Question about Maytag Atlantis MAV7551 Top Load Washer
Maytag Top Load Washer # MAV6057AWW
My washer is (sometimes) not moving properly from the wash to the drain/rinse cycle. It makes a laboring sound and sometimes doesn't spin. If I open it and move the tub from side to side a few times, then close it, sometimes it will then proceed on it's own. My (very handy) husband looked underneath it and found the screws around the belt. He said one was loose and tried to tighten it, but it wouldn't tighten. He thinks if he could open the machine up, he could access the screw from above, but the screws to open the front of the machine seem to be inaccesssible. Any ideas/help would be great.
I have the maytag MAV6057AWW. I had the same problem and today i am discovering that others are having the same problem i was. It first started with the no agitation after the rinse cycle. I emptied out the water and clothes etc. I lifted it, took it apart practically and discovered all was ok. I couldnt figure it out because after putting it back together it worked properly. After a few days it didnt agitate for the wash cycle after filling up with water. I was confused. But then I got pissed of and I slammed the lid shut and it began to work.
It was the switch. I havent replaced the switch, but i have learned to cope with the fact that i have to open and close the lid a 2 or 3 times times before it goes into the cycle.
When it doesn't agitate, its not a mechanical problem, but a safety switch that is failing to close. So either replace your switch or play with the lid a bit.
Posted on Jan 16, 2008
I have a Maytag model #MAV6057AWW and I believe the lid switch has failed. I have removed the lid switch but I have no way of knowing if the switch is indeed bad and do not own any type of continuity tester but was wanting to use jumper wires on the plug from the wiring harness to the switch to bypass the switch. There are four labeled contact: Neutral; Line; Motor; Machine, on the switch contact (male side of plug). What would I jump on the corresponding side of the female side of (wiring harness) to safely bypass this switch.
The reason I believe it is the lid switch is because the machine failed to operate immediately after the lid being dropped closed.
Posted on Jan 13, 2008
    Problem Solver:
  • 6 Answers
Open the top of the unit (including lid) by pushing a butter knife into the slots near the top right and left corners. Once the spring clips release, just lift the front of the top panel. There should be two screws attaching the front panel to the sides near the top. Remove these and lift up the front panel. However, the problem is probably a rusted spin bearing and the repair on that is costly and difficult. Buy another one, different brand maybe.
Posted on Mar 05, 2007
Maytag mav6057aww makes loud noise while spinning
Is it a scraping sound or more of a rumbling sound? If it's scraping check for screws, nails, necklaces, etc., in the drain holes of the basket. If rumbling sound your tub bearings may be failing.
Jan 07, 2013 | Maytag Atlantis MAV6000 Top Load Washer
My MayTag Atlantis washer will not spin or drain the water out, when it gets to the rinse cycle or spin cycle , it just makes a buzzing or clicking noise.
The brake mechanism is not releasing properly. The noise your hearing is the motor trying to move but can't. Do not continue to operate the washer or you will burn out the motor...an expensive replacement. See instructions for my other solutions.
Sep 23, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Wont spin
Sounds like the transmission seal had failed sometime back and has leaked the lubricant causing the transmission to overheat and now possibly seizing the gears, if this is the case the transmission will have to be replaced. Depending on the age of the washer, (5 years or less) you should contact Maytag to see if they will compensate you by way of furnishing the new transmission for free, but you will be responseable for the labor charge from a tech to do the replacement.
If they will not cover the part, you will probably be better off to replace the washer than to invest in the cost of a new trans and labor.
Good Luck !
Mar 21, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Agitator on maytag sav2555aww won't spin, loud clicking noise
I just replaced the trans in my maytag.if the washer is less than 5 years old trans is covered under warranty. but here is the kicker, labor and thrush bearing is not. trans cost is about 300.00 and labor is about the same. a new washer is about 450.00 So if you know someone who can do trans.[like for free] if not buy a new one. Good Luck
May 21, 2009 | Maytag SAV2655A Top Load Washer
Incomplete wash cycle.
It sounds as if you have something acting as a flap causing the restriction. You should take the hose that leads from the tub to the pump off and see if there is anything just inside the tub. I have noticed that alot times you could have a coin that blocks the opening. You may have to remove the inner tub to remove anything in there
Dec 30, 2008 | Maytag SAV3655A Top Load Washer
Top Loading Maytag washer will not rinse/drain and spin.
you may have a locked up pump causing the motor to not run, check to see if you can turn the belts under the unit, if so then you might have a timer with a burnt contact.
hope its the pump as it is cheaper then the timer to replace.
Nov 02, 2008 | Maytag Atlantis MAV7551 Top Load Washer
Maytag Atlantis MAV7551 Top Load Washer Logo
1,497 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
