Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Washer won't agitate
The washer fills to the correct level and the machine advances to the next level in the cycle, but the machine won't agitate. I can hear the motor hum until it thermally overloads and stops. I can turn the basket by hand, but the motor won't move it. If I manually advance it to the spin cycle, the water empties and the motor spins the basket. It will also start spinning (when advanced) if it is full of water.
  • 4 more comments
  • SDIIAZ Nov 05, 2007
    I have the same problem. Already check the belt, still good. Do not know what is wrong. Still looking for solution.
  • mikesusanl Aug 22, 2008
    Frigidaire model flxg52rbs7 top load washer - stacked washer/dryer combo. Machine fills with water. When timer advances to agitate the motor hums and starts to smell. I manually advance timer to spin and motor spins and drains. With belt removed I can turn transmission pulley in both directions. One way turns tub for spin, the other way turns agitator. With belt off motor spins freely on spin, but only hums on agitate. Thanks for any help.
  • littlejennyt Mar 04, 2009
    I have a frigidaire full size stackable washer/dryer that I purchased in 1997. The washer will fill with water to the appropriate level but wont agitate with or without clothes. It will drain and spin. If it is the belt, where is it located. My boyfriend took off the back panel but was unable to see the belt. Please help!
  • Anonymous Mar 20, 2009
    how take off front panel???
  • Anonymous Mar 22, 2014
    Motor and heater not working, level pressure switch turning solenoid valve off, than cycle go on without motor or heater turning on. Simulated overfilling fault, pump starts pumping and empties water from wm. where should I look for fault?
    Thanks Sam
  • Anonymous Mar 29, 2014
    repair man said it was motor and cost is like a new one. it fills but will not spin
Just fixed the same problem. Its a broken belt. Take the front panel off and to the right of the tub you will see a pulley and belt. We replaced both the pulley and the belt for around $40. Was real easy to do yourself.
Posted on Jun 06, 2007
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
Oct 30, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer will not move to next cycle; has to be done manually
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. Hope this helped.
Jul 16, 2009 | Washing Machines
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Ammana nav8805e
If your washer fills but the timer cycle doesn't advance-replace the timer. If your washer fills the time cycle advance, and still not agitating your agitator is at fault.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
1,128 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
