Question about Continental Manufacturing Company Value Line 1RE-SS-HD Stainless Steel Commercial Refrigerator
Rust on the door edge of my SS maytag Ice2O refrigerator?
HI, It appears that there is rust or something forming on the inside edge of both of my French Doors on my Maytag Ice2O refrigerator. The spots appear as "dashes" from the top of the door's inside edge to the bottom. Kind of strange.... I can scratch some of it off with my fingernail...
Any ideas on what could cause this? We've only had the refrigerator for 1 1/2 years....
Sue Allison
  • bigsky1978 Nov 16, 2008
    Thanks for your help! I wonder if this is covered on a warranty....
  • bigsky1978 Nov 17, 2008
    Thank you so very much! I will give the Maytag people a call. P.S. Aren't they the ones where the repair guys sit around with nothing to do because their appliances are so dependable????? Hmmmmm.....
  • 108 Answers
Your problem is no doubt a bad door gasket which is not sealing. Water vapor from room air is seeping through and condensing on the door edges. A new gasket should be available from your local refigeration supplier, but they are very difficult to replace. Read all instructions carefully before starting, and store your perishables.
Ray
Posted on Nov 16, 2008
  • Ray Nov 16, 2008
    Dear Sue... If the warranty is still in effect you should check with Maytag. Door gaskets normally last many years so if yours is leaking after 1 1/2 years, it may have been incorrectly installed.
    Ray
Painting the outer edges of the interior of a refrigerator..where the door seals meet the interior
Most likely not rust. You would see rust stains. IF you do repaint it, make sure that it is clean and dry. Oil or contaminates can cause the problem that you are describing.
Feb 15, 2015 | Refrigerators
Rust appearing on 10 month old refridgerator doors
How can I put this nicely.
TAKE IT BACK!!!!!! First moisture is forming where it shouldn't, air leak/door gasket not sealing, and second stainless doesn't rust. If rust is forming than it's of poor quality. More iron in it than steel. Isn't there atleast a one year warranty? Don't wait! Till it's too late. Complain NOW!!!
Oct 30, 2012 | KitchenAid Refrigerators
Zanussi SS fridge freezer not yet 2 years old, first freezer door started to rust on lower front edges and slightly on front panel - replaced no problem by local shop. That door is now rusting in same...
NO fun... Looks like you will need a new door again soon ~ no matter what.
I would buy a new door, BUT BEFORE installation... I would apply many coats of a decent clear lacquer paint first... apply on all of the bottom of the door and cover at least 10 inches up.
Also coat the bottom and inside of the door at least 6" up... the door sides too...
Be sure to allow each layer to dry thoroughly.
Use a 1" blue masking tape to keep your paint line straight and true. Lay the door down flat and face-up to do your work...
This measure should add years of service to your door... At the first sign of any rust ~ you know what to do.
As for Zanussi, I doubt if you could muster enough owners to pursue any legal actions... sorry.
Anthony
Dec 02, 2017 | Zanussi ZX99 / 5 Bottom Freezer...
My 2006 F-150 FX4 Crew Cab has rust forming on bottom of 2nd doors both sides. Will Fords EXP plan cover this issue.
Hello, The rust needs to be through and through and they will cover it. So if the rust is only on the inside you can ask but it is up to the Dealer to decide. If the rust is on the inside and starting to appear on the outside, it is a through and through condition.
We have a Lincoln which rusted on the trunklid and drivers' door bottom. The Dealer replaced the door and trunklid and painted about 80% of the car including surface (one-sided) rust on the rocker panels. Everything blended in and the car was almost 7 years old. All Warranty coverage.
Apr 22, 2011 | 2006 Ford F-150
Model 680 ss dripping on the leading edge behind
model 680 and up. the warer valve is located in the upper part of the unit. follow the water. is very posible the water is coming from the top of the unit. TIP. remove the upper grill. and a white cover. behin the white cover is the water valve.
Mar 27, 2010 | Sub-Zero 680 / F
Rust on exterior below dispenser
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish will remove the rust and pacify the surface. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Aug 14, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
Programming hv board
I have the same Maytage MFI2568AEB on the inside top left of the refrigerator the code is 0302, i still cannot enter the code, showing PEO OOO.
Jan 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Surface rust on GE Profile Stainless Steel Refrigerator
We use DeBruce Polish on all of our stainless steel IT IS THE BEST and it is ECO_FRIENDLY! Ceramic cook tops-kitchens in all our properties, DeBruce Polish does the job, never anything else just do the touch ups-seriously just the spot!!!
Better than Bug Be Gone on our windshields we travel with it-use on polished marble, granite also. We find DeBruce Polish at debrucepolish.com
Nov 22, 2008 | KitchenAid Superba Architect KSCS25INSS...
Rust on Jenn Air Refrigerator Door at Water Dispenser
You may end up respraying the door, but here goes.-
First mechanically remove as much of the rust as you can with an old screwdriver or similar scraper. Then use coarse emery cloth - 80 -120 grit untill all you're left with is shiny metal with rust pits.
You may need to go out further than you think - about 1" all round.
Then use a paint- on de-rusting fluid from vehicle products supplier. When all rust is black or dissapeared, use a zinc primer on all the bare metal. (this will stop it reacuring)
Then either spray the area with an "appliance white" aerosol or squirt it into the cap, and use a paintbrush.
If you are spraying it, open all house windows and doors, cut a mask from newspaper- then tape it to the fridge. Use blankets , plastic dustsheet or old sheets to protect things, and spray it from 12" in several very light coats.
When done, "polish" with T cut - which should remove the rust stain too.
Seal the area of the original leak with a white or clear silicone - and sort the original leak out.
If you polish the plastic with a silicone spray, water will tend to stay put rather than seep.
Jun 11, 2008 | Jenn-Air JCD2389G Side by Side...
Rust spots appearing on front of doors of kitchen (indoor) Kenmore refrigerator.
its what we in the business call "refrigerator cancer" they are rusting form the inside out. there is not repairing them and not worth the cost of replacing, you can take them off and spray them you might get a little time outta them. reason it happens is the insulation used years ago was fiberglass and would trap moisture between door and liner, eventually rusting through.. new refrigs are insulated with blown in poly-styrene. they don't hold moisture.
Mar 11, 2008 | Kenmore 94499 Refrigerator
Continental Manufacturing Company Value Line 1RE-SS-HD Stainless Steel Commercial Refrigerator Logo
278 people viewed this question
Top Continental Refrigerators Experts
John Tripp
John Tripp
Tom Chichester
Are you a Continental Refrigerator Expert? Answer questions, earn points and help others
