Question about E-Machines eMachines Desktop PC
W3052 E-Machine shuts down
The computer runs fine for some time but then shuts itself down and has like a long beep followed by a shorter beep of lower tone. or according to the girlfriend "a real slow "busy" signal"
any suggestions?
    Genius:
  • E-Machines Master
  • 1,252 Answers
Take the RAM out of its slot then put it again, also if you have an PCI device on your motherboard check whether they are inserted properly or not, try this one
Posted on Nov 16, 2008
  • redfish2112 Feb 26, 2011
    My Emachines w3052 would shut down and beep. I pulled out the old PCI modem and it works fine now. I cant say if putting another PCI card in there would effect it that way again, but I will avoid that slot.
Computer shuts down on its own. First it starting
Could be HArd disk drive issue or Windows OS issue, try repair windows operating system before you change your hard disk drive , good luck
Aug 07, 2013 | Computers & Internet
Flat panel TV comes on by it's self
It sounds that the voltage output from its internal power regulator board is not proper. Check it.
Feb 04, 2013 | Samsung UN19D4003 TV
I don't know my computer shuts down automatically.
In order to advance on the resolution path, could you please check the following :
This problem could come from a power saving mode that we see more often these days.
You must ensure that there is any setting in the BIOS that could cause the machine to shutdown ? If you want to make sure it's comes from the BIOS or from the Operating System (I suppose you use Windows), I recommend you to boot a linux live CD on a usb stick or CD. My recommendation would go to download and burn the latest Kubuntu CD, then boot on it (without installing it of course), and wait for 2 hours to check if the computer did stop or not.
Jul 09, 2011 | Computers & Internet
Beeps: deda, deda, deda, and RED led on motherboard flashes along with beeping. Sopmetimes happens if tower moved slightly, or may do so if left in idle mode, shuts down and starts the beeping. ...
This series of beeps tells us that your RAM is some-times not being seen by the computer system.
You need to remove the RAM modules and clean the gold finger connectors with tissue paper.
Clean out as much dust as you can with a vacuum cleaner, then reinsert the modules in the correct orientation.
Easy as they will only go in one way. There is a cut out on the RAM module that separates the gold finger connectors.
Kind Regards
damnor01
Feb 03, 2011 | E-Machines W3052 PC Desktop
My computer shuts down after 15 seconds. And the run time get shorter and shorter through out the times that you try to start it up
look at the capacitors around the processor and heat sinc the tops should be flat if not they need replacing if so you could need a bios flash if you had troubles shutting down and start up you need bios flash if not to late already
Oct 17, 2009 | Computers & Internet
Won't complete booting
Sounds like at the very least, the hard drive is. This is common when a file required by the OS is corrupted, and the OS tries to not damage data so it restarts or shuts down.
Jan 18, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
Startup problems
check your keyboard connection (unplug and plug again). If not works try another of same type.
Dec 24, 2007 | HP Compaq Presario V2000 Notebook
Monitor shuts down after 20 minutes
Sounds like the monitor is overheating. The internal power supply maybe going bad. Ray
Jun 19, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
E-Machines eMachines Desktop PC Logo
93 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
