Question about AT&T 8925 Tilt Smartphone
HI, my AT&T tilt screen has gone blank.
On the lower middle, i can see blue lines. top half is white and border in between is black leaf like. i can't read anything on the screen. plz help me with that
thanks
raj
  • 2 more comments
  • rajbir4 Nov 16, 2008
    thanks
  • Anonymous Nov 18, 2008
    First, make sure that the 'glass' has no micro-crack in it. If it is intact, you may have a poor connection on the ribbon cable. You would have to partly disassemble the unit to seat the connection again. Last resort, replace the screen completely. Available on the web for $44.oo or $47.00. There is a Manual in PDF that can be downloaded to show you how to do all this yourself.
    ALSO:
    http://www.youtube.com/watch?v=zsljpn74S...
  • Anonymous Mar 12, 2009
    Help!!!... I have a similar problem.
    My Att tilt went crazy and kind off freeze out. I Try to reset it butit didn't work. Now the phone has 3 lines on the screen(red green andan blue) and is chowing like some codes and the serial number.
    Don't know what to do.. Help!
  • k_oss Mar 14, 2009
    my tilt just froze,touchscreen dont work,it wont come on..i did a soft reset an it still dont work.i did a hard reset an lost everything i had on it an now it wont work at all..cant call out ,no incoming calls will come in..nothing works...grrrrrrr piece of junk if ya ask me..they realy rip us off..almost $400 for it not to work..come on now..whats next.i'm so mad an **** about this phone..anyone think of buying one,dont they are junk..an cost to much for the problems it has...urs truely....k_oss
  • 66 Answers
Www.fixphonenow.com can repair lcd, cost is $125.
Posted on Nov 16, 2008
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Lines at top of screen, about 4"
Hi:
This is due to vertical deflecton problem, there is some capacitors that has gone bad and need replacing. It might just be one cap rated at 100uf 35 volts. This is called vertical foldover eventually the top will fold over or you will get a 4" black border on the top of the scrn.
Aug 23, 2010 | Toshiba 27A33 27" TV
I have green and blue arched lines across my screen. how do i fix this
This is one of a group of sets that had bad picture tubes. A lot of them were replaced out of hand when the sets were new--I did dozens of them.
The tubes are no longer available from Sony and only available on a rebuild basis--remove the bad one and send it out for rebuild at about 300 per tube.
THERE IS AN ALTERNATIVE:
HERE IS WHAT I suggest:
With the set at first unplugged you need to remove the entire plastic grill under the front screen. It is secured in one of two ways: either 4 or more screws on the back on either side; it pulls out from the bottom and has tabs that are tucked into slots just under the screen.
The front controls/keyboard are mounted into it so if you get it free you tilt the front grill on its left side to the left; there are wire ties you can release to get more room.
The other way some versions use is there are two hidden screws at the bottom front covered with caps--remove them and lift from bottom and tilt to the left.
The idea here is to try to turn the screen controls for the green and blue (in your case) down.
With the grill out of the way you will find an inspection plate behind it dead center---remove that.
BEHIND THE INSPECTION PLATE LOCATE THE SQUARE BLACK PLASTIC BLOCK WITH SIX BLACK SHAFTS THAT ARE ADJUSTABLE.
ONE row is marked Focus (Do not touch those) You have to look closely as the controls are black and hard to read--left to right green will be in the middle and red or blue on either side of it.
With the set now turned on go to a unused video input: Locate the blue screen control( tiny letters will be b,g, red with green in the middle---turn the blue down slowly (usually to the left) until any blue lines and or blue background vanish---in your case then repeat with the green SCREEN control until any green curved lines or back ground are gone.
The idea is to lower each screen control until they just vanish--when properly done on the blank input you should only see the "VIDEO 1" ETC in green, with no other color in the background. Do it slowly and it should take less than 1/4 of a turn for this.
If it works you should now have a good black and white picture.
Since these sets have a history of this kind of problem you may only be buying some time---I have done it on dozens of sets and many last more than a year or more without repeat of the problem.
This gives you more life from the set and time to save up to replace it.
Let me know before you attempt this if you have any questions.
If this information told you something you did not know, rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 13, 2010 | Sony KP-57WS520 57" Rear Projection...
I have a 5 yr old Samsung HP-R5012 Plasma Display Television. A display model. Last night, horizontal lines appeared, then, the top half of the screen went black, with color pink and blue surrounding the...
All plasma an lcd TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Aug 11, 2010 | Samsung HP-R4262 42 in. Plasma Television
Black screen ecept for thin white line around all four side. Channel buton changes colors in various section of screen. On/ off button does not work
I found the solution on mine. To restate, I just saw a thin white border around a black screen. Pressing the channel up or down buttons changed the screen, in some kind of test mode to shades of gray, and red, green, and blue. I started finding a solution when I noticed when on one of the color screens, that the volume up or down buttons brought up a new menu for color intensity. Finally, I got back to the thin white border screen and pressed the arrow keys in the top half of the remote. Finally a TV screen and I pressed the enter key! Voila!
Mar 14, 2010 | Sylvania LC320SLX 32 in. LCD TV
My laptop, an Acer Aspire 5715z, has a big ol' white patch on it with a smaller one at the top of the white one. It covers about half of the screen, and it has blue around the start of the white line.
Oh okay. Your screen is physically cracked. Its broken, its going to need to be replaced. Thats why a part of the screen is coming and then you see splotches on the screen. Looks like somebody hit directly with something or stepped on it. If you turn the laptop off and shine a light on it, you might be able to see where the crack originated.
In the meantime until you get another lcd screen, you can hook up an external monitor to the laptop and use it like that for now.
May 23, 2009 | Acer Aspire 3610 Notebook
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Only half the screen is being projected?
i am having the same issue............any solutions??
Mar 31, 2008 | Toshiba 50H72 50" Rear Projection...
Open Questions:
AT&T 8925 Tilt Smartphone Logo
459 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
