Question about HP LaserJet 1020 Printer
HP Laser Jet 1020 heating up for 2 min every time I try printing
When Printing the document:
Printer starts working (rollers are turning) and it lasts about 2 minutes green light is on after it finishes warming up but nothing is printed.
When I choose to print again the machine starts warming up again for 2 min this time two lights are blinking green and orange one after another) and finally I get both lights on, which means that is a fatal error and nothing is printed.
This happens almost every time I try to print, doesn't matter whether it's microsoft office, acrobat reader etc.
Sometimes it starts printing but it stops f.ex on 3rd page and there is paper jam (document has horizontal line printed on the jammed page and orange linght is blinking)
I replaced the toner but didn't help.
Could anyone advise what to do?
Thank you
    Sergeant:
    Champion:
  • 347 Answers
Hello, first try simple solutions:
Make sure the computer is conected to the printer.
Reinstal the printer driver on the computer
Make sure there isnt a jam (liek paper) inside the printer, or a problem with the toner (**** as beign stuck or havign no ink)
Posted on Nov 16, 2008
    Scholar:
  • 181 Answers
Five things to check for this problem 1)either the printer door is not closed properly. lift the door and again close it tightly. 2)either the laser toner cartridge is not inserted properly so it is showing this error. there is a black colour plastic part in the cartridge which touches any sensor poart in the printer.by this the printer identifies that the cartridge is inserted.if the cartridge is not inserted properly the printer will not identify the cartridge and this error problem will come. 3)if the laser toner cartridge is totally empty this error comes up as there is no powder remaining in the toner and it needs replacement or the refilling of the cartridges. 4)if any piece of paper is jammed in the printer remove the laser toner cartridge by lifting the front cover and check if there is small piece of paper in it it will show this error. 5)if everything seems to be proper in your printer then its the driver software error just delete the drivers of the printer from your pc and load new drivers from the printer installation cd . your printer is absolutely perfect. just check out for this problems listed above.any 1 of the above will definately help u solve your problem,. rate the solution if it helps u. if further help require feel free for assistance. thanks.
    President:
  • 2,712 Answers
Uninstall the driver, reboot the PC and reinstall the latest version of the driver, which can be downloaded from hp.com
If that does not work, it could be an issue with the drum unit that is causing this error. You may have to replace it.
  • HP Master
  • 19,396 Answers
Try replacing the toner first.
robably the machine need a new drum.
  • Ginko
    Ginko Nov 16, 2008
    From the description it sounds like a problem with the drum, but on this printer toner and the imaging drum are packed in one unit. when you replace toner, you also replace the drum.
    If the drum/toner is OK, it can be one of the paper jam sensor (small plastic tabs) that is returning error, and getting the printer stuck.
    This would also explain why it gives paper jam that often.
    If the printer has over 1000 copies, it many also be necessary to clean the inside of the printer to remove toner dust. See: Clean your laser printer safely with these tips.
Why hp laser jet 1020 plus printing only some areas in a page
Poor copy quality can be isolated tot he following three components.
1. toner cartridge, you can quickly change the toner and find out if the printing improves.
2. Transfer roller which is located in the printer below the toner cartridge, these rarely fail so I doubt this is the issue.
3. Fusing assembly, the fusing assembly has a mylar sleeve around the heating element and over time this sleeve degrades and as a result print quality is compromised.
Hope this helped
www.aimdistribution.com
Feb 02, 2016 | HP Office Equipment & Supplies
How I can solve auto printing when I start HP laserjet 1020
how could I manage the auto printing in laser jet 1020??How could I delete the past setting printing from it's propertise??
Oct 13, 2011 | HP LaserJet 1020 Printer
My hp laser jet 1015 printer folding paper from the left corner of the page when it out form the printer
Try to check for some paper obstruction into the roller (black) and clear it. Try to clean also those roller with rubbing alcohol to remove some dirt on it and try printing again if it works.
Dec 31, 2010 | HP LaserJet 1020 Printer
I have HP Laser Jet 1020 When I print letters
Most cases on that machine it's the transfer roller that does that at 75mm, but could also be drum cartridge or fuser. Use a flashlight and inspect the fuser, shouldn't be toner or image on fuser rollers, If you unplug the machine when the print is in the middle, you can tell if it's before or after the fuser, and after the drum.
Nov 24, 2009 | HP LaserJet 1020 Printer
How i print a watermark picture in hp 1020 printer
To change the default settings for all future print jobs in Windows XP
1. In the Windows task bar, click Start, select Settings, and click Printers and Faxes.
2. Right-click the HP LaserJet 1020 printer icon.
3. Click Properties, or click Printing Preferences.
4. Change the settings, and click OK.
5. On the Effects tab, select the watermark you want to use.
NOTE Not all printer features are available from all drivers or operating systems. See the printer
properties (driver) online Help for information about availability of features for that driver.
Jun 11, 2009 | HP LaserJet 1020 Printer
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Printing Labels
Sorry loose plug. All fixed!
Jan 06, 2009 | HP LaserJet 1020 Printer
Have paper out jam
hi,
maybe your separation pad is worn out that's why it can't pick up paper which causing the paper jam...
rey
Oct 21, 2008 | HP LaserJet 1020 Printer
Hp laser jet 1020 paper jam and not printing... half paper inside of printer
REmove cartridge, and open rear door, might be all scrunched in very back fuser unit, if you can't remove it without damaging the rollers then it will need to be pulled to bits
Dec 27, 2007 | HP LaserJet 1020 Printer
HP LaserJet 1020 Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
