Toshiba satellite a100 wont take on power or boot
Hi, my computer has a habit of working some days and not others. There seems to be a pettern in that when using the laptop on battery alone it wont recharge using the AC adapter nor will it run on a second fully charged battery.... just to clarify (for my benefit) I'm using the laptop plugged in to the AC, if I disconnect the AC or turn off the computer it wont reboot. If I leave it on just the batter and it runs out it wont take the AC. If I remove the battery and get it going on just the AC its fine till I turn it off then it wont reboot again. This usually last for around 24 hours then it seems to take the AC again.
I have swapped AC power packs, purchased new a battery but its still the same problem happens. Anyone have an answer or like problem?
Jim
  • James O'Sullivan
    James O'Sullivan Nov 16, 2008
    The battery does charge when the computer chooses to accept the AC... if I pull out the AC however then it wont accept iot again and as such the battery runs out till the laptop stops again.... 24 odd hours later it accepts the AC and charges the battery again. The short solution has been to simply leave the laptop on.
  • omar_gamal Jan 04, 2009
    I have a toshiba laptop, and in the last few weeks something weird started happening. When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries, and the battery level drops by about 1% every few hours, but it never turns off, meaning it is recieving power from the AC. But the LED displays show nothing lit except the power icon and HDD icon. The AC, and Full/Charging battery lights do not seem to light up at all.
    Now my battery has completely died, and i decided to just run the laptop on AC power and remove the battery pack. When i shut down last night and tried to turn on this morning it gives me the low battery indicator (flashing yellow light) even though the laptop is plugged into the AC. I got a fully charged battery pack and plugged it into the laptop and still it gives me the same low battery indication and will not turn on.
    This is very frustrating and I would greatly appreciate some advice on how to fix this problem ASAP.
For this latop alwats faulty wirh power ic can use trick plug in and out some times, then laptop ok works, but not charge battery
Posted on Aug 24, 2012
The battry is not charging and check the model of the battry whether its the same
Posted on Nov 16, 2008
2 Suggested Answers
  • 237 Answers
SOURCE: Toshiba satelite A100 rejects AC... often.
Just to humor me, are you using any peripherals with your laptop when this happens, such as a wireless mouse, USB connections such as digital cameras? Try to take these away when recharging.
There seems to be 2 issues here.
1) Recharing batteries: To prepare the batteries for long-term use (I do not know how long you've had the batteries...try draining the batteries (both of them), and then recharging it to full 2x before using them without the AC Adapter. This should clear the problem.
2) AC Adapter only works every other day: When you swapped the power pack, was it with a new AC adapter, or another used one? Also, have you tried using a different outlet than the one you normally use? Let me know how this turns out.
Posted on Nov 17, 2008
1720 s.m.a.r.t HDD detects imminent failure the computer cant boot-up.
if you haven't got a good back up, external to the hard drive, it may be too late
dead hard drives are mostly un recoverable
take it to a computer repair shop to make sure that it is not a boot problem
if the hard drive is failing, replace it with a solid state hard drive that has no spinning discs to fail
Jan 13, 2017 | Computers & Internet
Satellite S50-B-15P Hi I want to find out what type of SSD drive is installed in my laptop. I want to up-grade to higher capacity. Thanks
Download SiSoft Sandra. It will tell you exactly what you have and also test every component. The best program by far and has been since Windows 98.
http://www.sisoftware.net/
Jan 11, 2017 | Computers & Internet
Will not start up
hi , Reuben
I would suggest you try safe mode.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
Follow the steps to boot the computer in safe mode with networking:
1. Restart your computer if it is powered on.
2. Tap the F8 key after your computer initially powers on.
3. Once you see the Advanced Boot Options menu you can stop tapping.
4. Use the up/down arrow keys to highlight your selection.
5. Select Safe Mode with Networking and press Enter.
6. You should see drivers loading, and then please wait.
7. You should then be at the Welcome Screen.
8. Logon to your computer using an account with Administrator privileges.
May 27, 2015 | Computers & Internet
Toshiba Satellite A665 S6067 laptop wont recognize my SeaGate FreeAgent Go 500 Gb. device
I had a similar problem and I had to "Delete Volume" when in DIsk Management. I then had a choice to "Create Simple Volume" which I did, and then a wizard created the correct partitions and assigned a drive letter to my external drive. Everything was them OK.
Mar 21, 2014 | Computers & Internet
I can't hook my monitor up to my pc I have a dell optiplex gx620 Sff
On the back of your PC there is a blue 15 pin video connection. Connect your monitor to this video connector, power up your monitor the boot up your PC.
Mar 23, 2013 | Computers & Internet
HOW TO ENABLE BLUETOOTH IN THIS NOTEPAD ?
The Acer Aspire is a high-performance laptop that includes a fast processor, widescreen display and an internal wireless card. In addition to these premium features, certain models also include one-touch Bluetooth access. If you have an Acer, enabling the Bluetooth is very easy and will only take a few seconds.
1.Turn on your computer and wait for Windows to fully boot. Then log in as an administrator. You will not be able to use Bluetooth under a non-administrator account.
2.Press the button with the Bluetooth symbol on the left side of the computer. This will launch the Bluetooth utility. From here you can sync and manage Bluetooth peripherals.
3.Press the Bluetooth button again to disable Bluetooth. This will disable all connections, but the utility will save your settings so the same devices will sync with the computer again when Bluetooth is re-enabled.
I hope you may find it very helpful.
Aug 25, 2011 | Acer Aspire One PC Notebook
How do i reset my computer to an earlier date?
Most computers have a RTC or "real time clock" in the BIOS. BIOS (or "Basic Input Output System") controls how data gets into and out from the processor (via keyboard, disk, etc.). Be careful making changes. The BIOS is normally only accessable when the computer is powered on or reset, and then only while performing the POST (or "Power On Self Test"). At this time your screen may display text describing memory, drives, controllers, etc. Some machine have a "silent boot" enabled which displays a manufacturer's graphic or logo instead of this data. It is during this time the the BIOS may be accessed. Depending on the manufacturer of your computer, a key (Delete, Escape, F1 or some other) or key combination (ALT + F1, ALT + S, or some other) will be needed. It is required to press the key or key combination prior to the Operating System loading message(s). This can be done be repeatedly pressing the key (or key combination) once every second (or two) during the POST. Holding the key(s) down the entire time - or pressing them too often will result in an error, and require starting over again.
Once the BIOS screen is presented, you will have to scroll the entire page(s) to find the clock. Most BIOS brands have more than just a single page of settings. Using the the up, down, left, right, PgUp, PgDn & Enter keys - navigate to the clock hours and minutes and adjust as needed. Make sure that you SAVE changes before exiting the BIOS screen. Upon exit, the computer will reboot with your settings.
Your Operating System may also provide a way for you to change the system time (and date) as well. Try clicking on the time / date to see if it will bring up a dialog box that allows you to make the change.
I hope this helps and good luck! If my answer was helpful, please rate it "4 thumbs up" Thanks!
Jul 27, 2011 | Computers & Internet
Freezes on the warm boot screen MC9000
This can be for a number of reasons.
First thing would be to try and cold boot the device:-
Remove battery half way, hold power button and trigger, push battery in fully until click and then release power and trigger
If that fails next thing would be to try and re-flash the operating system. This is done by using an SD card and loading the latest operating files onto it. The SD card slot is located under the keypad. A cross head screwdriver is required to remove the keypad. Search on symbol software download site for the latest. The download also has a readme with detailed instructions. Once the files are on perform a cold boot.
Remove battery half way, hold power button and trigger, push battery in fully until click and then release power and trigger. Drop the terminal in a cradle so that it runs on external power.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Dec 09, 2009 | Symbol MC9000-G Portable Terminal
How do I start bluetooth on the qosmio g25-av13?
Try the ff:
1. Are you also using a wireless internet? If you are and you cannot also connect on wireless, make sure that the wireless is enabled on your laptop. On the left side of the laptop there is a on/off switch push the switch to on. (beside the usb port).
2. if it is already on, make sure that the bluetooth is enabled also, you can check it on control panel, system, hardware, device manager, bluetooth, right click on bluetooth driver, if you see enable bluetooth click on it, if you see"disable bluetooth" that means it is already enabled.
3. If the above is already configured, lastly, look for the bluetooth icon (bluetooth manager) on the lower part of the screen on the taskbar/tray if you see the bluetooth icon, right-click on it then click "Enable Bluetooth Radio". Now, if there is no bluetooth icon on the tray at the lower right of the screen, go to Start, Toshiba, Bluetooth, Bluetooth Settings, inside the Bluetooth SEttings, click on Bluetooth, Options, CLick on Enable Bluetooth Power, also, inside the Tray Icon (still inside Bluetooth Settings) select an icon so you can always see the status of your bluetooth on the Tray and you don;t need to do and check everything everytime you cannot connect via Bluetooth.
Hope this helps.
Tricia
Aug 19, 2008 | Toshiba Qosmio G25-AV513 Notebook
I have doctor antivirus pop ups
Unfortunately, the only way I've found to be completely rid a machine of this is to wipe the hard drive and reload the operating system. This is an advertisement virus and this particular bug leaves several sleepers that lie inactive making it near impossible for any antivirus to find them. Once you get rid of the active virus, one or two, but not all of the sleepers will activate leaving several more hidden and inactive, and what makes it even harder to "get rid of" is that it hides the sleepers in file that your antivirus normally doesn't check on a regular basis, ie... picture files, music, screen savers, etc.. It will also hide them in registry files, so doing a system repair won't work either.
Jul 07, 2008 | Toshiba Satellite P105-S6104 Notebook
Computers & Internet Logo
1,494 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
