Question about Canon EOS 400D / Rebel XTi Digital Camera
My camera flash just won't work anymore
It doesn't pop up on automatic and it doesn't open when I press the flash release button and if i pry it open, it still doesn't flash. I didn't drop my camera or anything, why is this happening??
    Problem Solver:
  • 15 Answers
Again, the best advice is to immediately contact Canon, and get advice - if you try and fix yourself, it may invalidate the guarantee!
My guess is that when you press the flash release button, to pop it up, an electronic switch powers a release, and a spring loaded action pops up the flash - remember, you have to push it shut after use, it is not auto retract! I also am sure that the charge circuit is activated when the flash pops up. If it is not popping up when you press the button, the charge circuit will not be operating either.
I am sure you will find that if you ring Canon, there is a procedure which will return the camera to default settings, which would reset the flash action too perhaps. It may mention it in the handbook of instructions, or Canon will tell you. I had mine go weird, but it wasn't flash, and they told me, and it fixed my problem when I followed the advice - always ring them, and if you take the advice, and it causes a problem, you have a valid way out of responsibility if they claim you made the problem worse by forcing it to do something it wasn't doing as it should.
Hope this helps
Adrian
Posted on Nov 29, 2008
Nikon D5100 Built in flash won't pop up
Not even when you press the button on the left side of the class? the one with the flash symbol.
Switch on the camera and then press the button.
Look in the manual how you can setup the flash in all other than the automatic mode.
Nov 27, 2013 | Nikon D5100 Digital Camera
Nikon D90 flash will not pop.
I suggest you take your camera to a Nikon camera repairer.
Apr 18, 2013 | Nikon DSLR D90 Digital Camera
The flash of my dsc h3 wont automatically pop up anymore
you have the camera on burst mode.put it back on single. it takes the flash to rechare like 5 seconds. and burst can;t support the flash.
Feb 22, 2009 | Sony Cybershot DSC-H3 Digital Camera
Canon Camera Rebel XTi reads error 05 and the flash will not pop up
Err 05 means: Something obstructed the built-in flash's pop-up operation. Turn off the main switch and turn it on again.
Prepare to press the flash request button with your left hand. With your right hand, position your thumb and finger to gently pry up the flash head, perhaps using fingernails. Push the button and pry. With that help, it should pop up.
Dec 20, 2008 | Cameras
Nikon d 80 flash will not pop up while in auto mode
The flash up button is located on the left hand side of the camera right near the top.   You should use this button to pop up the flash. Prying it up could/has broken this button.
Also, depending on what setting you are using, the flash doesn't always pop up automatically.   Check to see what mode you are in, on the round dial on the left -- ie  Auto, Portrait, Manual, etc.   I can move sometimes without your knowledge, and this may be the problem.
Apr 15, 2008 | Nikon D80 Digital Camera with 18-135mm...
Canon XTi Built in Flash
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Feb 09, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
How to switch on Auto Flash in Auto mode
Put the camera in "P" and press the flash button above the lens release. If the flash pops, than you probably just have too much light to need it when you are in auto. The flash button is not active in auto so if the xti doesn't want the flash in auto, u can't make it fire. If the flash button does not make the flash pop in "P", search this site for another post about flash not working and u will find that this could be the flash deactivation button in the hot shoe sticking. Not likely though with a new camera unless u have had a speedlite mounted alot.--
Dec 26, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Automatic flash problems
I have the same problem as Irichard, in that the flash won't pop up automatically, the camera wont work when you pop it up manually all all modes that allow flash photography do not work.
Nov 01, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
My Flash suddenly will not pop up.
Hi Randy, It seems like the problem could be the settings. Try to set the flash manually, and then try to pop it up. If this doesn't work, and since the pop up flash release is electronic, have the camera cleaned at a camera shop. This would be a small price to pay if it works, and would be worth it for such a great camera. Please let me know if this works for you. Best regards, nightdiver
May 29, 2006 | Olympus Camedia C-770 Digital Camera
Flash Problem
Using the flash When shooting with the built-in flash, open the flash manually. The flash does not pop-up automatically. The flash will not fire if it is closed. The flash will work when it is opened up. When the flash is open, the (flash on) icon or (automatic) icon will appear on the LCD monitor (or in the viewfinder). Flash on: The flash fires in every shot. Automatic: The flash fires automatically. Press the (flash) button to switch between the and flash modes while the flash is open. In some shooting modes, the flash mode does not switch even if the flash button is pressed. Please refer to Functions Available in Each Shooting Mode in the Camera User Guide provided with your camera for more information. When you are not using the flash, close it manually. When the flash is closed, the flash will not fire and the icon appears on the LCD monitor (or in the viewfinder).
Aug 31, 2005 | Canon PowerShot S2 IS Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
82 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
