Question about Dell OptiPlex GX260 PC Desktop
Flashing green light
I bought my Dell Optiplex Gx260 last year second hand. About six months of owning it the green light next to the power button flashes. It goes from steady flashing to barely flashing to not even flashing. I used to get the battery voltage too low screen for some reason I stopped getting that screen. I also keep getting a messsage saying my virtual memory is too low. Can anyone help me?
  • lataurac Nov 21, 2008
    My hard drive access light goes from steady flashing to barely flashing to not even flashing. Is my computer crashing or is the hard drive damaged? When I first got the computer it was solid green. It started flashing after I started getting a string of viruses. What's going on!
I loose vga video controller
Posted on Nov 20, 2008
My brother owns a Dell Desktop computer and suddenly it stopped working. - The Power button light is flashing continuously. - The green light on the motherboard is perfectly on. - The port light where...
Do the fans run? If not the power supply is most likely bad. Hopefully it didn't trash the motherboard, memory and any installed cards. If you can't hear the hard drives spinning up, then it has to be the power supply
Aug 12, 2016 | Dell OptiPlex GX280 PC Desktop
My dell gx260 ligth come green if i turn it on but for a few mins time it turn orange why
Do you mean the monitor's power light starts green and then turns orange when you turn it on? Most monitors will go to a power saving mode when they do not get a signal from the computer.
The Dell GX260 has a green power light when on. When the computer is off, the light is off. If it is green and blinking, then the computer is in a power saving mode.
Diagnosis: start with the obvious: is the monitor cable plugged into both the computer and the monitor (if not permanently connected to the monitor)? Are you connected to the active port? (You can add a video graphics card in most desktops. The motherboard video port usually needs to be disabled to use the card ports. If you plug in the monitor cable to the disabled port, it won't work.) Is the monitor set to the correct input? (This applies if the monitor has several ports. In that case, there will be a Source or Input button on the monitor.) Is the computer on? The GX260 has the power button on the front. (Other computers have the power button on the top.) There is also the power supply switch on the back which needs to be on.
Next try a different data cable between the monitor and the computer (if you can). Try a different monitor. If a second monitor works, than the monitor has a damaged main board. If the second monitor doesn't work, then the video graphics adapter has probably failed. Replace the add-on card, if in use, then boot in the safe mode to remove the old graphics driver. Then install the correct driver for the graphics adapter.
Note: the computer and the monitor should both be off when you connect the cables. Then turn on the monitor first and set it to the correct source before turning on the computer.)
I hope this helps.
Aug 21, 2011 | Dell OptiPlex GX260 PC Desktop
Start button flashing
It depends on the color, if it's green or amber. This may indicate the computer is in sleep mode. Press the power button to see if you can turn on the pc. If it doesn't press and hold power button for five seconds. You may give more details. I hope this helps
Mar 10, 2011 | Dell OptiPlex GX260 PC Desktop
My dell optiplex GX 260 suddenly restarted on its own a few times then it does not start anymore. The power indicator on motherboard doesnot light up. Power box burnt?
Possibly, there was a serious problems with capactiors that affected all major manufacturers a fre years back whereby the caps didnt last more than 2 to 3 years. SOme lasted longer before blowing. Dell could help you establish if yours was affected. It does sound like the power supply, see if the fan is spinning on it. If not they are easy to replace and can be purchased on ebay. Mail me if you need the part number and ill see if i can help you. m.g.woodruff@googlemail.com
Aug 17, 2009 | Dell OptiPlex GX260 PC Desktop
TRY TO BOOT DELL OPTIPLEX 260 BUT NOTHING HAPPENS, JUST GET A FLASHING CURSOR IN TOP LEFT HAND CORNER OF SCREEN. DIAGNOSTIC LIGHTS ARE A,B,C GREEN AND D AMBER
The light code doesn't really help us much with this one. Its basically and 'other' for the light codes. Are you able to get into the BIOS? If so look to see if the hard drive shows up. If it does, there could be a software issue with the OS installation. If you can't get to the BIOS then you could try resetting the BIOS, or replacing the CMOS battery.
Jul 16, 2009 | Dell OptiPlex GX260 PC Desktop
Dell PC Desktop Optiplex GX260 Doesn't boot
Open up the case and remove any add in cards and memory modules. Try to start up by adding these back one at a time until the unit stops booting normally. The light combination is not one recognised in the user manual so I am guessing you have a non-descript fault with one of your components. Be careful when you open the case as to not disturb the ribbon to the motherboard which controls the power, I have had a very long experience trying to get one of these reconnected!
Dec 15, 2008 | Dell OptiPlex GX260 PC Desktop
Dell motherboard does not come at all
If the power doesn't come on at all, or the system powers up but never starts up, it almost certainly means the system board is board is bad. I have fixed 3 Gateways and 2 Dells in that last six months that required board replacement. A good place to try for boards is www.blueraven.com.
Nov 21, 2008 | Dell OptiPlex GX260 PC Desktop
Dell Optiplex GX260 Tower flashing yellow power button
Hi
Power up the Optiplex GX260 and check the QUAD Pack Diagnostics LEDs (located at the back). Compare the LED pattern to http://support.dell.com/support/edocs/systems/opgx260/en/ug/solvprob.htm#1167139 for more info.
Ideally, to troubleshoot and resolve the issues, try removing all PCI devices, disconnect all external devices/peripherals including keyboard and mouse. You may leave the Monitor connected. Power up the PC and check for successful Power On Self Test (POST). If POST completes (generally fails on "Keyboard not present"), shutdown, connect keyboard and try POST again.
If all goes well, install PCI devices one at a time and test successful POST. This will help identity a failing device.
If issue persists, after removing all devices, remove the CMOS battery for about 90 seconds and try POST again. If same, remove all DIMMs (Memory) and check for beep codes. Compare beep pattern to http://support.dell.com/support/edocs/systems/opgx260/en/ug/solvprob.htm#1176760.
NB: Ensure to remove power lead and press power button briefly to use up flea power before working in the system.
If the system beeps, it suggests that the CPU and systemboard are "likely" fine. Install one DIMM at a time and test successful POST. If there no beeps then the systemboard and/or CU is/are at fault.
Regards
Mike
Mar 27, 2008 | Dell OptiPlex GX260 PC Desktop
DELL GX260 bootup problem
To start with I would run FDSIK from a DOS boot disk and delete the partitions on the hard drive. Then reload the operating system. There is no telling what has been loaded on the system. After the reload the DELL should boot normally.
BPCS
Nov 15, 2007 | Dell OptiPlex GX260 PC Desktop
Optiplex GX260 won't boot
I had the same issue and accidentally discovered a temporary solution. Unplug the power from the back of the machine, open the case and unplug the ATX power connection from the motherboard. With the ATX cable unplugged, plug the power cord back in. When you try to turn the computer back on the power light should turn orange and fans should be spinning, with it powered on plug the ATX connector back in. That should turn the computer off. Turn it back on and it should boot fine. You can even shutdown and restart, but when the power is unplugged you will have to go thru the same process to get it back up. This sounds crazy but it worked on mine. Good Luck!
Nov 01, 2007 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex GX260 PC Desktop Logo
288 people viewed this question
Alun Cox
