Question about Kenmore Elite HE4 Electric Dryer
Drum light goes on and off kenmore elite oasis dryer
I have a kenmore elite oasis dryer. it is about 2 and half years old. it works fine, but my drum light goes on and off and continuously beeps everytime
  • gretchenf Jan 05, 2009
    I have the same problem. It works fine, but the drum light going on and off every few minutes or even seconds is starting to drive me crazy. Did you find a fix for this?
  • 116 Answers
Repl user interface ,, it has a stuck button,, order inter face
Posted on Nov 30, 2008
SOURCE:
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore Elite Oasis 6806 Electric dryer with burning smell
you must disassemble the unit and clean the lint out of the heating unit area, it is lint catching fire and could be dangerous to continue using your unit in this condition. a vacuum cleaner should do well to clean the lint and the drum must be removed to do a proper cleaning
Apr 15, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Hi, I have a Kenmore Elite dryer model 110.76962501. It was working fine earlier in the day. Now when I turn it on, it makes a humming, whirring sound. The drum is still rotating. Any suggestions?
Hi etzelmueller...
I think you have a drum roller problem or a felt seal problem on your dryer to cause the noise you describe..
Please take time to rate me.
Sep 18, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
When my washer is on the spin cycle it goes out of balence shuts down no matter wht size load or how i arange the load never completes the spin cycle this is a kenmore elite oasis 5 years old. #2 problem...
as for the washer there maybe a broken spring or where the spring attaches that balances the drum. look for this firest. for the dryer is it spinning around at the right speed if it is then the belt is ok. is it hot inside the dryer after running it when you open the door. if ti is check the dryer vent hose and exterior door at end of hose to see it they are plugged up . if the hose is plugged up the heat and moisture can't excape and the clothes will take a long time to dry.
Sep 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Can I use a 3 prong dryer cord on the Kenmore Elite Oasis dryer?
Most dyers are 220V. If the chord is connected to three terminals as most dyers have, then it would work just fine. Just be sure you connect the ground wire correctly.
Apr 08, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore elite oasis dryer quiet pak 2 making loud screeching noises-
Either your glide pads that the front of the drum rides on are worn out, or the rear drum bearing are worn out
Mar 24, 2011 | Kenmore Dryers
The dryer squeeks when I turn it on. It will be three years old in November 2009.
Remove drum by lifting rear ball out of the socket. Use high temperature grease in the socket, that should fix it.
Thanks for contacting Fixya.
Sep 18, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My 18 month old kenmore elite oasis quiet pak 2 gas dryer smells as if there were a fire in it!!!!  and ironically, when i noticed the smell i also saw water around the base of the kenmore elite oasis top...
Hello plz make sure the gas burner does not have any lint build up on burner assembly inside the machine / plz clean.That usually causes a burnt smell. If there is no error codes on the display and the machines is operating fine you are chasing a ghost. If there is a pump or motor over load an error code should come up on the display.
Dec 11, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
338 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
