Question about Wolfgang Puck Bistro 1700 Deep Fryer
Fuse keeps tripping
My fryer when warming up keeps tripping the fusebox.When I first got this it did this too , but then I had no problem for quite a while.I've tried plugging into different outlets but it keeps tripping the fuse.Any ideas please ?i love this fryer and eagerly want to use it again ? Thanks.
  • 944 Answers
The first thing to do would be to get an electrician to your home to check that the problem is not with your supply. If you ask nicely then the same guy could probably check your fryer for short circuits - the most likely culprit if the problem is intermittent is the plug on the power cord, the cable and the connection inside the fryer where the cord goes in - check that all these are ok. The other possible cause could be a faulty element, however this is unlikely to be an intermittent fault, and it would usually get worse quickly to the point of not working at all. Hope this helps - please post again if not :)
Posted on Apr 17, 2007
What could be causing my Pitco Electric Fryer pump to keep tripping the circuit breaker?
Hi there!
The filter pipes may be clogged causing the motor to trip off during operation.
You can find the nearest authorized service center when you visit www.pitco.com
Regards
Feb 02, 2013 | Kitchen Appliances - Others
What is the reason for the reset button keep poping out on the dean sm35gm
Hi there!
Reset button of hi-limit switch will only pop-out when its sensing bulb sensed temperature higher tha 450F (trip temperature of hi-limit). Theramostat may be bad allowing oil to reach temp above 450F causing hi-limit to trip-off or hi-limit itself is bad tripping-off at temperature lower than 450F.
Check also the position of the sensing bulb of the hi-limit, it may be positioned touching the heat tube (for gas fryer) or heating element (for electric fryer) that's why it prematurely trips-off.
Regards.
May 11, 2012 | Dean SM20G2 Deep Fryer
F-64 red trouble light keeps comming on
Hi limit switch is tripped.If it stays lit at start-up, you have to replace it, mechanical contacts got stuck in tripped position.
Apr 15, 2011 | Wells F-67 21167 Deep Fryer
Dash lights quit, gauges and idiot lights work. Help
It's most likely a burnt fuse. Check the fusebox in the cab first. If none of those match the dash, check the underhood fusebox next. A burnt fuse looks like a burnt light bulb. As long as the metal part in the middle is connected it should still be fine.
Mar 02, 2011 | 2001 Ford F350 Super Duty SuperCab
My ge deep fryer will not turn on
Most of these fryers have trip on the rear of the element unit. Search for the trip and reset, if this does not sort out your problem check the fuse in the plug if you are in Europe.
Regards
Alan Hood
ami-man
Mar 29, 2010 | GE 168952 Deep Fryer
Ducati monster s2r 800 2005 after big rain nex day no pover after turn keys on
A couple of potentials here: -water in the fusebox -water in the ignition switch -corrosion or bad contact at the starter -blown fuse due to water intrusion I lost a fuse myself on a cross country trip in a heavy rain storm. I lost the ignition and fuel pump fuse at 75 MPH is a blinding 38 degree rainstorm across Nebraska. My solution was blow it out the best I could, install one of my spares, and parked her inside the hotel lobby for 8 hours to let her warm up and dry out. If you find water in any major contacts or fuseboxes, get an air gun on a compressor and blow them out WELL before installing a new fuse, or you're back in the same boat. The fuse box cover waterseal.... DOESN'T. (in my experience...) the Stick
Nov 26, 2009 | 2005 Ducati Monster S2R
Quit working no power
IT could be a blown fuse , if your handy w/ tools or know someone who can fix anything , you need to open it and locate a fuse (a small glass tube) and replce it, hope it works , AJ
May 26, 2008 | Rival CZF630 Deep Fryer
Sunbeam Deep Fryer Model df6300 4litre
FIRST check for a blown fuse inside , that could be it , let me know , AJ
May 18, 2008 | Lang Manufacturing C28 Deep Fryer
Star deep fat fryer model #EM14
You should determine how many amps the unit is pulling, you will need an ammeter to do this. Continuity through the internal circuit breaker does not determine the current being pulled by fryer only that it can pull current. If the fryer is pulling more than 50 amps the problem will be in the fryer, if it is less than 50 and the breaker trips you could have a faulty breaker.
Aug 22, 2007 | Star Manufacturing TSF-6575 Deep Fryer
Kitchen Appliances - Others Logo
679 people viewed this question
Top Wolfgang Puck Kitchen Appliances - Others Experts
Steve
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Wolfgang Puck Kitchen Appliances - Other Expert? Answer questions, earn points and help others
