noisy thing as well!
Posted on Oct 01, 2007
You need to delete the job from the printer memory with the printer keyboard or using the web admin interface. This sucks big time. Canon seems to think it is a feature, not a bug.
Posted on May 09, 2007
SOURCE:
Xerox 7760 Wrong paper size error when trying to print to A4
First your computer selects the printer to output to, so make sure your default printer is selected.
Next, within your printer you may have selected a different page size for output as a default.
The printer it self should allow you to load and auto detect paper size. If this feature is not enabled see if it is a choice.
Also whatever you are trying to print check page setup in the program you are using make sure to ensure they match.
Sep 16, 2016 | Xerox Phaser 7760DN Laser Printer
If i send 10 pages to print I have to press the ready button after the completion of printing of each page. After the first page has been printed, the red light blinking on paper on printer. I then have to...
sounds like your printing to a custom page size in your printer properties in the computer, go into control panel >> printers >> right click your printer >> go to properties Set the page size to A4 or Letter. When you go to print your document, use the printer properties button to make sure your page size remains at A4 or Letter. I think the printer may be asking you to insert your custom page size, and then waiting for the "Go" button to print, next page . repeat. (kinda like if you were inserting envelopes or greeting cards), Also check that your page setup in your word /office software is set to letter, as this would cause the same result.
Aug 29, 2010 | Brother HL-2040 Laser Printer
Hello sir, how to take print on A4 page? please help me
Hi The A4 paper size is an internationally used paper format. Although not often used in America, it is by far the most commonly and widely circulated paper size. At 8 1/4 inches by 11 3/4 inches, it is similar though not quite identical to the American standard U.S. letter size, which is 8 1/2 inches by 11 inches. Because of its ubiquity, all printers and programs have the ability to handle the size, and getting a printer to print to it is a matter of adjusting the settings.Put the A4 sized paper into the automatic feeder in the printer. You may have to adjust the tray guides to fit the paper in snugly. Close the tray firmly when finished.
  • Step 2.Set the printer to register the A4 sized paper inside the the tray. This varies from printer to printer but generally involves going into the print menu, scrolling to the automatic feeder and designating the tray as an A4 tray.Step 3.Select "File" and then "Page setup" in the program you are using.Step 4.lick on the drop down menumag-glass_10x10.gif next to paper size and choose "A4.Step 5.Select "File" and then "Print." Click the "Print Summary" button to ensure the file is set to print to the A4 size.
  • Step 6.Press "Print" to print the photograph.
  • Jul 31, 2010 | Toshiba e-Studio163 Copier
    Error Message: load the correct paper cassette: A4
    check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
    Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
    I HAVE A PANASONIC WORKIO 8020, IT SAYS BYPASS A4- HOW DO I FIX THIS?
    The computer has sent a A4 size document to the printer and the printer is asking you to put a A4 size piece of paper in the bypass tray so it can print it. It may be an email A4 size that someone has sent you or check the settings in Microsoft Word print or page setup to see if it is set for Letter size, not A4 size.
    Dec 01, 2009 | Panasonic Office Equipment & Supplies
    HP 4L when printing an internet page, print size is for
    Under print preferences set the paper size to A4.
    Start > Printers and Faxes > (Right-click printer and select properties) > (select printing preferences) > (set paper size)
    Aug 25, 2009 | HP LaserJet 4 plus Printer
    OKI 24DX - Press ONLINE button to print each page
    you have to open your printer icon in CONTROL PANEL
    CONTROL PANEL
    THEN
    PRINTERS AND FAXES
    RIGHT CLICK ON YOUR OKI PRINTER
    select PREFERENCES
    under SET UP and MEDIA size change it to A4
    I think this might help you. I'm guessing that you have the wrong size paper selected. And each time the computer needs you to confirm you want to print with a different size paper
    I wouldn't phone OKI help line..I was on hold for 15 minutes, then just gave up.
    Jul 01, 2009 | OKIPAGE 24 Led Printer
    I am using a HP Laserjet 4 plus. I got a flashing "PC" and "Load A4" on the screen and could not print. Pleas help.
    Clear the Print Que in the PC, turn off and unplug the machine, turn it back on.. send a test print from the driver.
    A4 is european paper size, your printer is set for letter, someone attmepted to print an A4 file. Which is in the page set up in what ever file was to be printed.
    Next Time Please be specific?
    Sep 11, 2008 | HP LaserJet 4 plus Printer
    Printing from wrong tray
    Go to printers and faxes and right click and properties on your printer!! Then select Advance, then Printing defaults!! In there select paper size A4 format. And in Word go to File, Page setup and select page size A4!
    Jan 24, 2008 | Office Equipment & Supplies
    Have canon mf5700 says check paper size and only prints one page of several page job
    go to control panel> printers> and make sure in preferences its set to LTR (letter)
    Hope this helps
    Dec 21, 2007 | Office Equipment & Supplies
    Canon imageCLASS MF8170C All-In-One Laser Printer Logo
    1,094 people viewed this question
    Clive
    Clive
    old marine
    old marine
