Question about Toshiba 50H82 50" Rear Projection Television
Convergence for toshiba 50h82
Just replaced the stk ic's in a toshiba 50h82 and it looks great again, just had to do some minor adjustments in the convergence menu. Was wondering do I need to do that for all of the inputs I use or doing it once will be sufficiant ,also which is better to do the convergence in the regular menu or go into service mode to do it, or is there a difference in the two, as far as adjustments.
  • Anonymous Mar 20, 2009
    what are stk ic's and where do i get them?
  • Toshiba Master
  • 3,459 Answers
Either mode is fine...just save your session when done!
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
convergence for toshiba 50h82 - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Jun 06, 2010
My Toshiba 50H72 HDTV has shadows like watching a 3D movie without the glasses. I only have the cablel remote and trying to adjust the convergence through the front of the tv did nothing. I also have...
The tv hyber board also known as the tv convergence board it is dead.Yes,if u have all the tools and also can do ICS chips soldering works?Yes,Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a whole complete convergence kit belong to ur tv make and model replaces those 2 STK conconvergence ICS and some or all of it resistors too by ur self.Or the shops will cost u like $300-350 for parts and labors.
Jun 17, 2011 | Toshiba 50H82 50" Rear Projection...
Blurry picture and purple and green color on top and bottom screen, cable channel indicatoe showing doubled
Tv have a problems known as a convergence problems,it dead.The tv convergence board,require 2 STK convergence ICS and some or all it resistors to be replaced to solved the convergence problems.The shop will,cost u $300-350 for parts and labors.
Aug 08, 2010 | Toshiba 50H82 50" Rear Projection...
Why is my toshiba tv showing double
The tv have a problems known as a Convergence problems,it dead.The tv convergence board require it 2 STK convergence ICS and some or all it resistors to be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Aug 03, 2010 | Toshiba 50H82 50" Rear Projection...
Tried to auto adjust the guns, will not come within range
Hi Tod,
If colors do not align correctly, most likely you have a convergence failure. This requires replacement of the 2 STK ICs and possibly some low ohm resistors.
Some Toshiba have a Horizontal oscillator/Drive IC failure that results in a small or shrunk picture (2-3" border on all sides). The 3 colors do not align properly because of the reduced Hor drive signal. The convergence adjust controls will work but not allow good adjustment. Convergence is ok, Hor Drive signal is incorrect.
Many do-it-yourselfers mistake the Hor Drive problem in Toshiba RPTV with convergence failure. Too much adjustment of the convergence controls may cause the saved data to be really messed up and require more difficult alignment in the service mode.
If minor or simple adjustments in the customer convergence adjust menu do not fix your problem, there is a fault. Stop adjusting until fault is repaired
Convergence failure can be accurately identified with the Convergence Gallery on our website. Service in Toronto, Ottawa, Calgary, Edmonton and other Canada cities.
easyab
Apr 21, 2010 | Toshiba 42H81 42" Rear Projection...
Will a REBUILT PTS PART number pd0637 toshiba hyper, number on part MVPU14 2L20DD work as a hyperboard in a 2002 50h82
Most of these hyperboard are inter changeable.But must Check the 2 STK convergence ICS munbers on the ICS parts have the same printed #---?
Apr 01, 2010 | Toshiba 50H82 50" Rear Projection...
RED HORIZONTAL CONVERGENCE OUT.INSTALLED NEW STK 392 110.SAME PROBLEM
Please check does STK IC getting +22 and -22 volts supply to work properly, check pico fuses that might blew off / open, replace it and check.
Thanks.
Oct 29, 2009 | Toshiba 50H82 50" Rear Projection...
50H82 red wavy convergence (stks didn't fix)
If the tin can module you are referring to is the hyper module, it is common to replace all 11 caps because the factory caps ****. Check for bridged solder connections at STK's search the forum at electromaniacs for 50h81 :)
Sep 15, 2009 | Toshiba 57H82 57" Rear Projection...
Color test bars not in alignment
STKs convergence ICs they are big black ICs will have STK on them if 110s use 180s Replace Both ICs Call MATS 1-800-628-1118.Example STK392-110 ect.....
Aug 07, 2009 | Toshiba 50H82 50" Rear Projection...
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
50h82 red convergence ic replacement
Q783 is a 2SJ512 (FET) with part number 23205037. These are not the easiest to test. If you suspect that it is bad, just replace it. It costs $2.48. I only have a listing for one convergence IC (STK-392-110), but if there are 2, replace the one labeled RVBVGV or just swap the two to see if the convergence shifts from vertical to horizontal.
Keep us posted.
Dan
Apr 17, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 50" Rear Projection Television Logo
199 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
