Canon VIXIA HV30 DV Camcorder Logo
Posted on Nov 16, 2008
Canon vixia hv 30 not recognized by computer
Plugged in usb port hi speed--no picture no nothing. camera display settings at auto as canon says playback mode determined by computer ability to show and it's not HD ready--do I need .M2T whatever that is? or what
  • 3 more comments
  • Anonymous Dec 28, 2008
    can't d/l movies
    Canon HV30 isn't recognized by my relatively new iMac G5 (3.0  Ghz, running 10.5.6)  My older Sony camcorder gets recognized instantly, but when I attach this new Canon HV30, I get nothing (from iMovie or Systems Profiler.)  Any advice?
  • Ron Charles Dec 28, 2008
  • Anonymous Feb 27, 2009
    ya same. it really sucks
  • LolaJoy Mar 07, 2009
    I'm trying to import video from my brand new Vixia HV30 to final cut express and it's just not working. I had no problem with my old camcorder. No doubt the new camcorder captures beautiful video, but seems like a complicated mess just to import it into my lap top to edit. I'm ready to return it. I'm not technically inclined so can anyone help me with a simple step by step solution.
    Thank you!
Anonymous
Level 1:
  • Contributor 36 Answers
  • Posted on Dec 02, 2008
Anonymous
Contributor
Level 1:
Answers
36
Questions
0
Helped
15335
Points
55
This camcorder uses USB for pictures only. To access pictures, plug in USB cable, set the camcorder to Play and to Memory Card.
To transfer video you need a firewire cable and card. Actual cable will depend on connection your computer has, typically it will be something like this: FireWire_cables.jpg
Additionally, to transfer video you will need a video capture software and codecs, unless the software has the codecs (Nero does). Unfortunately all free video editing software I tried was unable to deal with HD. I had various levels of success with Windows Movie Makver, Ulead and Nero.
You may want to record video in non-HD, and see if you are able to capture that. If your computer can capture that but not HD, and you have the codecs installed, you will need to investigate your computer.
If all you need is a codec, here is a good free candidate: K-Lite Mega Codec Pack
It is of course very frustrating that Canon would include nothing with the camcorder to assist users with video caputure.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 30, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3295
Points
The iMac for example only accepts a firewire transfer, not USB. If your laptop doesn't have Firewire port, you can spend $60 on a 500MB external hard drive with both a firewire and USB port, load it onto the hard drive, then import it into your computer's movie program via the USB.
2answers
I can't download pictures to my computer error message says cannot detect camera
It may be a USB port issue or a USB cable issue. Try an alternate cable or a different USB port. Try other USB devices on those same ports to make sure they work. Try using a USB card reader to transfer photos from the card directly instead of plugging in your camera directly.
I am trying to digitize HDV footage using fcp 6.0.6 on an Intel imac with 2gb ram. Trying desperately to get my computer to recognize the Vixia HV 30 camera, but it will not. I have tried changing...
First, confirm what type of video is being output from the camera as HDV cameras can also ouput DV or can Downconvert HDV footage form the camera to DV even if the settings for recording were HDV.
The message is to double check and understand the menu settings within the camera.
Once done FCP will require an Easy Setup that matches the camera output.
If you shot and are indeed outputting HDV, start off with Easy Setup>HDV-Apple Intermediate Codec1080i60, assuming you a an NTSC user.
My computer do not recognize my canon vixia hf20 double click on my computer icon : computer do not recognize the camcorder canon vixia hf20
Be sure that you have installed he driver correctly ..and the cable is well plugged...,another thing to check is the camera's display and see if it asks for a connection confirmation in the moment you plug it in ...if it does..choose PC connect ..and after that will work ..
also check into the device manager and see if the camera is present there ..even if it appears in yellow with an ask sign on it ...this meaning that the driver is not installed or damaged or not the proper one..
http://software.canon-europe.com/products/0010719.asp
select the operation system ..download ..reinstall and go for it ...but first check what I suggested..
Need the manual for Canon Vixia HV 30 mini HDV camcorder
You can download and print the instruction manual in PDF format by clicking this link
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
2helpful
(Canon HV-30) Firewire not responding any more with Final Cut Pro
SET YOU CAMERA TO FIREWIRE OUT, NOT AUTOMATIC!! <!-- from fixya rte -->
1helpful
Canon hv30 is't being recognized on my vista computer
You may have used a different USB port on the computer. Try a different one.
Generally, any USB port would work, except that some devices create a "Virtual USB" connection that is configured with a specific USB port.
Let us know if this helped...
Gort007
2answers
1helpful
2answers
My Mac does not recognize my Canon HV 30 DV when i connect the FireWire.
I've been around the block with this for days, including a fresh installation of the software on my MacBook Pro. Sigh.
Here's what seemed to work:
1) Reset Vixia HV30 (tiny reset button behind the battery). Did not change any settings on the camera after that.
2) Installed Canon's software that dropped some canon-related files in Library/Quicktime folder.
3) Opened new iMovie 6.0.3 and Final Cut Express HD 3.5.1 projects (a) FCE (using Easy Setup in FCE) to Apple Intermediate Codec 1080i60 (b) iMovie 'HDV 1080i'.
4) Connected 4-pin --> 6-pin firewire cable out of the camera to a bus-powered external drive and from the drive, firewire 800 --> firewire 800 --> MacBook Pro 10.5.8.
This was a last-ditch, Hail Mary effort. It worked, and the camera showed up in the System Profiler firewire window, too, whereas it had not before all of the above. Still does not show up when hooked directly from the camera to the FW 800 input, but at least I can capture now.
Black screen
To view the pictures on the computer, remove the card from the battery compartment and put it in a card reader connected to your computer.
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
