Question about Breadman TR2200C Ultimate Bread Maker
Kneading I've used my Breadman a few times, but the last 2 it hasn't been kneading into a ball. I'll open it in Knead phase 2 to mix in what it didn't get, and it won't have anything patched together. But the paddle is fine and I added the ingredients just as it said. Any suggestions?
  • 25 Answers
Check your measurements.
Sounds like operator error.
Posted on Jul 24, 2008
2 Suggested Answers
  • 3 Answers
SOURCE: My bread maker doesn't knead correctly.
I had the same problem with my Breadman TR845. I made the first loaf O.K. but the knead paddle would not turn much when it had flour in the bread pan. I took it apart and discovered that the timing belt had slipped off the black plastic gear attached to the shaft of the motor. The belt was still around the shaft of the motor which allowed it to move the paddle a little. I needed a small spacer washer that would keep the black plastic gear from sliding on the shaft and allowing the belt to slip off. There is lip only on one side of the plastic gear so if it moves the belt can slip off. I created a spacing washer from the cap on a tube of toothpaste. I cut the toothpaste cap in half and had to use a metal file to get it the right size. It needed to be 1/4 inch tall and 3/4 inch in diameter. I cut the space so that it could slip over the shaft. After putting it all back together everything works fine. And the toothpaste tube was almost empty anyway.
P.S. There are lots of screws that hold it together and the belt and gears are at the bottom of the Breadman and you have to take the whole thing apart to get to the bottom. I was able to leave all the wires attached so that putting it back together went quickly compared to the work of taking it apart.
Posted on Nov 19, 2010
How can I get the machine to start the bread making process from the beginning. It is currently stuck on knead.
Do you have your owners manual and have you baked bread in your machine before? Just want to be sure that you know the stages that the machine goes through. The first mixing and kneading stage in a tr444 will take up to 15 minutes before it stops on its own. It will then let the dough rest for about 1/2 hour before the 2nd knead begins. It takes almost 4 hours for your machine to go through all the stages before your baked bread is finished.
Jan 15, 2015 | Breadman TR444 Bread Maker
I was given a regal bread maker model k6751 is the kneading blade supposed to turn the whole time?
No, the blade only turns when the machine is in a mix or knead cycle. There are many minutes where the blade does nothing. This is when your machine is allowing the dough to rise or at the end during the bake phase.
Nov 07, 2013 | Kitchen Appliances - Others
Kneading blade comes off during breadmaking process
Yes, if the blade come off then your bread is not going to mix and knead properly. The blades on all makers are designed to slip on and off though so you can remove them for cleaning etc. Be sure you are pushing the paddle all the way on. If it still comes off when mixing that would be very odd as the weight of the dough ball itself helps keep paddles on. I have owned dozens of machines by different manufacturers and never had a paddle come off in process.
Jan 01, 2013 | Sunbeam Oster CKSTBRTW20 Bread Maker -...
Bread machine model TR520, mixes the dough, stops for a long time, then starts mixing the dough again continuously without starting the bake cycle. This was on the french program. The machine is new...
By continuously do you mean forever, non-stop kneading? I'm guessing not. French bread is really nothing more than white bread dough kneaded for an extra long time. The extra kneading creates the chewyness common to French breads.
Hope this helps!
Jun 17, 2011 | Breadman TR520 Bread Maker
HI, I use the dough cycle and it takes 1 hour 20 minutes, but it actually only kneads the first 10 minutes and then here and there a minute for all together about 15 minutes of kneading. Is my machine not...
It sounds like everything is OK...machines knead a while,,,,rest a long time....knead a little rest along time etc......that resting allows the dough to rise....
Feb 27, 2011 | Breadman TR555LC Bread Maker
2 years old B&D bread machine. Motor doesn't turn. Didn't wait long enough to see if the heater is working.
Hi keneddy,
Always wait a few minutes to see if your bread machine start to mix after a few minutes. If the oven chamber is cold it will gently warm up a few minutes before it starts to knead/mix. This can sometimes take anywhere from 4-5 minutes and longer. If it doesn't start kneading after about 20 minutes then you do have a problem. Whole wheat programs often warm up before any kneading begins. All you will hear is a faint clicking noise while the heat comes on.
Feb 21, 2011 | Black & Decker B2300 Bread Machine
I put fruit in the fruit & nut dispenser & it did not come into the bread. What am I doing wrong?
Hi, sorry your dispenser appears not to be working. Unless and until you can repair it you can always add fruit and nuts the old fashioned way. Take a look at your manual and find the program you are using. Find how long the 2nd knead cycle lasts. For example lets say your 2nd knead last 20 minutes. Plan on opening the lid of your machine 10 minutes into the 2nd knead. All bread machines recommend add-ins well into the 2nd knead. Just have your ingredients premeasured on a paper plate next to the machine and fold the plate and pour them in halfway into the 2nd knead of the program you chose. At least that will help you get the bread you wanted.
Dec 30, 2010 | Breadman TR2200C Ultimate Bread Maker
Used the breadman successfully 6 days ago. today; nothing happens. Window states "knead" but nothing happens at all.
Are you making a different kind of bread than you did the first time?. If so some machine programs have a delay before they start kneading such as the whole wheat cycle. Also some machines delay the kneading process while they warm up the ingredients. If it is colder where you live now than itw was 6 days ago that could be a factor.
Oct 12, 2010 | Breadman TR845 Bread Maker
Kneading paddle having problem kneading
Sounds like you might need a new belt. If it works ok with nothing in it but wont when the dough is in there
Feb 13, 2009 | Breadman TR875 Bread Maker
Bread pan pops out during the kneading 2 cycle
Me too! I have to bend the two metal pieces on the sides out before every use - they are pretty flexible, you won't break them. Just bend out and they hold the pan in for a use or two. Not an elegant solution, I admit, but it works.
Dec 31, 2008 | Breadman TR2200C Ultimate Bread Maker
Breadman TR2200C Ultimate Bread Maker Logo
137 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
