Question about Philips Televison & Video
Setting up tv sound to come thru stereo speakers
I have a philips 32 inch lcd model 32pfl7422 and would like to set sound up to come thru my stereo, i can do this thru side av when using portable dvd player i have red and white lead in stereo, yellow in side av and black and yellow cable in dvd player if i want to do this for tv where do i put yellow and black cables if this is possible kind regards
    Brigadier General:
  • 6,966 Answers
Offhand, your Philips 32PFL7422/98 do not have regular Audio Output RCA jacks (white and red), sorry. However, right before the antenna connector is an S/PDIF output connector. This should allow transfer of digital audio signals from the Philips 32PFL7422/98 to a S/PDIF capable receiver or amplifier. If you would look at the rear of your stereo and determine if it has such an input, then it would be a matter of getting the right cable/connector.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 16, 2008
How do i turn off internal speakers to hook up a sound bar?
There may be an internal speaker disable option in the initial set up routine.
Aug 13, 2014 | RCA L32HD31 32 in. LCD HDTV
Sound
Your TV has a pair of analog RCA Audio Outputs on the back of the set. They are the red and white, female, round outputs and should be labelled as Audio Out. If you have a surround receiver or stereo that accepts this type of input (most do), then you would purchase a stereo RCA audio cable that has the red and white male ends on both ends of the cable and plug them in to the appropriate stereo RCA left and right channel audio inputs on your receiver and the aforementioned outputs on your TV. The same is true if you have a pair of self-powered computer speakers (or similar). If your external speakers or audio systems don't have the RCA inputs, you may need to get an adapter to convert the RCA output to stereo mini-jack (or similar) to match the appropriate input on your external speakers. Does that make sense?
Apr 14, 2014 | Sceptre X322BV HD 32 inch Class Television...
Can't get sound thru my stereo and stereo speakers
If it is just the sound from the computer then if you have windows look for the little speaker icon in the bottom right corner of the screen, right click this, select "Sounds" then select playback (while connected to the tv) and chose the tv as the output device (set to default).
If on the other hand the issue is with the tv at all times then try going into the menu settings of the tv and looking for the various sound options. Possibly the remote control will have an audio button that scrolls through various audio options (two circles followed by roman numerals?).
Hope this is of some help.
Nov 22, 2013 | Televison & Video
Sony BRAVIA KDL-40V2500 audio not working
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
Mar 29, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I have a luxor 32" lcd tv and i cant get my surrond sound speakers to work. how do i do this?
Hi well surround sound speakers require an "Interconnection" box, that is a box with Jacks that the Red & White stereo audio plug into, on one side, and the 3 SS speakers plug into the "Other side" as it were. Usually with SS we have a Rear, Front and Sub Woofer, as this means 3 sets of speakers must mate with the 2 outputs from the TV etc. So the "Line Out" stereo output from the TV, which are usually the Red & White, is the output to the interconnection box, from there it feeds into the SS decoder, some plug directly into the decoder itself, and don't use an interconnect box, but it's all the same in the end. The stereo output is fed into the SS decoder, and then SS signal is extracted from the sign in, and routed out to the appropriate speakers.
Oct 21, 2011 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
I have a Sharp 32 inch LCD TV (LC-C3234U)that sits
Try the head phone jack there are some kool remote systems out that support the head phone output.
you can also place them anywhere in the room.
Mar 24, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Setting up receive set top box and tv for surround sound
Plug the TV to an open channel on your receiver via this output:
*Rear, 1 x Digital audio output (coaxial) ( TOSLINK )
This will look like a single RCA output plug.
Set that input channel on your receiver to some sort of virtual surround mode because it doesn't look like your HDTV has a decoder in it (meaning it will come out stereo and the receiver will have to fake it).
Turn the volume all the way down on the TV and use the receiver to control TV volume just as you do with DVDs.
*Substitute this with the digital audio output on your set top box if you are sending video only to the TV from the set top box (component, DVI or s-video connections). So video goes to the TV, audio to the receiver.
Feb 03, 2008 | Televison & Video
Magnavox mwd7006 dvd player hookup
if you are useing componet output and the pic is black and white you have them hooked up in the wrong order
The Cableguy
Oct 17, 2007 | Philips Magnavox MWD7006 DVD Player
Televison & Video Logo
150 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
