Question about Hotpoint RB526 Electric Kitchen Range
MY OVEN IS BAKING AT A LOWER TEMPERATURE
MY RANGE SEEMS TO BE BAKING AT 275 WHEN IT IS ON 350. F2 CAME UP ON THE PANEL. IT DID THIS THE LAST TIME WHEN THE TIME CHANGED. I FORGOT HOW TO RESET THE TEMPERATURE.
  • 370 Answers
Check to make sure the broil element works. If so then change your oven sensor.
Posted on Nov 18, 2008
Why is my oven burning baked goods on the outside but still raw on the inside, when baking at the correct temperature setting?
Sounds like you need to set your thermostat as its not reading properly. Ours has a little screw on the side of the thermostat and I use an oven thermometer to make sure the heat is right. Ours was twenty five degrees out.
Dec 16, 2014 | GE Profile Spectra JBP95 Electric Kitchen...
F2 &F3 error codes, oven keeps beeping, I already tried turning off circuit breaker did not solve problem
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board).
2. Press CANCEL. If error code
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven,
if double oven) Replace Oven temperature
sensor (RTD)
Note: Applies to all F3-E...
codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
oven, if double oven) F3 - E2 Oven temperature is too high (Cook
mode) F3 - E3 Oven temperature is too high (Clean
mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven,
if double oven) F3 - E5 Oven temperature sensor (RTD) shorted (lower
oven, if double oven) F3 - E6 Warming drawer sensor open F3 - E7 Warming drawer sensor
shorted
Dec 20, 2010 | Whirlpool Accubake RF362LXTT Electric...
While baking in my Hotpoint electric stove I pressed the oven light button to check on the biscuits and a code of F2 came up. What doe this mean?
this code usually means that the oven temperature is too high.
Is the oven working ok? Does the temperature seem to be correct? Did the code go away? If not,you can try shutting the breaker off to the range for a while and see if it resets. if not make sure that your oven is not getting too hot.
you could have a bad temperature sensor or possibly a bad control panel.
Jun 03, 2010 | Hotpoint RB787 Electric Kitchen Range
When baking bread in my Kenmore electric range (9435) the loaves on the bottom rack burn on the bottom and the ones on the higher rack take almost 2X as long to cook
In an electric range, the ideal place for baking is the middle shelf. there are temperature differences within the oven cavity. On the bottom shelf the heating elements actually "broil" the bottom of the pan. In the upper part of the oven, the temperature is lower, being blocked by the lower pans. A convection style oven is more ideal for bread baking.
Aug 23, 2009 | Kitchen Ranges
F-2 code
HI. this code can come up for two different reasons. it could during a bake session or a cleaning situation as well. I will list the details below.
During Baking(((f2)))
During a baking session, if the control senses an active oven temp above 615f-630f, this code will appear.
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
During Cleaning(((f2)))
During a cleaning session, if the control senses an active oven temp above 915f-930f, this code will appear.
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Aug 02, 2009 | GE Ovens
Baking cake and F2 signal
F-2 on your range indicates a bad temperature sensor. Please replace your temperature sensor in the oven.
Jul 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool Electric Oven RBS305 overheats while baking, locks door
The technical manual for your range doesn't show an error code of E2 F2 but all of the F2 codes pertain to the touchpad of the range.
Can you clear the E2 F3 by pressing the cancel button? If not, shut off the power to the range for a few minutes and see if the error code goes away. If the error code remains You should unplug the range from the wall and remove the back panel for the control area. Disconnect the ribbon between the touchpad and the electronic control, clean the end of it and reconnect it.
If this doesn't repair the problem you will need to replace the touchpad on the range. The parts diagram lists two touchpads, they are part numbers 8273575- bisque, and 8272702- white.
Good luck
Dec 18, 2008 | Kitchen Ranges
F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Nov 06, 2007 | Tappan TGF363 Gas Kitchen Range
GE OVEN DOES NOT WORK PROPERLY JBP69SGH2SS
I am not an expert, but this has happened to me. Examine your circuit breaker and see that it provides the amps that your oven requires. If it just barely provides it, then it could be that your circuit breaker is tripping if you have anything else on that line and it is being used. Especially hair dryers. If your circuit breaker is not tripping, you should contact GE or repair service because you may have a "power module" problem. Good luck.
Nov 30, 2006 | GE JBP69 Electric Kitchen Range
Hotpoint RB526 Electric Kitchen Range Logo
123 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
