Question about Maytag MSD2756G Side by Side Refrigerator
Ice maker I have a Maytag MSD2756G, about 5 years old. Problem is the icemaker is working fine but won't let the ice come out the little door. It's not jammed or nothing. Ice comes down fine, the little door just won't open for the glass to retrieve the ice. Sure could use some expertice on the subject. Thank you.
  • Julie Scheuneman Nov 27, 2006
    Hi Tom, I can open the door, no problem there. It just won't open for the ice to come out. The grandson was getting some water in his water bottle and then switched to the crushed ice button and he said he was going back and forth with this. And now the door just won't open for the ice to come out. Everthing else is working fine. We can open it(the little flap) from the outside of the door and when we open the freezer we can open it from inside the freezer part of the frig. This has my husband baffled. He's just been opening the freezer to get the ice when he want's a glass of ice water, etc. I'm always the one that want's things fixed. Thank's for your help.
  • Anonymous Mar 18, 2014
    Ice machine intermittently quits working. I open the door take out ice tray, mess with it a little put it back in, it will start working for a while. Anywhere I can get a service manual for this?
  • 237 Answers
Can you open the door by hand or is it stuck shut? Check this site for a diagram of the area to help you see inside the door mechanism. http://www.partselect.com/MultiModels.aspx?ModelNum=MSD2756G&searchTerm=img_A58-10&RefineSearch=0&imgMfg=Maytag&Page=2
Posted on Nov 27, 2006
  • Marc Wilson
    Marc Wilson Dec 04, 2006
    Ouch, a "poor" rating when I only was trying to get more info to help?
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Trying to remove icemaker. One screw found & removed. cannot get icemaker out. seems to be another screw holding it in, but I cannot see what it is
Here are 3 diagrams of the ice maker. The first one is the ice maker assembly, and the second is the ice bin assembly, and the third is the outer fountain assembly.
Diagram 1
Diagram 2
Diagram 3
Feb 16, 2011 | Maytag MSD2756G Side by Side Refrigerator
Have a Maytag side by side with ice maker...it quit making ice within 3 months of installation. Had one repair man look at it...said that it was a common problem w/ Maytag...hit ice maker with his fist a...
Assuming it's not still under warranty, I would probably replace the icemaker components inside the freezer.
The repairman's "fix" indicates that there is some kind of problem with the "brains" of the icemaker. It would probably not be cost effective to try to diagnose and fix the problem.
Oct 12, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag fridge no water to icemaker any suggestions
Pour about 2/3 cup of water into ice maker . If it freezes and dumps , replace the water valve . If it does not dump , replace the icemaker . Also make sure the coils are clean beneath refrig , and the clear fill tube , which fills the icemaker , is clear of ice (not frozen up ).
Sep 12, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice-maker problem
if the water runs constantly when you turn the water on its your valve but if it does it periodacally it probably your icemaker
Apr 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker isn't getting water. Water works on door, and line from ice maker has water in it, just not all the way to the ice maker
Icemaker is probably bad. If ice is in mold it is bad. If not, pour some water in it and see if it drops cubes after a few hours. If it does then fill spout to i/m must be frozen up- thaw it out. Common for i/m to go bad. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Maytag MSD2756G Side by Side Refrigerator
Maytag ice maker
ok first the dispencer doesnt affect ice production in any way onle diapencing so for get it the most common promblems will be the filter or the water valves on the back of the unit water and ice are on two different valves so because one works dont mean the other does also check the icemaker fill tube to see if its frozen a leaking icemaker water valve will cause it to freeze im also going to send you the procedure for checking the icemakermoudle its self do this after checking everything else remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Jul 22, 2008 | Maytag MSD2756G Side by Side Refrigerator
Maytag side by side MSD2735GR
well sometimes it clogs up , when i open the frig door sometimes the ice falls out since the actual cup in inside of frig is full of the crushed ice.
Sep 11, 2007 | Maytag MSD2756G Side by Side Refrigerator
Ice maker not making ice
Same thing happened to me. I unplugged the refrigerator, plugged it back in and it worked. I guess the computer system reset itself. Easy fix.
May 13, 2007 | Maytag MSD2756G Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
358 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
