Question about Canon PIXMA iP3000 InkJet Photo Printer
Service error 5100 canon pixma ip1300
What should i do?
  • 412 Answers
See this --As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
Hello, my ip1300 printer is showing error. It shows service error 5100. hoe can I solve it, pls advice me.
Posted on Aug 30, 2009
  • 25 Answers
SOURCE: canon IP1300 printer is giving service error 5100
hi raheel, hope i could help you. I think you got a problem with the sensor strip inside your printer. Try to look at it maybe it got messy and the reason a printer head cannot run properly and you got that error.
I can't show you the exact image because my camera was at our store. But hope you could understand this:
  • Turn off the printer
  • Open the cover
Look at the image, you can see a "TRANSPARENT" horizontal strip object which controls the movement of the printer head slots. Try to wipe that with CLEAN tissue paper with a little amount of water.
Here's another one. Try to follow this instruction.
1. Remove the plug of the printer
2. Press and Hold the Power button(don't release).
3. Plug the Printer
4. Release the power button
5. Switch on printer.
Hope this help you. : )
Posted on Dec 27, 2009
SOURCE: Service error 5100 on my canon Pixma mp110
Had the same problem, i just replaced the black ink cartridge which was finishing at that time and resetted the counters. No problems after that. Not sure whether this will help though.
Posted on Aug 31, 2008
SOURCE: service error 5100
may be the driver are not installed correctly ... just try reinstalling the drivers ... and make a check that you have inserted the ink cartilage or not ...
if not insert it and then give try ... it may work ..
if problem persists then call the service rep ...
Posted on Feb 07, 2008
SOURCE: canon pixma ip1300 initialisation problem
service error 5100 on canon pixma ip1300
Posted on Sep 01, 2008
I have a canon ip 1300 produces an error(both LED's are alternately blinking one blink for the green led and 5 blink from the orange led) then it will produce an error 5600.
Posted on Feb 24, 2009
Canon ip1300 service error 5100 solution
you have to clean the printer's cartrige head and connector. If the same problem occer, please change your cartrige.
Thank you.
Jun 29, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
SERVICE ERROR 5100
for error 5100 usually i turn off my printer, then disconnect the usb cable then connect again to computer
then i turn on my printer again
try it
i hope this helpful
thank you for using fixya
Feb 19, 2011 | Canon PIXMA iP1300 Printer
Canon ip 1300service rror 5100 -
Canon is a greedy company. It may be selling cheap printers, but the company is so obsessed is exploiting the consumers by selling its ink cartridges that is unusually high. Please boycott Canon printers and let this greedy Japanese company fall into pieces.
Jun 02, 2010 | Canon PIXMA iP1300 Printer
It shows service error 5100 & doesn;t print
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 20, 2009 | Canon PIXMA iP1300 Printer
Error message 5100 is displayed
Two questions.
Are you reporting the correct printer model? I cannot find the iP1300 on the Canon website.
Are you reporting the correct Error No? I cannot find an Error No 5100 on the Canon web site.
Don
Nov 18, 2009 | Canon PIXMA iP1300 Printer
CANON IP 1300 SERVICE ERROR 5100
ERROR 5100 means that there is some foreign object blocking your ink cartridge carriage that disables it from moving. It may be a piece of paper or a scotch tape or a staple wire. You may try cleaning also the encoder strip with a moist tissue paper. Furthermore, you may also try cleaning CAREFULLY the contact points of the cartridge holder and the cartridge itself (those shiny bronze pins) with a moist lint-free cloth.
Jul 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
PIXMA iP1300 printer is showing an error 5100
nope try this --
Dec 28, 2008 | Canon PIXMA iP1300 Printer
Canon pixma ip1300 initialisation problem
Dec 03, 2008 | Office Equipment & Supplies
Service error 5100
Feb 07, 2008 | Office Equipment & Supplies
Canon PIXMA iP3000 InkJet Photo Printer Logo
1,858 people viewed this question
old marine
old marine
