Question about Ovens
Frigdaire wall oven fault code 3
Thanks for your help, where is the temp sensor located?
  • 116 Answers
The temp witch is at the back of the oven when you look inside. At first glance It looks like around piece of metal sticking out of the back of the oven. sually secured with two stainless steel screws. For the stand alone the connections are is usually accessed from the back after taking off the back panel.
Disconnect power from the stove before opening the back
Regards
Posted on Nov 16, 2008
F 3 comes on when I press the oven temp or boil button. We have already change the sensor
This fault is a bad or open sensor to the oven, the control unit can't see the oven temperature and won't run it if it can't control it.
I hope this helps
Nov 28, 2013 | Maytag 27" Built-In Double Electric Wall...
I'm getting fault code f2 reading, do I need to replace the oven temperature sensor or relay board? what part number is this and where is it.
Hi
Thanks for using FixYa. Error F2 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
Got error code f-10 how do i fix this
Hello, the f-10 error code is a oven temp sensor failure notice. you will need to check the wires leading from the temp sensor to the control. if the wires are in good condition and , the sensor harness is not welded, replace the temp sensor asap.
Thanks
Jun 11, 2010 | Frigidaire 24" Built-In Single Gas Wall...
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
F4 error message
HI. This is a failed oven temperature sensor error code. Simply replace the temp sensor, asap. This will clear the code. The temp sensors are generally located inside the oven, mounted on the back wall, in the top left or right corner.
It will look like a 4 inch slim probe.
F4 failed temp sensor.
Dec 29, 2009 | Jenn-Air JJW8230D Electric Double Oven
Flashes f-3
you have a bad oven temp sensor probe
Jun 19, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Frigdaire elite oven
this is a fault most often related to the temperature sensor. the connections to it may be bad but it is most likely a bad temperature sensor
Nov 14, 2008 | Ovens
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Gas oven temp problem
HI thanks for your question. there is a oven sensor , located in the oven, top left corner. replace this part. thanks the appliance doc. please rate my answer. thanks
Oct 11, 2008 | Frigidaire Ovens
Oven showing F2 fault
tire, if your model starts with 911. the code stands for an overtemperature condition. I would start with the temp sensor, this is the probe inside the oven cavity, part # 334300. You can ohm it out, should be around 1100 ohms at room temp. This is for model number starting with 911. Catriver..post back.
Apr 21, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
56 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
