Question about Electronics - Others
Berkley Forge Sunrise Patio Heater
Saw your answer on how to keep the heater going. We are trying to help my brother keep his going. Can you explani a little more? His stays on for 20 mins, then goes out. The original owners told us that is why they gave it to us.
What did you bend? Did you move the tip of the thermocouple towards the pilot light or away from it. My husband is helping me write this. I need lots of instructions, but he is more mechanical minded.
Thank you in advance. Are you in Colorado by any chance?
Kathy Tarrant
katsamatwork@juno.com
719-271-8686
hotuna
  • 288 Answers
SOURCE: windchaser patio heater
You have to hold the button down for 30 seconds at least before turning the knob to ON. If you are doing this and it still goes out after you let up on the knob, then it needs a new flame sensor, or thermocouple. Same thing different names.
Posted on Mar 06, 2008
  • 10865 Answers
SOURCE: Propane patio heater ignition problem
I would change the thermocouple and here is why:
The thermocouple is the pilot's, well, co-pilot! It is the electronic device that senses if the pilot flame is hot enough to sustain burning the gas fuel from the burner. If the thermocouple thinks it's safe, then it keeps open the main gas valve located in the pilot assembly. If the thermocouple does not sense enough heat from the pilot flame (such as when the pilot is out), then the thermocouple shuts off the gas valve to the burners.
How the Thermocouple Works
So what is this thing and how does it work? Well the thermocouple (technically called a thermocouple junction) is a device that contains two metal wires welded at the ends and placed inside a protective metal case. The thermocouple sensor is found at the business end of the pilot flame and is designed to be placed in the hottest part of the flame. The other end is connected to the pilot valve body. As the thermocouple heats up, it produces a small amount of electricity and when it gets hot enough from the pilot, send a signal to open the gas valve by using a solenoid operated by a 24 volt transformer. The thermocouple calls the shots, and by converting heat to an electrical signal, it allows the gas valve to open or close. Once the gas valve is open, gas is then constantly supplied to the pilot and as required for the gas burners (as called for by the thermostat). If the pilot goes out, then the thermocouple gets cold and produces no electric signal to open the gas valve's solenoid and the gas valve shuts off the gas supply to the pilot and burners
Posted on May 27, 2009
protek480
  • 1723 Answers
SOURCE: WONT FIRE UP Hayward h150 Pool heater
Is the thermocouple in the pilot flame? It has to sense the flame and provide a signal to light. or, is it a flame sensor? Same thing, must be sensing the pilot flame. This is the first step for it to light...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 23, 2009
  • 236 Answers
SOURCE: need parts: pilot assembly and thermocouple
THe thermocouple either has 2 wires or a coppr tube going to the gas valve. They can be bought at a good hardware store or a plumbing supply. The length of the wires or copper tube will be the determining factor as to which one you need. As these thermocouples, when heated generate a small electric charge tha keeps the gas valve open. Should cost no more than $10-15 USD
Posted on Oct 10, 2009
  • 1214 Answers
SOURCE: Is it o k to bend the thermocouple tip. The only
Bending it will ruin it. You need to find out why the pilot flame is not as strong as it should be.
It is usually caused by bugs or spiders having gotten into the small air mix jet of the pilot assembly and died or built a web or, there is some dirt from the fuel that is partially clogging the fuel tube leading up to the pilot assembly, or plugging the orifice.
Posted on Dec 14, 2009
Testimonial: "worked perfectly"
I need the instructions on how to put my patio heater togeth
There is a specialist patio heater company that might help, they have lots of help pages, see patio heater tips, try emailing them for a manual.
Nov 22, 2011 | Stainless Garden Sun Steel Propane Patio...
I have a sterling forge propane patio heater and the burner screen is rusted out. The screen is 10 3/4 inches in diameter and I don't find any that size. Also the dome is 36" with a center hole for...
Doug - Patio heater parts are pretty universal from one manufacturer to another. Especially so, for the parts you need. AZ Patio Heaters carries a large selection of universal fit parts, as well OEM parts.
Here's a link to their website http://azpatioheaters.com/home.php?cat=2&gclid=CLOGyd-DnKgCFQl_5Qod_29hHg
Hope this helps you find what you need.
Apr 14, 2011 | Sterling Forge SFP40PT Gas Patio Heater
Hole in gas line to burner
Get a replacement paty at your full service propane dealer. He would probably appreciate your gas business as well.
May 02, 2010 | Berkeley Forge G-PH001PSS Open Flame Patio...
The pilot light will not turn off after the burner is on... I think it over heats, because it will just shut off after several minutes.... any suggestions? Thank you
The pilot light must remain on, even when the main burner is on, to keep the thermocouple hot. If the thermocouple cools off, the gas flow shuts off. It sounds like something is interrupting the gas flow. If this is an LP heater, try replacing the regulator.
Dec 11, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
Can you telll me how many BTUs is has?
There is a UL plate on the heater it should strate the BTU's on it I did find this for you Berkeley Forge G-PH001PSS Open Flame Gas Patio Heater. Patio, Alimentation: Gas, Open Flame, 12000 BTU
Oct 12, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
I have a sun rise 1001 Model SR1001 40,000 btus. On the regulator hose, where it attaches to the tank should there be an O ring on the fitting. Thanks Email eydee77@aol.com
IF THERE IS A SLOT AT THE END OF THE BRASS NIPPLE, THEN THE ANSWER IS YES.
TO GET THE RIGHT ONE GO TO A STORE WHERE THEY FILL TANKS AND SEE IF THEY HAVE ANY, OR JUST EXCHANGE THE TANK.
THANKS,
RSMITH972278
Need parts: pilot assembly and thermocouple
Oct 10, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
Need cover for heater
If you google berkeley products there is a phone # to call in Calif.
Sep 05, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
Berkeley Forge Outdoor Propane Heater Sunrise Model SR1001
I believe the company is out of business but I just got my heater fixed using a local gas service company. Took them a while to find a compatible thermocouple assembly but he found it so there is hope.
The unit works like new now except for the ignitor but not a big deal as it works fine to light the pilot with a lighter.
Jun 10, 2008 | Berkeley Forge G-PH001PSS Open Flame Patio...
Electronics - Others Logo
175 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
