Question about Jl Audio E1200 Car Audio Amplifier
Will a jl amp e1200 kick a jl woofer 12w3v2 loud
I was wondering if this e1200 jl amp can kick my jl 12w3v2, to where it is loud and clear or should i use a bigger amp.
The amp isn't 1200 watts it's 200 watts on one channel if i'm not mistaken
Posted on Dec 05, 2008
    Problem Solver:
  • 16 Answers
Yes a 1200 watt amp will do the trick.. the problem would be in the box the 12w3v2 sub needs a good size box and you should have one made for your car. and yes you will get the bass you want
Posted on Nov 16, 2008
Can a Jl e1200 amp Handle a Rockford P2
Definately. Just set your amplifier so that you dont damage either. In actual fact you are more likely to damage the amp before you mess up the speaker!
May 24, 2010 | Jl Audio E1200 Car Audio Amplifier
How to wire a JL audio 12W3v2-d2 subwoofer . there are two sets of terminals how are they connected two the amp
Jan 02, 2010 | Jl Audio 12W3v2-D2 Car Subwoofer
Wire three 10" jl subs to jl e1200
what is the impedance of your woofers it will be a number with an Omega symbol. Looks like a horseshoe next to your woofer . Like this JL Audio 10W1v3 8ohm. Please, Please tell me you bought 8 ohm woofers JR?? Because if not, it ain't gunna happen.. If you did buy 8 ohm woofers than wire them in parrellel which means all the +'s together and all the -'s together giving you a final impedance of 2 ohms and your amp will think your a car audio GOD... But if not be ready to smell plastic burning where your amp used to be.... let me know i can walk you thru the wiring but let me know what you have. ok. mark
Mar 18, 2009 | Jl Audio E1200 Car Audio Amplifier
My jl e1200 is very distorted
check your groud make sure theres contact and check your rca's
Mar 15, 2009 | Jl Audio E1200 Car Audio Amplifier
My tinsel leads to one woofer keep frying
also after repairing unless it's done by a true professional normal solder will not work.. it doesn't flex as well as it does from factory, and it's very hard to extend tinsle lead length, I would suggest returning to original store for swap or return to JL for swap.. (or get new ones.... not JL :) )
Jan 26, 2009 | Jl Audio 12W3v2-D2 Car Subwoofer
Jl audio with 2 12kickers cvr
it sounds like you don't have enough power to run the amp, or else it is a built in (MOSFET) overload device inside the amp. the woofer is from your discription blown. when you choose a amp and woofer you need the woofer to be able to handle more watts (MAX) than the amp can give or you will blow every woofer you connect up. you can solve the power outage by fitting a "CAPACITOR" which stores power and provides it to the amp as and when it is needed, or you will need to install another battery for the amp alone.
Jan 15, 2009 | Jl Audio 250/1 Car Audio Amplifier
Which amp do you guys prefer will bumps better on the jl 12w3v2?
jl audio is a good name to stand by for amps kickers amps sound good at a high vol but not at a low vol
Nov 30, 2008 | Jl Audio E1200 Car Audio Amplifier
If my jl amp e1200 is on green, but no power is going to the sub
your audio wires from the head unit have been pinched or discontected or the head unit is not putting out a signal
Nov 29, 2008 | Jl Audio E1200 Car Audio Amplifier
Do you know if my woofer is blown?
well if you hear a rattle sound its probably already blown...and the amp could be drawing too much power if the radio shuts off...make sure all your wiring is correct. also if your car is off and you turn it up it will most likely shut off cause the battery cant handle it. but as for the sub i think its blown. good luck
Nov 16, 2008 | Jl Audio 12W3 Car Subwoofer
Only works for RADIO!!!
You're using the wrong control lead. There should be an amp control lead. You're using the power antenna lead.
Oct 31, 2007 | Jl Audio E1200 Car Audio Amplifier
Jl Audio E1200 Car Audio Amplifier Logo
204 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
