Question about Compaq ATI RADEON All In One Wonder (32 MB) Graphic Card
Video capture function has weak audio when using dongle connectio
When I capture a video from my camcorder or vcr using the input on the tv mode the audio is very weak. if i use line level audio from the rca jacks and if I use an amplified audio source the audio gets distorted before it is really as loud as it should be. I cannot find an adjustment for the audio input. You cannot use the line in on the motherboard and combine it with the video input from the dongle. This makes poor videos for u-tube. What am I doing wrong? xp pro sp 2
  • Compaq Master
  • 2,087 Answers
OP did not state what model number of the video
flash ACD card he has.
no PC stated
OS (operation system (windows what?)
no OS stated (XP) this matters big time to match good relic software and drivers.
no sound card stated, (if a card or on mobo)
lacking all that key factual information all I can say is.
1: test the VCR with a real amp yet, hardware, not the PC? if this fails the TAPED audio is no good.
or connected to a TV with RCA jacks,?
2: using the PINK jack is microphone and is hopeless using that. use the light blue jack. line-in
3: never ever connect a speaker amp to line-in,'or you will overload the line in pre-amps and they WILL CLIP/Saturate. (horrible distortion).
4: get a real sound card, use that, buy one, that has good software drivers for you unstated OS.
5: better is to get the video/sound Gongle USB. device for $10
one of the above 5 choices will work, as always.
6: buy a real camera. used, one that records to SD cards. not tape.
end the usage of tape, is always best.
SDR card, Sony DCR series Handycam.
to MPEG-2 format.
https://www.ebay.com/itm/Sony-Handycam-DCR-SX63-16-GB-Touch-Screen-Camcorder-with-Charger-and-SD-Card/222665242926?epid=99992346&hash=item33d7e1f92e:g:HD8AAOSwDJ1Z0wEV
composite video from VCR, do you have composite?quality video.(magic good tapes, LOL)
or the USB video/auto DONGLE from Amazon, etc.
Posted on Oct 30, 2017
  • Anonymous Oct 31, 2017
    or tell what sound card is there.
    if no card what PC, you have.
    and we can find the matching drivers..
  • 104 Answers
Double click the speaker down by the clock, click options/properties and make sure line in has a check next to it then press ok, now go to your line in slider and raise the volume
Posted on Dec 15, 2008
  • 1 more comment
    he is using LINE input , not speakers.
    VCR line L/R to sound card.line in.
    so only line in is adjustable, for sure not the VCR. (rca audio jacks)
    what he needs is better video capture device.
    assuming the Tape is good, and is dream there, no?
    time to upgrade.
    http://www.ebay.com/gds/Top-5-Video-Capt...
    or better sound card, there are endless examples of sound cards and quality.
    some even have filters, and extra's on line in,
    never connect a speaker amp to any line jack
    the line it is 300mV max. (each card has its own rules here)
    the speaker out of an amp at 5watts
    is near 6 volts, 20 times too much.
    see?
    they doing a tests.
    take that VHS tap
    connect the VHS L/R RCA to any audio amp.and speakers if it sounds ok then the tape is good if not? , NOT.
    easy using only hardware that dont lie like computer can.
    if that test passes then we attack the sound card unstated in your post, or is it just the
    unstated mother board, line in jack.
    omg your not using MIC jack are you?
    never connect line in to mike,
    line in is light blue, pink is MICrophone , or mike as we say.
    once this is correct from VCR direct to Linein blue.
    then we need the correct sound card driver.
    from the maker.
    no PC stated, nor sound card so , no help possible here.
    which one, there are many models.????????
    the 8500 DV from 2002 (15 years old? that one?
    this card has video flash ADC.
    720x480, 8MB-per-second MPEG-2
    but has no sound on card.
    the OP uses and unstated PC and unstated OS and sound card to digitize sound.
    ether the driver is wrong for your sound chip
    as is so common on 15 year old PCs
    that is the problem.
    RECAP and conclusion:
    1: tape sound is weak, (bad tape or recording methods wrong)
    2: a real amp test, (per above) passes tests.
    3: a newer sound card works.? it sure will
    4:or buy the USB video/ sound capture device.
    this is best as it has great software that lets you record many formats even MP4.
    use only the blue jack on the sound card.
    3.5mm with RCA to 3.5mm adapter.
    A "Y" adaptor RCA- left/right to mini phone jack. to Lt.blue jack ONLY.
    get and run the correct driver for your sound card(or chip) my guess, its is wrong.
    and never once stated. what is there.
    i did this all the time back in year 2000
    before DVDs/
    and did audio work back to 1965.
    Tape then.
    My guess, is the best answer is buy a real camera from this century.
    all we really know here are 3 facts.
    ATI RADEON All In One Wonder Graphic Card
    VCR
    and sounds bad.
    nothing else stated, not even photos of all wires at back of unstated PC presented.
    is the OP using the CamCorder as VHS tape player only.> wow so many facts not knonw.
    if doing live video to you tube.
    there are 1000s of choices better.
    this\? is what I use on vacation.
    https://www.walmart.com/ip/Sony-HDR-CX24...
    or use my Canon T5I-eos , in video mode.
    or if really active in the field
    this
    https://www.stuff.tv/news/five-best-vide...
ONLY HAVE A S-VIDEO CONNECTION ON CAMCORDER, HOW CAN I TRANSFERE VIDEO TAPES TO COMPUTER?
Does your computer already have a capture card input function and video record software? IF not, then you'll need to purchase one. When you purchase one be-sure it has s-video input. Many have an adapter that will convert the s-video to composite video (RCA Jack type) if it doesn't have s-video to begin with. If your computer has the capture capability but not a s-video input then you'll need someway to convert the signal. Its possible to kind of cheat and use something else like a old vcr. Do you by chance have an old vcr that had s-video in. If yes try connecting the camera s-video to the input of the vcr, select the correct line in and then connect the RCA composite line out that would go to your tv to the input of your computer capture card. You could also checkout your local radio shack, best buy, etc and find an adapter/converter. If you don't already have a computer setup I suggest going to your Favorite electronic store and looking around the software section. There's lots of box sets that come with hardware and software. Some require card installs and some use external usb connect devices.
Jan 30, 2011 | Samsung SC-L901 Camcorder
Sony handycam ccd-trv35e how to video record on my laptop
Hi there.
The computer must have standard Audio/Video (A/V) RCA input jacks and compatible video capture software to complete this procedure. Because there are many different video capture applications on the market and we cannot reasonably know which video capture software you are using, Sony is unable to provide specific instructions or support for software we do not manufacture. However, many video capture applications have detailed help files, including specific instructions about capturing and importing video from a camcorder to a computer.
The help files should be available in the Help menu of the video capture software or in a separate file on the software disc. If you cannot find instructions in the help file or on the disc included with your software, consult the software manufacturer for more detailed support information.
  1. Connect an A/V cable to the A/V output jack of the camcorder:
    If your camcorder has standard A/V RCA output jacks, use standard A/V cables for the connection. avstnd.png
    If your camcorder has a mini A/V output jack, use an A/V cable with a mini connection on one end.
  2. Connect the other end of the A/V cable to the A/V input jack on the computer.
  3. Turn on the camcorder to the VCR, VTR or PLAYBACK mode.
  4. Cue the video in the camcorder to the beginning of the video footage to be transferred.
  5. Turn on the computer.
  6. Start the video capture software.
  7. Begin playing the video in the camcorder.
  8. Begin importing the video with the video capture software.
Good luck and thanks for choosing FixYa!!
Jun 02, 2009 | Sony Handycam CCD-TRV35E Camcorder
Computer not recognising VCR- what plug should i use?
You need a TV tuner card to be able to read both audio-video signal, else how are you going to covert analog to digital. The VCR gives out analog output.
........sodeep
May 08, 2009 | Pinnacle Studio MovieBox DV 9 (210100349)...
Video transfer not working
  1. connect VCR(recorder) to TV, select TV proper channel to get signal from VCR
  2. connect Mini DV to VCR, for example, you are using AV1 input on your VCR
  3. on you VCR, select channel(or input) to AV1, insert a blank tape
  4. turn your Mini DV to play mode and play, press REC on your VCR
you should get picture now.
May 08, 2009 | Panasonic NV-DS60 Mini DV Digital...
Cant capture video
Not having camcorder control is normal, as the ADVC110 doesn't translate DV (AV/C) control to anything else. It just accepts and replies to deck control commands so the capture application doesn't get stuck waiting for a response.
First off, make sure you only have the ADVC110, your VCR, and your computer connected. No other Firewire devices.
Be sure your have the output from your VCR connected to the ADVC's input. Connect your VCR's output to your TV. You should see in iMovie the same image you see on your TV, slightly delayed.
Jul 04, 2008 | Canopus ADVC-110 A/D Converter...
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Watching tapes on TV
To connect your camcorder to a TV (or VCR), you'll need audio/video cables. These need to be run from the VIDEO and AUDIO jacks on the camcorder to the VIDEO and AUDIO inputs on the TV (or VCR). Once cabling is completed, follow either of these scenarios: When connecting the camcorder directly to the TV, turn on the TV and tune it to the video input channel by pressing the INPUT button on your remote control. # When connecting the camcorder to a VCR that is already connected to a TV: Turn on the VCR and place it in the Line or Camera mode. # Operate the TV as you normally do to see the signal coming from the VCR. Select camcorders have an S-VIDEO jack, which offers higher video quality. Provided your TV or VCR has an S-VIDEO input jack, connect the camcorder to the TV or VCR using an S-VIDEO cable. Since the S-VIDEO cable only transfers video, you will also need to use an audio cable. Select the S-VIDEO input on your TV or VCR to view the signal coming from the camcorder.
Sep 06, 2005 | RCA CC-432 Camcorder
Digital camcorder to convert VHS tape to PC for DVD burn
You can't with what you've got I hate to be the bearer of bad news, but in order to play tapes in a vcr and run them through a digital camcorder for output to a computer, the camcorder must have s-video or av inputs. Your camera only has s-video or av outputs, used for sending from the camera to the vcr or tv. Also, some cameras have the inputs but don't support analog to digital pass-through (which is what you are describing). With these cameras you input from the vcr and record it to the tape in the camera, and then output it to the computer. Without the inputs, you can't do either one.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Compaq ATI RADEON All In One Wonder (32 MB) Graphic Card Logo
284 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
