Question about Yamaha DSP-A1000 5-Channel Amplifier
5. chanel and stereo sp.B at the same time
How can i play on yamaha 361 amp. the seroundsound on sp. A and stereo on Sp. B in the same time and seperate?
  • 151 Answers
The yam 361 can not play A and B speakers at the same time you need to buy a switch box so you can select one pair or two pairs of speakers.
Hope this helps.
CABLE GUY.
Posted on Nov 16, 2008
Front speakers won't work simultaneously with the rest of my 5.1 system
This is an either-or situation. As your manual explains, SP-A is one set of speakers and SP-B is another separate set. Your Yamaha receiver should have an SP-A + SP-B setting but given the way your speakers are currently configured it's anybody's guess as to what the result will be.
Dec 15, 2013 | Yamaha Rx-v365 A/V Home Theater Receiver
2000 Yamaha XJR 1300 SP remove front wheel
Hi, Gtcallister for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Motorcycle Front Wheel Removal and Install
Yamaha XJR 1300 SP 2000
Yamaha XJR1300 99 Service Manual
OEM parts for Yamaha
YAMAHA XJR1300 Owner Manual
Sep 15, 2009 | 2000 Yamaha XJR 1300 SP
What are the differences in the record modes? (HQ, SP, & LP)
The amount of recording time on a disc depends on the recording mode selected. The approximate recording time for each of these modes is listed below:
  • HQ (High Quality): Recordable time is up to 20 minutes.
  • SP (Standard Play): Recordable time is up to 30 minutes.
  • LP (Long Play): Recordable time is up to 60 minutes.
  • NOTE: If you record in LP mode, the quality of the scenes may be degraded, or scenes with quick movement may appear with a block noise when you play back the disc.
    Jul 08, 2009 | Sony Handycam DCR-DVD92 DVD Camcorder
    My Yamaha HTR-6050 shuts off at random times and says "Check SP Cable"
    i think it means speaker cable?
    http://www.fixya.com/search/p514076-yamaha_rx_v2700_7_1_channels_receiver/check_sp_cable
    Apr 23, 2009 | Yamaha RX-V757 Receiver
    Yamaha 5.1 says Check SP Cable and shuts down - has been fine.
    It has nothing to do with the input you choose. A speaker wire is shorted. Disconnect each one in turn and try it. The last one disconnected before it stops failing is the one.
    Mar 22, 2009 | Yamaha HTR-6030 Receiver
    I need a wiring diagram for a stock radio
    this info comes from 12volt.com :
    RADIO 12V = yellow
    RADIO SWITCH = purple
    RADIO ILLUMINATE = red/white
    POWER ANTENNA = green/white
    LF SPEAKER = (+)blu/wht (-) blu/yel
    RF SPEAKER = (+)brown (-) brn/wht
    LR SPEAKER = (+)lt. grn (-) blk/yel
    RR SPEAKER = (+)blue (-)pink
    this info comes from alldata :
    LH FR SP (-) GRN/YEL
    LH FR SP (+) PPL
    RH FR SP (-) BRN/WHT
    RH FR SP (+) BRN
    BATTERY BLUE
    ILLUM CONTROL RED/YEL
    LIGHTING YEL/RED
    ACC PINK
    AMP BLU/WHT
    LH RR SP (-) BLK/PNK
    LH RR SP (+) ORG
    RH RR SP (-) GRY/RED
    RH RR SP (+)GRY
    Omega and alldata match , i expect the second set to match .
    obviously only one of these color codes match your radio , which ever one matches , is the one . cheers
    Jan 10, 2009 | 2000 Nissan Sentra
    Problem with Yamaha Amplifier 361
    volume levels on all channels varies depending on what dsp mode you are using. to be able to determine the level you desire, just chnge the level setting of those channels. either you do it by remote control or the front panel of the amp. try setting the dsp mode on disco and you should hear higher vol levels on all channels. Do not expect as well all channels to produce same vol levels as your effects speakers may not be able handle higher power levels.
    Aug 12, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
    That is a check the speaker wire error, caused by a short or perceived short. If you look at the back of the receiver you may see 1 strand of the wire loose, they are very hard to see sometimes. You may use banana plugs as it is painful to get everything hooked up without a few loose strands.
    If there is still the issue check your speaker connections for the same issue. If they are in ceiling/wall speakers disconnect them all then plug them in one at a time to narrow it down.
    If the issue persists perhaps one of your speaker wires has a short somewhere, could be a misplaced drywall screw from hanging a picture, or a carpet tack strip, or a pet deciding it was a nice chew toy.
    If you are completely sure it is none of those then I would say it is a bad speaker or receiver. Try changing in and out known good speakers/receivers if you have access to them to see which one it is.
    Good luck
    Feb 03, 2008 | Yamaha HTR-6030 Receiver
    Yamaha Receiver RX-V630 not working (resets itself immediately)
    This maybe an easy one. Have you unhooked all the wires going in to the stereo. "SP wires" means you have wires to the speakers are touching and the stereo is shutting down to avoid overloading. Hope this helps...
    Jun 05, 2007 | Yamaha RX-V630 Receiver
    Yamaha DSP-A1000 5-Channel Amplifier Logo
    91 people viewed this question
    Top Yamaha Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
