Question about Kenmore 67082 Electric Dryer
Makes squeaking noise after running for about 10 minutes
The dryer starts out running fine then about 10 minutes into the cycle it makes an annoying squeaking noise. Can anyone tell what might be wrong. I have a Kenmore 70 series dryer. While the drum is turning for a couple of min there is a loud squeal, then the drum stopped turning. The belt does not seem to slip on the drum, when I manually turn the fan at the lower left behind the dryer I can hear the squeak (back panel & air vent removed). I'm thinking it is the pulley or wheel that the belt is connected to? If this is the case, how do I get access to it or replace it. Model # is 66702692 Kenmore Series 70.
Thanks for all your help
    Sniper:
  • 50 Answers
There are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Posted on Jan 30, 2009
At the start of the drying cycle the dryer would squeak for a few minutes as it heated up the squeaking would stop ;now the dryer will not turn on, only hums whn the start button is pushed..HELP!!
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 30, 2011 | Dryers
My Maytag Neptune dryer, works fine until the last 5 to 10 minutes and then starts to make a loud skreeching noise. Suggestions??
heatman101
Jul 18, 2011 | Maytag Neptune MDG9700A Gas Dryer
I have a gas dryer Maytag Dependable Care Model 6 cycle about 11 yrs old...Has a steady squeak as it runs , seems to be getting louder . Everything on the dryer seems to work fine other than this...
heatman101
Jul 14, 2011 | Dryers
The dryer will make a loud scretching noise like metal rubbing on metal and then after about 10 minutes the dryer will shut off and when you try to restart pushing the timer/start button, it just make a...
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 31, 2011 | Dryers
Dryer makes squeeking sound when running
you need to replace the rollers an idler an belt,,,this will stop your noises...call if need help...
May 10, 2010 | Dryers
Squeak
check what is called an idler or tension pully. lubricating these can somestimes help but only a temporary fix. actualy its not a fix. only makes it quiet. replace them or call service these parts are easily accessable
Apr 25, 2009 | Maytag Neptune MDE4000 Electric Dryer
Replace the dryer drive belt and the dryer tub rollers.
Mar 01, 2017 | Kenmore Dryers
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
you can check a lot of things. the motor itself, the rollers on the back, and the main bearing at the center of the drum. you can apply any lubricants to all of those rolling parts.
Feb 12, 2008 | Kenmore 84152 Electric Dryer
Kenmore 67082 Electric Dryer Logo
479 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
