Question about Kenmore 24 in. 16023 Built-in Dishwasher
Clean Light is flashing
I have a Kenmore model 665. 1602 stock number 16023. The clean light is flashing and the unit will not start. The troubleshooting section of the manual says to call a service tech to check the heater circuit. Does anyone have any other information on this problem?
  • bsokol99 Jul 25, 2008
  • 188 Answers
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Mar 02, 2009
  • quakwak Jan 15, 2011
    Whoever submitted this answer, THANK YOU!!! You saved me $1,100 on the Bosch my wife was pressing me for!!!!
How do I stop my kenmore dryer, model 970-c87172, from beeping? Drying, cool down, wrinkle rid and clean lint filter lights flash 3 times. Start light doesn't flash at all. It does this even
Hi Brenda
First off It seems that you model is not correct. Kenmore model numbers start with 3 number followed by a . and then some more numbers. Most Kenmore laundry numbers start with 110.xxxxxxxx. The number you have looks like a serial number which is no help.
Oct 19, 2014 | Kenmore Dryers
Won't work say's clean
the clean light is flashing a error message , remove kick plate and get the tech sheet to see what the error is .
Feb 20, 2013 | Kenmore Dishwashers
My Kenmore dishwasher 16023 stopped working yesterday. I'm not sure if it stopped working midcycle, because the dishes were not clean when I I took them out and there some water pooled at the bottom....
Firstly be very careful working with electricity.
Try plugging a lamp or similar into the outlet to see if it has power.
If it does sounds like it then has internal problems.
Most older appliances cost more to repair than they are worth. I suggest time to upgrade.
Nov 02, 2017 | Kenmore 24 in. 16023 Built-in Dishwasher
Diswasher malfunction - won't start clean light flashes 7 times The clean light keeps flashing green. Can't get the washer to start. The only operation it will do, is drain when the cancel / Drain button...
This information may help in your situation. This can be a common problem on some Whirlpool manufactured dishwashers. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Nov 10, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Was running a wash cycle lastnight and it stopped running and the clean (green) light is blinking and won't turn off. When I push the Start button, there is a red blinking light. Help. It is a Kenmore...
Is your washer a front load? Does it have a small window where you read the stages or minutes left?
If so is there a code flashing in thet window?
Also what year is your model?
Oct 21, 2009 | Kenmore Dishwashers
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Kenmore Elite Dishwasher clean light ind flashing and won't start
That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold
Jan 09, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore 24 in. 16023 Built-in Dishwasher Logo
557 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
