Question about Buffalo Technology AirStation WBR2-G54S (747464109220) Router
''DIAG'' red LED stays on all the time
After the power is turned on, the "DIAG" red LED does not go out. The AOSS LED is always on. The WAN and and all four port LEDs comes on and off simultaneously about every 15 seconds. The router is not connected to any PC or the broadband modem.
4 Suggested Answers
  • 7 Answers
SOURCE: Belkin 5D3230-4 not working at all
Try and update your firmware on router,and see if that helps, you can go to belkin website to do that, look up your router and download firmware, call belkin they will help u install it
Posted on Feb 06, 2008
SOURCE: pc link
there is reset button on the bottom of the router .... hold it unless a red light (dont know what its called) on the front led panel appears
Posted on Aug 04, 2008
SOURCE: No access through D-Link DIR635 - Modem speedstream 4100
Hi! try to reset the router for 10secs that is located at the back of the router..then connect your computer directly to the router and pull up the browser and type in at the url:192.168.0.1, it will ask u the username and password, username by default is admin and the pass, just leave it blank, then it will show the setup page of the router..try to check this first in order for you to setup the router so that it will talk to the modem: if u bypass the router it will work, the reason why the modem wont talk to the router bcoz the router is not properly setup.. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Posted on Aug 09, 2009
Back light cutting out, red light flashing on front
Hi, Mister,
Two things, first check if the power supply of the tv is in good order, second, has to be your inverter, this is the circuit of the backlight. Thank,s good Luck.
Serge.
May 06, 2016 | Panasonic 65" Class 64-1/2" Diag. - LED -...
Samsung 75 smart tv , is power on or off when red light is on ????
Red light means that the unit is in standby mode, It has power but is not turned on.
Jul 24, 2015 | Samsung New 75"" Class 74.54"" Diag. LED...
SMCWGBR14 N only power led
Resolutions:
1) Power on the SMC modem / router and wait until all the lights are light up.
2) Press and hold the reset button for 15 seconds and wait until all the lights are light up as the modem / router needs to reboot.
3) Try to access to the admin page again by default login IP - http://192.168.2.1/.
4) Enter the default login password.
a) smcadmin
b) (blank)
c) barricade
Nov 25, 2013 | Edge Barricade 4 Port Broadband Wireless...
I have a Dell Dimension 3000. Worked fine until we went to turn it on one day and the monitor stayed black. I'm assuming it's the video card that's the problem. I need to know what card is compatible. ...
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
The links in that article will allow you to determine where the failure is on you system (The power LED indications and the Diag LED indications on the back of the system)
Post back with the indications of the POWER and DIAG LEDs on the tower if you need more detailed instructions.
Feb 12, 2011 | Dell Dimension 3000 PC Desktop
I have RV082 Router , and Diag Led is constant what to do
Checking the Router's LEDs
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router.
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router, the following should be lit:
  • 1 - 8 (LAN)
  • DMZ/Internet (WAN2)
  • Internet (WAN1)
  • Diag
  • System
Step 1:
Make sure the System LED is lit.
NOTE: If the Diag LED doesn't goes off, you need to upgrade the router's firmware. For instructions, click here .
Step 2:
Make sure the LAN 1-8 ports is lit depending on the computers connected to the designated Ethernet port.
NOTE: If the LAN 1-8 port is not lit, make sure that the computer is powered on. You can also try connecting the PC using another working cable.
Step 3:
Make sure the Internet (WAN1) and DMZ/Internet (WAN2) LED is lit.
NOTE: If the Internet or DMZ/Internet LED is not lit make sure the Broadband modem is powered on and that the modem is properly connected to the Ethernet port
You can access the web-based user interface utility of the RV082 by using one of two methods:
  • Through the RV082 IP address (192.168.1.1 by default), or
  • Through its default hostname ("RV082")
1. Open a web browser (Internet Explorer or Netscape Navigator)
· By IP address: Type http://192.168.1.1 (192.168.1.1 is the default IP address of the RV082)
and click Go or press the [Enter] key.
· By Hostname: Type http://RV082 and click Go or press the [Enter] key.
2. When the username and password prompt appears, type admin in both the username and password fields. (admin is both the default username and default password for the RV082).
Nov 08, 2010 | Linksys RV082 Router (RV082-AU)
Power light is on and doesnt blink, Link light is solid green and there's a red light on the "diag". when I try to plug a Lan cable into the router I get no up link. My friend ask me to take a look at the...
You said there is a diag light lit up on the router.
In that case you can try to reset the rotuer for 30seconds . unplug the power and plug it back in. wait for a minute.
Check the lights on the rotuer. If you still see the diag light then try to reset the rotuer again. If there is a diag light on the router then the rotuer is not working.
Try to reset the rotuer for 2 - 3 times . power cycle the router till you get no diag light.
Once the diag light is gone then reconfigure the router.
Connect the modem to WAN port and computer to one of the 4 ports. Do not conenct anything to the uplink port.
Reconfigure the router.
Click Here to know more about how to set up router
Nov 19, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Wan diag light stays red - is router bad?
Did you try a hard reset:
. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
if the power led stays red, you need a new router.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 18, 2009 | Linksys EtherFast Cable/DSL Router
Power PC G5 Dual 2.5 sudden shutdown and no reboot
In G5 always the cover should be closed properly if not it will start the fan very fast like a blower and the red leds will be on showing that the heat is over so please check that the cover is closed and locked from behind so itworks smooth and the power supply is standard or normal
u should always use genune parts with mac..
thanks
Dec 19, 2008 | Apple Power Mac G5 Desktop
Diag led
wat about the powerlight in the router....
Oct 24, 2007 | Linksys Wireless-G WRT54G Router
Buffalo Technology AirStation WBR2-G54S (747464109220) Router Logo
177 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Sulkhan Abesadze
Sulkhan Abesadze
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
