Question about Cameras
Rechargeable batteries wont recharge
When I put the hahnel nimh 2700 AA batteries into the Hahnel power station TC compact 2 it displays a green light (which means its just trickle charging) but in my camera it says no battery power and switches off.
We had a lot of power cuts recently and I think it might have happened while I was recharging the batteries once.
Is there any way to ''reset'' the batteries so that they recharge properly again?
beergut707
  • 79 Answers
SOURCE: initial charging time
hi there
the first charge should be around 12 hours, this then teaches the battery its max load.
ignore the charger if tells you its charged after a couple of hours.
after the first charge use as normal.
hope this helps
beergut707
Posted on Oct 09, 2008
welcomejee
  • 10594 Answers
SOURCE: Camera keeps shutting off.
Please use Sony Cyber-shot batteries for DSC-H2 model camera.
Posted on Nov 18, 2008
  • 34 Answers
SOURCE: My G600 printer dock does not charge my rechargeable batteries
are you using a D26 adapater?
can you verify what type of batteries are installed in the camera?
The only battery that the dock will charge in the CX7530 camera is the
KODAK Ni-MH Rechargeable Digital Camera Battery KAA2HR
8156572
Posted on Jun 30, 2009
  • 34 Answers
SOURCE: Charge batteries while camera is docked
what is the model of your camera and what specific battery are you using( what is on the label of the battery?)
when the camera is docked on the printer, you should get a little light indicating the charging status. Once it is fully charged, all 3 green lights would come on.
But, we need to know what is the model of your camera and what type of batteries are being used in order to determine if they are compatible or not.
BillB-SA
  • 2761 Answers
SOURCE: A640 freeezes while taking pictures
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
Are the batteries fo Powershot A85 rechargeable
This camera takes ordinary AA batteries. You can use alkaline ones, which are mostly not rechargeable, or you can use a set of AA size NiMH rechargeable ones, which will last longer per charge than a set of alkalines. You will need a separate charger for the batteries, they won't charge in the camera. You can buy a charger complete with a set of batteries cheaply online or in shops. Get ones marked 2300 mAH or 2700 mAH if you can- they will last longer than ones with lower ratings.
Oct 18, 2010 | Canon PowerShot A85 Digital Camera
I have an Energizer E2 Slider battery charger, Is the green light supposed to stay on when charging. Does it shut off when charge complete.
all chargers show a light of some colour when charging , green or red , depending on make of charger , when the battery is fully charged the unit monitor this and automatically switch of to stop from over charging , a safety feature that has to built in for safety reasons ,
Jul 19, 2009 | Energizer NiMH Compact AA/AAA Battery...
WORKING INSTRUCTIONS FOR NIMH CHARGER NO LIGHTS COME ON NOT GREEN
one problem here could be the contacts btetween the batteries and the charger , had a similar problem myself and found bu using a very small , mean small too , you can slightly bend out the contacts and hopefully presto , contact has been made , lights come on and batteries are charging , make sure its not plugged into the wall when you do this , and only use very slight pressure on the contacts
Jul 04, 2009 | Energizer NiMH Compact AA/AAA Battery...
What color should LED be when charged on duracell NIMH charger
When the batteries are charged fully the light should be green.
Nov 27, 2008 | Duracell NiMH AA/AAA Battery Charger with...
S40 Battery problem
Alkaline batteries are not capable of outputting the level of power required for your camera to operate. Your daughter's camera may have lower requirements and be able to function properly using alkaline batteries. Your standard alkaline battery outputs about 700 milliamps of power when they are brand new. A rechargeable NiMH battery can range from 1200 to 2700 or even 3200 milliamps max power output depending on the quality of the battery. Most compact digital cameras that accept AA style batteries are designed for these high-output rechargeables and will not function for very long even on fresh Alkaline batteries. David Millier Advance Camera Repair
Mar 21, 2007 | Pentax Optio S50 Digital Camera
What is the difference between the available AA battery chemistries?
AA batteries are available in four basic varieties: Alkaline Nickel-Metal Hydride (NiMH) Nickel-Cadmium (NiCad) Photo Lithium (Li-FeS2) Alkaline and photo lithium are non-rechargeable, while NiMH and NiCad are rechargeable. Each has advantages and disadvantages. Non-Rechargeable vs. Rechargeable: Rechargeable batteries are desirable from an environmental standpoint because they are reusable. Self-discharge refers to the fact that batteries lose energy when unused and even when not in a camera or other device. Rechargeable batteries tend to have relatively high self-discharge rates, approximately 1-2% per day for nickel-based batteries. Non-rechargeable batteries generally have very long shelf lives and extremely slow self-discharge rates. This makes non-rechargeable batteries a better choice for infrequent usage. Non-rechargeable batteries are available fully charged in stores all over the world, which makes them a convenient choice for travelers or customers who have dead rechargeable batteries and no time to recharge. Photo Lithium Batteries (Li-FeS2) (non-rechargeable): Photo lithium batteries will yield the longest battery life of any AA battery, surpassing NiMH by 50-100% and surpassing alkaline by 100-500%, depending on the load. While they are more expensive than alkaline batteries, their additional energy capacity makes the cost the same or less per shot than alkaline batteries. Nickel-Metal Hydride Batteries (NiMH) (rechargeable): NiMH batteries are the lowest cost overall solution for users that take a lot of pictures (more than the equivalent of a roll of film per month) or use a lot of high-power features. The largest disadvantage to NiMH batteries is their fast self-discharge rate of 1-2% per day whether the batteries are in a camera or not. NOTE: NiMH batteries need to be completely charged and discharged a few times when new to achieve their full capacity. Rechargeable batteries will eventually fail. If you have been getting acceptable battery life and then see a decrease in life, either quickly or slowly over time, a worn-out battery may be the cause. Storing or charging the batteries in high temperature conditions will accelerate this potential failure. Alkaline Batteries (non-rechargeable): Although the cheapest and easiest to find, alkaline batteries yield the worst performance of all the chemistries in a digital camera. They lose capacity at high power drains and at low temperatures. Skiers and other winter outdoor enthusiasts may find them unsatisfactory. Alkaline batteries are frequently available in two types: High drain (ultra, titanium, maximum etc.) Regular The high drain versions are a premium product designed to operate better under heavy loads than the standard product. However, there is a trend of major brands to increase the performance of their standard battery to b
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Cameras Logo
50 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
