Question about HP Officejet 5610 All-In-One InkJet Printer
Paper jam???????? ok this peice of **** is 9 mo old never used at all because of ghost paper jam. when you turn it on it goes through its little deal and the ink cartridges goes to the left then they jump up and down and popping then the message paper jam ole hot damn this is my jam
  • 1 more comment
  • kboggs Nov 16, 2008
    ok this peice of **** is 9 mo old never used at all because of ghost paper jam. when you turn it on it goes through its little deal and the ink cartridges goes to the left then they jump up and down and popping then the message paper jam ole hot damn this is my jam.to the right
  • Anonymous Dec 07, 2008
    That happens to me as well. I had a recent paper jam, and before the jam it would only move to the left and right and then stop. Now it makes weird clunking noises.
  • Anonymous Jan 28, 2009
    My printer does the same dang thing... its really annoying actually
  • 30 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
753
Posted on Feb 27, 2009
    Scholar:
  • 97 Answers
Please follow the follwoing steps,
1) unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to
printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and
then release both buttons, this should resolve the issue.
Regards,  raj_p5983
Posted on Jan 29, 2009
When doing two sided printing I always get a paper jam indication when none exists. Single sided is OK.
Likely a small peice of paper stuck in the rollers on the paper flipping side, or a bad sensor.
Dec 29, 2014 | Epson Artisan 837 All-in-one Wifi Inkjet...
Error paper jam
It is possible that there is a little peice of paper that has ripped off of the sheet that was jammed. Was the sheet whole when you removed it? If not, check the location where the paper was jammed for bits of the last sheet of paper.
Sep 17, 2013 | HiTi P510L Photo Printer
Paper jam won't go away and its no paper in the machine
was there a paper jam in the first place where you had to pull the paper out?if so try and get in there and check if there is a little peice left as i believe these have little sensors that are affected very easily by the tinyest of paper. good luck!
Feb 07, 2012 | Sharp UX 355L Plain Paper Thermal transfer...
Printer screen showing paper jam. There is no paper jam.
Hi, this is a well worn path.
I know its a bore, but follow this, with your CSI Torch open up the rear access covers and look in carefully look. Satisfied replace cover, lift scanner lid, again using your CSI Torch check out the print area for a little peice of offending paper, if needs be try moving the rollers but gentle.
If no, left side hidden away, gentle move the print head carrige to the left there is every possibilty you will find a sodden inkedpeice causing the problem.
If still no paper, then as a lasrt resort reinstall the printer prog, it could be corrupt.
Did you have a paper jam that cased the original error message, if so then the odds are there is a little peice causing the problem. Good Luck.
Peter.
Feb 10, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I am receiving a message, "paper jam", yet there is none. At the same time, It goes to sleep. How do I get it to awaken? Any assistance is appreciated.
LOL, I know it isn't funny but it sounded funny. There is probably a small particle of paper stuck inside it, and that little peice of paper is telling the machine to sleep until the paper is removed. Try spraying some keyboard cleaner where the paper goes in and where the paper goes out.
Aug 06, 2010 | Brother IntelliFax-2820 Laser Fax
My 2600n laser printer had a paper jam in the outbox bin. I took the stuck paper out and had a look inside. I see no other paper jam but the printer keeps telling me I have a paper jam in the outbox. ...
There is a sensor flag (little black peice) that hangs down in the paper path as the paper exits. The flag tells the printer if the paper has made it out or not. That sounds like your problem. Just in case it is something else, her's a copy of the complete service manual for your printer. Start on page 90 (pdf page 113) and it goes thru the jam areas.
http://www.feedroller.com/Store/Service%20Manual/HP%20Color%20LaserJet%202600N%20(Q6455A)%20Parts,%20Service%20Manual.pdf
Nov 16, 2009 | HP Office Equipment & Supplies
Printer says there is a paper jam but there isn't
: Clear the jam from paper tray 1
  1. Remove all paper from the output tray.
  2. Turn off the product.
  3. Unplug the power cord from the back of the product.
  4. Lift the output tray and then check for jammed paper in input tray 1. Use these steps to remove any jammed paper.
    1. Raise the output tray. Figure 3: Raise the output tray c01321359.gif
    2. Grasp the jammed paper and pull it out of the product, toward you.
    3. Lower the output tray.
  5. Plug the power cord back into the product.
  6. Try printing a document.
    4. Lift the product off tray 2.
    5. Remove the jammed paper from the bottom of the product or from tray 2.
    6. Reposition the product on top of tray 2.
    7. Plug the power cord back into the product.
    8. Try printing a document.
    • If the issue is resolved, do not continue troubleshooting.
    • If the issue continues, proceed to the next step.
If you would prefer to view a video with audio instructions, click here (in English).
  1. Turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the ADF input tray and open the ADF cover. Figure 4: Open the ADF cover c01285903.jpg
  4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside. Figure 5: Remove the jam cleanout part c01285904.jpg
  5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open. Figure 6: Lift the green lever c01285905.jpg
  6. Check the ADF paper path for jammed paper. Figure 7: Paper jammed in ADF paper path c01461018.gif
  7. Check for jammed paper where paper enters the ADF paper cleanout. Figure 8: Paper jammed as it enters the ADF paper cleanout c01461019.gif
  8. Gently remove the paper without tearing it. Figure 9: Remove the jammed paper
    • If the paper does not come out with gentle pulling, follow these instructions.
      1. Open the ADF, and then use both hands to gently loosen the paper.
      2. When the paper is free, gently pull it out.
      3. Close the ADF.
  9. Lower the green lever.
  10. Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
  11. Replace the ADF input tray.
    • Figure 11: Follow the correct method to attach the ADF frame c01461020.gifc01461021.gif
    • Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
Jun 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
Toshiba estudio 200 keeps having false paper jams where are paper sensors located?
its not the paper sensors you need to get to its the feed rollers,which will be above the paper tray near either the left or right side of machine. clean those with glass cleaner. if they appear smooth in any way they should be replaced, keep old ones to compare. what you are referring to as false jams we in the copier world call the "ghost jams"
May 08, 2009 | Toshiba Estudio 200L Copier
Hi, I'm Ron a Disabled Frustated Senior Citizen. I have or the AX is going to get it. HP Photosmart 8050. 1, ONE Peice of paper Jamed. Now the RED Light is Blinking? No Idea. Also it says Print Cartridge...
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck..
Dec 30, 2008 | Office Equipment & Supplies
I have a HP OFficjet 7210 All-in-one that keeps jamming.
Clean the pickup rollers and ensure that there isn't a small peice of paper lodged between them. I use a product called "rubber renew", it removes the dust, dirt, etc. and eats away someof the rubber to make it rough again.
Nov 18, 2008 | HP Officejet 7210 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
59 people viewed this question
Seeker5211
Seeker5211
