Kenmore 43142 Front Load Washer Logo
Posted on Aug 01, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore washer weak agitate even at fast load and no spin
I have a kenmore 90 elite only 8 years old When I select any speed, the agitator goes very slowly, weak movement to left and right , and has humming noise when fast speed is selected so cannot use the washing machine . Also the washer does not spin at spin cycle. I took the back panel off and noted a kink in a belt just above the pump. Could that be the problem? Thanks if you can help with this condition
  • Anonymous Dec 14, 2008
    when it is the final spin does not spin fast. and make noise.
Frank Antonowitz
Level 2:
New Friend:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Expert 47 Answers
  • Posted on Aug 01, 2017
Frank Antonowitz
Expert
Level 2:
New Friend:
Teacher:
Answers
47
Questions
0
Helped
6226
Points
137
It could need a new belt. If there is damage on the belt it may also be dirty or stretched and thereby slipping and not giving you it's best performance.
5 Related Answers
Anonymous
  • Posted on Dec 30, 2008
SOURCE: kenmore elite won't agitate properly
Does the bottom of your agitator work correctly? We had the same problem if you pop the cap off the top of your agitator there is a cam in there with 3 dogs that engage the agitator causing it to spin. If the bottom part is agitating correctly then chances are the dogs in the cam assembly are shot. If the bottom is agitating correctly then it is very possible you have something stuck under the bottom section of the agitator. If this is the case remove the top cover (same as before it's just a lid that pops off) inside you will see a 1/2" square use a 1/2" drive ratchet with a 3" or 6" extension unscrew this piece remove the top section of the agitator then the bottom. Once the bottom is out check to make sure all is clear inside the washer. Reassemble in the reverse order making sure the lower section sits all the way down on the splines for the drive mechanism. If neither one of those solve the problem I would suspect you have an issue in the drive train of the washer.
Anonymous
  • 262 Answers
  • Posted on Jan 11, 2009
SOURCE: Remove agitator on Kenmore 90 series
ok take the top off the agitator there is a cap carefully remove this cap and then some have a inner cap with a handle remove that also in side the agitator it has a 1/2" or 7/16" head bolt remove the bolt and then pull up really ******* the agitator. to replace dogs you have to break the taps holding them in not the agitator be careful
Anonymous
  • 11896 Answers
  • Posted on Jan 28, 2009
SOURCE: Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
onthejob5130
onthethejob1
  • 640 Answers
  • Posted on Feb 01, 2009
SOURCE: kenmore 90 washing machine does not spin or agitate
make sure your pump is not clogged or jammed..that will stop the motor,,quick test,,pull pump off and start unit in wash,,or spin if unit is empty..onthejob
ned_san_jose
Ned Halaweh
  • 240 Answers
  • Posted on Jul 16, 2009
SOURCE: Kenmore 90 Series fills with water but would not agitate or spin
You have a problem with the motor coupling. Top-load washers use what's called a direct-drive system, meaning it does not use a belt but what's called a "motor coupling". I probably replace 5 a week because these little guys break because of 2 reasons that i've found.
1) The break mechanism is too dry and causing the basket to stop at a holt, which puts a lot of strain on the coupler.
2) They break because of over-loading. I don't think you're over-loading though because it was find for 5 straight years.
Good luck to you. The repair is kind of hard to do on your own for the first time, so I would call an authorized technician. It will run you anywhere between $90 to $120 at most.
Best of luck!
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
Kenmore 90 weak spin and agitation, good coupler,
go to www.searspartsdirect.com put in you model number and you can pull up a explode view of the transmission.
1helpful
Agitator on my washer is loose
Replace the agitator dogs in the top part of the agitator. Parts are about $7.00.
2helpful
Best of luck!
1helpful
Kenmore Washer Grinding Sound - No spin or agitation
sounds as if oyou have a bad motor coupling, you can search you tube for keywords, whirlpool motor coupling, far easier to watch someone perform the repain that try to explain it, easy to do!!! part number 285753
2answers
Washer does not spin and drain water. (Kenmore Elite Heavy Duty)
it seems to me ur washer transmission is going out or already there
Kenmore 80 series washer
Your transmission is not engaging thats why the speed changes your making will sometimes get it to work.Honestly any machine after the 10 year age mark is not worth the cost of replacing the transmission.
Alexander
vince
