Question about HP Pavilion dv4000 Notebook
Black screen for hp laptop
I have a hp pavillion dv000 laptop that I have used for about two years or so and all of a sudden its screen just went black...nothing. I cant even see a resemblence of my desktop when i turn it on although if i press the sleep button i can see the display for about a second. but, everytime i press the button it puts my whole computer in hibernation.
I dont know if the problem is my backlight, inverter, or my lcd, and even if i did i wouldnt know how to go about fixing it. I want to replace it completely with another laptop but there are some very important documents that i want to transfer over to my external hardrive first but cant because i cant see anything on it.
i thinkig about hooking it up to an external monitor another laptop but dont know how or what cord i would need to do that with. If that doesnt work, would i (or somebody else) be able to take out the C drive and put it in another laptop?
Thanks
    Brigadier General:
  • 6,966 Answers
Initially, a couple of ideas ou may want to explore:
  • hook an external monitor. Often there would be a VGA connector at the rear of a laptop specifically for this purpose. It would need a standard 15 video cable normally attached or with the external monitor. You may need to cycle through Fn + F? keys to enable the external monitor. F? would be the function key with the small monitor icon;
  • remove the hard disk of the erring laptop, connect it to a 2.5 to USB adapter and attach to a free USB port of a 2nd computer. it will be treated as an external storage device much like a thuimb/flash drive and therefore would allow copy and paste;
  • tap on the cover of the laptop, the one right behind the LCD screen anywhere on the sides, this is in the hope that it is a cold solder or loose connection;
  • run the laptop with the lid not fully opened;
  • slightly warp/twist the lid/LCD, it could just be a loose connection;
  • if the display works even just momentarily, then chances are that no major repair work is required. The bulk of the job would be in the opening and offhand, no major component replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 16, 2008
Respected sir,
when i turn on the laptop i do not found disply and see the balnk screen. so pls send me quick soloution
Bhupendra verma
Posted on Dec 13, 2008
    Sergeant:
  • 306 Answers
  First of all the backlight, inverter, lcd is not the problem if you see any display, even for a second. An external monitor connects just like it would for your desktop computer -a 15-pin connector -the only connection for an external monitor. Do that connection while the computer is off! Fn + F7 switches between the lcd internal monitor and the external monitor if you do not see a display at boot on the external monitor. If you find that the video card/motherboard is history then the internal hard drive can be removed and connected to another laptop or desktop computer. There are inexpensive adaptors or hard drive cases that allow you to connect that drive to any computer. If you are not interested in doing that then you can also take that hard drive to a computer shop who can easily transfer that data to another hard drive, burn a cd/dvd or put it on the internet for you to download with another computer.  The only consideration for putting the hard drive in another laptop is that you cannot boot from that drive on another laptop. If you use an adaptor to connect to a desktop then that hard drive will be a removable disk or slave, never the primary boot drive.
Hp pavillion dv6 on but dark screen
sounds like the black screen of death
a lot of dv hp laptop have this problem the gpu has to reflowed are your keys also blinking. if they are count the number of blinks it will point to problem
HP DV7 Laptop Graphics Fix Black Screen of Death
would not fix it his way
Jul 04, 2015 | HP Pavillion DV6-1355DX Notebook PC -...
Ihave an hp pavillion laptop where the screen went black and need a solution to fix
First hook a spare monitor to the video output jack usually on the back, if picture comes up! it indicates a bad inverter board, or the backlight has stopped working, if the spare shows the same problem, it means the video graphics card is defective and normally built into the motherboard.
Mar 05, 2012 | HP Computers & Internet
Hp pavillion laptop screen goes black
its the common problem with graphic card, if its nvedia chipset graphic, there is only one temp solution, ask any hardware machanics to put a glue and heat the display ic, then it would work for a week, in that period buy the amc from hp service centre, after a week if there is a prob, company will have to replacd the motherboard
Feb 10, 2010 | HP Pavilion dv6000t Notebook
Screen blacked out laptop hp pavillion dv9404nr
Please visit http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us and follow the steps. Contact HP and see if you model is on the affected list, as it could be eligible for a free motherboard replacement to resolve the defective video card issue. If they say no, check out www.hplies.com for other useful information regarding this Globally known issue with nVidia and HP.
Jan 10, 2010 | HP Pavilion dv9000t Notebook
Desktop monitor went black & and wil not power up
Try the fuse on the monitor power cord, and if this does not cure, you will have to get another monitor....pretty good prices on ebay!
Jan 04, 2010 | Computers & Internet
My hp pavillion dv000 wont trun on, when i press p[ower buttin , lights comes on, no fan noise, dvd drive make litlle noise, green light on and off, after20 seconds alllights trun off, please help
mother board repair or replace disc check and bios is still coming up but the part that kicks on fans for cpu isnt working hope fully it didnt damage cpu but its possible
Nov 07, 2009 | HP Computers & Internet
IBM Thinkpad R51 screen blacked out
try to plug in a extrernal monitor and see if that works if it does your backlight went out
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 21, 2009 | Computers & Internet
Hp pavillion zx 5000 screen black
GO ON LINE AND TYPE THE MFG NAME, MAKE, MODEL, SCREEN WENT BLACK.
ENTER
ROD
May 12, 2009 | HP Pavilion dv6000z Notebook
Screen dim to black
This will be a problem with either the screen inverter or screen backlight. You will need to take it to a shop for diagnosis, in order to find out which one it is. If it turns out to be the backlight, then the entire screen will have to be replaced. They are considered a sealed unit, and the backlight can't be changed out.
Jul 24, 2008 | HP Pavillion ZV6000 Notebook
HP Pavilion dv4000 Notebook Logo
697 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
