Question about Garden
How-to repair the pull starter for the WEED EATER GHT220 hedge trimmer.the rope pulled out .
  • 163 Answers
Remove the starter housing, usually only 3 or 4 bolts or screws. on the inside should be a large white or black wheel, hold the outer case with one hand and rotate the wheel counter-clockwise with the other as many times as can without force. on the inside of the wheel should be a small hole, rotate the wheel to line it up with rope guide hole on the outer case/housing. use a nail or small screwdriver to help hold in place. feed the start rope through the 2 holes and tie a knot at the end, single or double depending on the size of the hole. if the end of the rope is frayed, use lighter to melt and twist to a point to make it easier to handle. when reassembling you may need to jiggle the handle for realignment. it works on an inner spring coil tensioner system, so if the cable has no tension when rotated or doesn't recoil back, the starter assembly will need to be replaced.
Posted on Nov 28, 2008
HOW TO FIX BROKEN STARTER PULL ROPE ON TB65SS WEED EATER?
You need to remove/disassemble the recoil starter assembly to replace the rope. Be carefull the spring does not get away from you if you do take iot apart.
Sep 21, 2014 | Garden
Weed eater featherlight XT260 rope pully
Your recoil could be messed up if you cant pull the rope out or if its just too hard to pull out you could have it too tight.
Jul 29, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Where can I find a manual for the PE550 weed eater
You can download one online at... http://www.poulanpro.com/poulanpro/indexAction.do?id=default Scroll down the right side to 'Download Manuals'...then enter your model #.. you can then download the owners manual or parts manual. Dwain
May 21, 2009 | Poulan Garden
Poulan Weed Eater GHT220
there are mntwo different size fuel lines which one does the gas filter hook up to?
Oct 17, 2008 | Poulan Ght225 25cc Gas Hedge Trimmer
Garden Logo
2,739 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
