Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
How do you remome the hall sensor from the kitchenaid pro mixer to replace with a new part
DOes anyone have a picture of the inside of the kitchen aid and the location of the hall sensor? I am a non-mechanical person who just wants to check this on my kitchen aid, but I can't find any diagrams!
Posted on Sep 27, 2012
  • 16 Answers
I used two flat head screwdrivers on both sides to push the tabs in and lift out.  But I assume you're trying to change the Hall sensor because of a problem with the speed on your mixer.  Before you take the sensor out, make sure that the sensor is snugly attached to the control board.  Also, make sure that the sensor is oriented properly.  I bought and replaced my Hall sensor, but I later realized that my original sensor worked fine.  The connection between the control board and sensor had just become loose possibly because of use and vibration.  The orientation of the sensor to the control board is critical.  Because the control board has three small prongs the sensor can attach facing up or facing down.  It definitely matters.  Before changing your sensor, I would suggest making sure the sensor is properly connected to the control board and trying your mixer again.  If that doesn't work, reconnect the sensor with the connection facing the other direction and try it again.  It took me a little trial and error before I realized which way the connection should go but it solved my problem.  Now I have an extra hall sensor.
Posted on Dec 30, 2008
Two small tabs located on each side of the sensor hold it in the motor housing. Pushing one side with a small flat screwdriver while pulling gently up on the sensor will work.
Posted on Dec 09, 2008
Mixer starts running on selected speed then speeds up & quits
I'm not sure what model of Kitchenaid you have.  I have a professional 6 Quart model, KP26M1XPT. I would recommend that you first check the Hall Effect sensor which determines the mixer’s speed.  I had this exact problem and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My mixer worked as good as new! But I was curious to know if my original sensor was actually defective, so I put it back in mixer and again made sure all of the connections were tight. Guess what? My original sensor also made my mixer work!  There was nothing wrong with the original Hall Effect sensor except the connection between the control board and sensor was not tight--unfortunately I didn't check the connection before I decided to buy the new sensor. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations.
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall Effect sensor looks like. BTW the part number is 9703312.
2.  You'll need a phillips head screwdriver to open up the mixer gear case cover.
3.  Make sure that the connection between the control board and sensor is absolutely tight and snug.  This is critical!
4.  Also, make sure that the orientation of the sensor is correct.  It's difficult to tell which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or down. After you've made the connection, run the mixer. If it still doesn't work, disconnect the sensor, reconnect it with the prongs facing the opposite direction and try it again.  I actually found the right sensor orientation through a little trial and error.  But by going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work if it were reconnected with correct orientation.
5.  This whole process probably takes less than 10-15 minutes to perform.
6.  Finally, use your common sense and make sure to unplug the mixer before checking, connecting or disconnecting anything.
Feb 08, 2009 | KitchenAid KSM50PR Professional Series...
Kitchenaid 250watt standard mixer - how to take a part ?
The speed of these mixers is controlled by a component inside of the unit known as a Hall Sensor. This part is simple to remove and install. Just contact your nearest kitchenaid parts supplier for this item. It will cost about $13.00.
Be sure to unplug your mixer before removing the cover. You will need a phillips head screwdriver. Once inside you will be able to unplug the hall sensor from the control panel and from the top of the driveshaft. good luck
Jan 16, 2009 | KitchenAid K45SS Classic Stand Mixer
Kitchen aid mixer stopped working
Nieu, I'm not sure what kind of mixer you have nor am I should what the one speed is.  In my case, I have KA 575 watt professional 6 model that would operate at only the highest speed regardless of setting. If your problem is similar to this, I would recommend that you first check the Hall Effect sensor which determines the mixer’s speed.  I bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My mixer worked as good as new! But I was curious to know if my original sensor was defective, so I put it back in mixer and again made sure all of the connections were tight. Guess what?  My original sensor also made my mixer work! There was absolutely nothing wrong with the original Hall Effect sensor except that the connection between the control board and sensor was not tight--unfortunately I didn't check the connection before I decided to buy the new sensor. My best guess is that the connection between the control board and the sensor probably loosens and comes undone over time from use and vibrations. Follow these steps:
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall Effect sensor looks like. BTW the part number is 9703312 for my model.
6.  Use your common sense and make sure to unplug the mixer before checking, connecting or disconnecting anything.
Dec 27, 2008 | KitchenAid KP26M1X Stand Mixer
Starts on high speed and quits
I would recommend that you first check the Hall effect sensor which determines the speed.  I had this exact problem and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My blender worked as good as new! But I was curious to know if my original sensor was defective so I put it back in mixer and again made sure all of the connections were tight.  Guess what?  My original sensor also made my mixer work!  There was nothing wrong with my original Hall effect sensor except the connection between the control board and sensor was not adequate--unfortunately I didn't check the connections before I decided to buy another one. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations.
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall effect sensor looks like. BTW the part number is 9703312. 2.  You'll need a phillips head screwdriver to open up the mixer. 3.  Make sure that the connection between the control board and sensor is absolutely tight and snug. 4.  Also, make sure that the orientation of the sensor connection between the control board and sensor is correct. it's hard to know which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or facing down. If, after you've made the connections, the mixer still doesn't work.  Disconnect the sensor and reconnect it with the prongs facing the opposite direction and try it.  I actually found the right orientation through trial and error.  By going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work it were reconnected with correct orientation.   5.  This whole process probably takes less than 10-15 minutes to perform.  6.  Make sure you use common sense and unplug the mixer when making connections and such.
Dec 14, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid 350 Watts KSM50PR Professional Series Stand Mixer stuck on
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall effect sensor looks like. 2.  You'll need a phillips head screwdriver to open up the mixer. 3.  Make sure that the connection between the control board and sensor is absolutely tight and snug. 4.  Also, make sure that the orientation of the sensor connection between the control board and sensor is correct. it's hard to know which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or facing down. If, after you've made the connections, the mixer still doesn't work.  Disconnect the sensor and reconnect it with the prongs facing the opposite direction and try it.  I actually found the right orientation through trial and error.  By going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work if it were reconnected with correct orientation.   5.  This whole process probably takes less than 10-15 minutes to perform.  6.  Make sure you use common sense and unplug the mixer when making connections and such.
Jul 25, 2008 | KitchenAid KSM50PR Professional Series...
Kitchenaid Professional 600 Model KP26M1XPM
I would recommend that you first check the Hall Effect sensor which determines the mixer’s speed.  I had this exact problem and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My mixer worked as good as new! But I was curious to know if my original sensor was defective, so I put it back in mixer and again made sure all of the connections were tight.  Guess what?  My original sensor also made my mixer work!  There was nothing wrong with the original Hall Effect sensor except that the connection between the control board and sensor was not snug and tight--unfortunately I didn't check the connection before I decided to buy another sensor. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations.
Jun 07, 2008 | KitchenAid KP2671 Professional 6 Series...
Kitchenaid mixer speed
I would recommend that you first check the Hall Effect sensor which determines the mixer’s speed.  I had this exact problem and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My mixer worked as good as new! But I was curious to know if my original sensor was defective, so I put it back in mixer and again made sure all of the connections were snug and tight. Guess what?  My original sensor also made my mixer work!  There was nothing wrong with the original Hall Effect sensor except that the connection between the control board and sensor was not tight--unfortunately I didn't check the connection before I decided to buy another sensor. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations. To fix your problem:
5.  This whole process probably takes about 10-15 minutes to perform.
May 06, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Mixer goes really fast then stops
First thing, check the Hall Effect Sensor (part # 9703312) to make sure that it is seated snugly AND properly!  The Hall Effect sensor measures the speed of a tiny rotating magnet and basically tells your mixer how fast it should rotate.  I was experiencing the same problem that many others have described here--my mixer would go really fast no matter what speed I put it on and it would shut off after five seconds. I came to the FixYa site and saw that one solution that seemed to work was to replace the Hall Effect sensor.  So I went to a local hardware store and purchased a new Hall Effect Sensor for about $13.  After I replaced the "defective" sensor, my mixer still did not work.  So, I started experimenting with the three prong orientation of the control board--this can make a big difference. After a little trial and error, I found the correct orientation for the sensor and my mixer worked good as new!  But I was curious to see if the improper orientation was the cause of my original "defective" sensor.  So I put the "defective" sensor back with the proper orientation and THIS ALSO FIXED MY SPEED PROBLEM! There was nothing wrong with my original Hall Effect Sensor at all--it simply was not snugly or properly seated!  I'm not sure how it happened--possibly over time the sensor prongs may have become unseated from the vibrations of running the mixer on high speeds--but my original Hall sensor was not seated properly or snugly.  So before you run out and buy a new Hall Effect sensor make sure that the original one is not only snugly seated but also properly oriented!  If I knew how to add digital pics, I would have put pictures in my comments to clearly demonstrate what I found.  Unfortunately, I am not sure how to do this.   To sum this up: 1. Download the parts information and diagrams from the Kitchenaid site and find the Hall sensor (part # 9703312).  2. Make sure that the Hall sensor is firmly attached on both ends.  The actual sensor should be located next to a tiny magnet and this end needs to be securely seated.  And the other end of the Hall effect sensor has three small prong holes which also need to be firmly and corrected seated to the control board! Bottom line, my mixer is working like new and I put the original Hall Effect sensor back in the mixer. I'm going to hold on the new one as a backup...you never know.
Dec 29, 2007 | KitchenAid KP2671 Professional 6 Series...
My Kitchenaid K5SS 300 watt standing mixer launches into the highest speed regardless of the speed selection. It functions with a sliding knob and I can barely ease it from off to stir and it goes from no...
I had a similar problem where the mixer would also go to fast speed right away. On the back at the top was a screw that was loose. After tightening this screw I had 4 speeds but no stir speed. I unscrewed that screw and a bolt fell out. This bolt went to threads on the inside of the area covered by that back plate. I put that bolt back on and tightened it and the corresponding one on the other side and wala the mixer works perfectly at all speeds. Hope it helps. Make sure mixer is unplugged before attempting anything like this (wires are exposed when the back plate is removed - some kind of flexible circuit board).
Nov 21, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer works at high speed only
You might have someone repair it for you; here is a place that charges a flat fee of $69.95 and thats including the return shipping. Check 'em out:http://www.marbeck.com/repair_mixer_kitchenaid.html The speed controller board sounds like the right direction but it hard to know if that is the issue until you install a new part. This is a known issue as far as I have heard around the internet. You might give KA a call and see if they can help; all they can say is no. I have heard they revised the part to fix the problem; my brother had a couple of boards replaced on his pro model and now it seems fine. Good luck!
Jun 22, 2007 | KitchenAid KP26M1X Stand Mixer
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
217 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
