Question about Lexmark X6570 InkJet Printer
Fax driver issue
Hi when i tried to fax from the printer x6570 it says fax driver missing and i need to re-install the driver. I have re-installed the driver and it still keeps going on about it. Has anyone faxed anything from this printer ?
Same problem. I was using the cjb6500en.exe file which does not contain the OCR and FAX drivers. Use the installation CD and select Custom->Update Driver and Install Optional Software to add the FAX driver.
Posted on Dec 23, 2008
SOURCE:
Have a new computer and cannot install the printer Lexmark X6570, the fax and scanner have installed but not the printer
To download and install the Lexmark X6570 printer driver, please visit the Lexmark website at http://bit.ly/hVA0vj. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
Aug 10, 2011 | Lexmark X6570 InkJet Printer
I owe a Lexmark Printer X2580 and I lost the instalation CD. I downloaded the file cjr2500EN.exe, I installed it, but when I try to send a fax I get the following message: "The fax driver is missing...
The Lexmark Fax Solutions software can be installed using the installation disc that came with your printer. Please contact Lexmark technical support for additional assistance.
Jun 18, 2011 | Lexmark X2500 All-In-One Printer
I have a lexmark x6570. I have att uverse phone/internet/tv. I have always been able to send/receive faxes. Now i can receive a fax, but cannot send one. When I do, the transmission report says...
Try dialing *82 and then the full fax # you are calling. AT&T sometimes has issues with caller ID functions, and I found that this caused me to be able to receive a fax, but not send one. Post back and advise whether this resolves your problem.
Best,
JudyP
Mar 26, 2011 | Lexmark X6570 InkJet Printer
Driver not find
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Multifunction-Printers/Drivers-Downloads/model.KX-FLB801.D#ts
you can download drivers on this page
If this helps orsolves the issue, please rate it and give a testimonial for myresponse!
Feb 25, 2011 | Panasonic KX-FLB801 All-In-One Laser...
Driver to fax is missing on Lexmark 6500 series
kindly reinstall the printer driver with printer driver cd it will automatically add fax printer.
Have a nice day and do not forget to rate please...!
Feb 12, 2010 | Lexmark X6570 InkJet Printer
Problem with fax, when fax is turned no it read scanner driver not working. can you help.whenever a fax is sent we don't come through you can hear it dialing fromthe other end that all tried to install new...
scanner drivers have not been properly installed .it requires fresh installation of software after removink previous install of software. tell me ur operating system,i will give you steps to uninstall previous software and install new software.as far as fax is concerned,first we have to install drivers,then ur fax issue will be solved
Aug 17, 2009 | Office Equipment & Supplies
Can send but not receive faxes
Is that a USB connected Lexmark unit?
Apr 24, 2017 | Lexmark X6570 InkJet Printer
Cannot Install or Uninstall printer
Hi u need not install fax software for this machine..its a standalone fax machine..the fax software provided for fax is for computer faxing..
first find which operating system u have on ur computer..if its vista..try downloading drivers and then installing
Feb 11, 2009 | Lexmark X5495 All-in-One &USB...
Lexmark 9500 fax trouble
Pls try:
  • un-install the 9500;
  • reboot your PC with the Lexmark's USB connection;
  • preferably clean your registry;
  • reboot again;
  • temporarily disable your antivirus and firewall;
  • use the CD installer that came with the Lexmark 9500 and do a clean fresh install. Do not plug in the printer/fax until instructed to do so. Pls follow on screen instructions.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 13, 2008 | Office Equipment & Supplies
Lexmark all in one series x6570
Remove your printer first and uninstall driver .Then set your ip address, dns and gateway in the computer as given by the internet service provider. And connect to the internet. Then connect your printer and install drivers. If your printer is ok then it should work
cheers
May 07, 2008 | HP 1040 Plain Paper Inkjet Fax
Lexmark X6570 InkJet Printer Logo
246 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
