Question about RCA Televison & Video
Need details of how to reset RCA VRA905 to default settings
  • jdqu Nov 16, 2008
    EXTENDED UNPLUG AND SOFT START SUGGESTED DID NOT WORK - NO APPARENT RESET BUTTONS FOUND. IS THERE ONE UNDER THE COVER?
    VCR MODEL IS THOMSON (SOLD IN AUSTRALIA AS RCA)VRA905AU ABOUT 7 YEARS OLD.
    NEED TO RESET TO DEFAULTS TO RETUNE TO PLAY VCRs.
  • 905 Answers
Are you having a problem playing vcr tapes ? or are you having a problem setting up the channels?
and is this your vcr?
Need details of how to - 12e0924.jpg or do you have a dvd player , because thats what you have it listed under, but if you have the vcr and you are having problems playing vcr tapes ( tracking can be adjusted on the remote) but the head may be dirty and it does have auto tracking. or inside the player there is manual scews to readjust the tracking setting.
if it is the channels that are a problem then you can auto program the channels in the menu options
Posted on Nov 16, 2008
    Genius:
  • 1,011 Answers
Sir,
Power on player.
Open the tray.
Enter 16719.
OSD shows current region.
Enter 0-6 for region setting before screen disappears.
(Enter 0 (ALL)for region free.)
Display shows new region assignment.
NB (Displays "ALL' if 0 is selected.
Power off.
click this link for more information
http://www.dvddemystifiziert.de/codefree_en/rca.html
thanks
good luck
    Genius:
  • 1,250 Answers
Try this one
There is a small hole just to the left of the plugs in the back call 'reset.' Open up a paper clip and use it to press the button inside the hole. It will initialize the VCR settings to the default
    Genius:
  • 1,269 Answers
Try the following steps.
1. Eject any CD inside. Turn off the unit
2. Unplug the power cable for about 5 minutes then plug the power back in.
3. Using the remote, hold the power button for about 10 seconds
4. Or on the unit itself, hold the power button before plugging the power cable back in.
5. Wait for 10 seconds before you release the power
Hope that helps!
    Brigadier General:
  • 6,966 Answers
Initially, pls try unplugging from the mains for an extended period of time. Additionally, pls confirm the model number. I could not find any listing for an RCA VRA905, there is however a Samsung DVD905. In some versions, a soft reset could be performed by unplugging, press and hold the power/standby button while plugging in; in some others it could be a combination of keys while in others, there would be a small recessed button at the front or rear for a hard reset.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 16, 2008
    Hi again,
    Appreciate the quick postback.
    Most VCRs do not have a reset button/feature unlike some DVD players. To your concern "NEED TO RESET TO DEFAULTS TO RETUNE TO PLAY VCRs.", could you pls clarify:
    • retune;
    • play VCR.
    The way I read it is, you can not watch the movies played in the VCR? If yes, perhaps it is not the VCR that has to be tuned but rather the TV? Meaning the TV is not set to receive the signal output of the VCR. In most PAL models, there would be a hole somewhere where the antenna cables are connected. It would contain an adjustment screw that is used to adjust the channel/frequency of the RF out which is normally in UHF. Often likewise, there would be marking saying something like 39~50 indicating the channel. Should this be the case, pls tune your TV to regular broadcast channel 39 and adjust the VCR till you receive said video feed from the VCR.
    Alternately, perhaps the TV is set to CABLE and not AIR or regular broadcast hence it can not receive the VCR's signal.
Reset voyager111 rca tablet
hi Rodney.
see if this helps you out.
Follow the detailed instructions below on how to completely reset your RCA Android 7 Voyager (RCT6773W22) tablet. Step 1. With your tablet off, press and hold the volume up (+) button and power button until you see the RCA splash screen with Nipper and Chipper.4 Feb 2017
SOLVED: cannot reset my tablet to factory default - RCA ... - iFixit
https://www.ifixit.com/Answers/View/.../cannot+reset+my+tablet+to+factory+default
or go to this link to read up more.
how to Reset voyager111 rca tablet Google Search
Nov 29, 2017 | Tablets & eReaders
I was given a RCA tablet that had been reset wrong. It now wants information I don't know. Can it be fixed?
hi there.
see if this works for you if not go to the link and the bottom.
RCA tablet reset Google Search
Nov 17, 2017 | Tablets & eReaders
My rca 55 in smart tv only has power menu input volume and chanels what do i push to reset tv
If set has reset manual will tell you. Or you can contact RCA for a hidden code to restore to factory defaults.
Sep 07, 2017 | RCA Televison & Video
Gccant get my sa?fe mode off. My rca andriod tablet
How do I get my Android tablet out of safe mode?
Use the following steps to get out of safe mode.
  1. Restart your device by holding the power button, then tap Power off.
  2. Tap Ok to confirm.
  3. Power the device on. Your tablet should now be out of safe mode.
If the device is still in safe mode use one of the following methods.
  • Uninstall the last application you installed:
    1. From the Apps menu, tap on Settings.
    2. Tap on the app and then tap on Uninstall.
    3. Restart your device.
Perform a factory data reset:
  1. From the Apps menu, tap on Settings, and then tap Backup & reset.
  2. Tap on Factory Data Reset, and then tap Reset Tablet.
  3. Tap Erase Everything to format your tablet back to factory default configuration.
Source: http://packard-bell-uk.custhelp.com/app/answers/detail/a_id/27146
Hope this helps!
Jun 26, 2017 | RCA Computers & Internet
Problem with RCA DTA880 DVR.
You can ask any question and as many as you like. We don't charge a penny.
Keep the answers detailed and spell check before you post and post to the correct category as you have done.
Jan 06, 2017 | RCA Televison & Video
Lost password for my netgear WGR614 Router
using a paper clip press the RESET button in the small hole on the rear of the device.
that will rset the router but you will have to tell it any special settings such as your ISP logon details and wireless setting all over again on most routers.
Some do remember the basic details
Feb 04, 2011 | Computers & Internet
Does the RCA TV Model G27400WK, Serial No.234550152 have a reset button and where would it be located?
try these steps
On occasion, an RCA television may need to have certain options reset in order to restore default settings. Software resets, such as resetting the Picture Control, the Parental Control lock and the Wake-Up Timer, can easily be restored to the default settings by accessing the settings menu via the remote control. A Hard Reset is recommended if there are hardware problems with the TV, such as a loss of picture or if the TV isn't turning on properly.
if that doesn't work try these steps
  • Unplug the TV's power cord from the electrical outlet.
  • Wait 5 minutes.
  • Plug the TV's electrical cord back into the electrical outlet. If this does not resolve the problem contact RCA Customer Support or a local technician store
  • Jan 04, 2011 | Televison & Video
    Where is reset button on 35 inch rca tv,I can only view 49
    there is no reset button. Ypu need to give more detail about what i sgoing on with your set. Also what is the model and ctc numbers thfey can be found on the back of set. Unplug set for around 30 minnets then plug back in see if it wil work then.
    Feb 28, 2009 | RCA 20" TV
    Televison & Video Logo
    22 people viewed this question
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
