Question about Acer AL1715 17" LCD Monitor
Speakers not working
How do you get the speakers to work? In the menu there is no "on" switch.
  • 472 Answers
You will need to connect an audio cable from your computers sound card to the audio input under the monitor.(near where the video and power leads plug in)
You will need a standard 3.5mm to 3.5mm stereo lead for this.
Hope that helps =)
Posted on Apr 11, 2008
Surround sound speakers does not work
Hi Anneri,
Have you gone into the sound menu and switched on the surround speakers? If yes, have the speakers checked. If the speakers are good too, your tv needs to be checked.
Jun 01, 2015 | Televison & Video
I have a sony bravia KDL-32L4000 LCD TV and the sound has gone
For anything you plug in or just certain things? Before the sound stopped, did you change the sound output to something different? Do you have external speakers plugged in?
If the built-in speakers on the tv are not working, plug the television into a set of external speakers, select the output in the menu accordingly and test them. If they work, might be the speakers are blown or the menu configuration is wrong.
Always check the simplest things first, then work your way up to the harder/more expensive issues.
Rule out speakers, speaker board, connectors, external speakers, components attached to television, etc.
Mar 07, 2013 | Televison & Video
No sound on my technika 42" 3dtv
If the headphone jack socket works the audio output for the set is good, I suspect a dvd etc will also work if connected to the rear input audio and video jacks.
This does not leave too much, headphone jack dirty or defective, speakers for whatever reason are switched to off in the main menu.
the sound for the headphone socket if it is built into the set is the same audio going to the speakers.
Dec 05, 2012 | Televison & Video
There is no sound coming out of my jvc k series tv. it worked like 10 minutes ago. what went wrong?
Look in audio menu or setup menu to make sure the speakers did not get switched off----check set or a box if used for same or volume turned all the way down---speakers being switched off is the most common cause or the audio circuit has failed.
Apr 15, 2012 | JVC AV-A21M3U 21" TV
No sound at all ,good picture ,mute is not on
If using a box make sure sound not turned down on it.
In Set menu make sure speakers are switched ON.
Look for a slide switch on rear of set for Internal/external speakers. It may also be in set's menu as an option.
If ear put right to speaker"s do you hear anything?
still not working likely an audio output circuit problem.
Mar 28, 2012 | Televison & Video
Left speakers are not working on my onkyo tx-ds575
Check the units internal "menu" settings for speakers and audio. beyond that, there would be an internal problem and neded service. Hope this helps
Jul 05, 2009 | Onkyo TX-DS575 Receiver
No Sound
try switching the prologic mode on in the audio setup menu also switch front spks to small in the speaker setup
Apr 11, 2009 | Audio Players & Recorders
Speakers are not working
some flat screen tvfs in the menu have a selection to turn on or off the tv speakers, my Sony has it in the sound menu it say speaker selection, and the options are TV or Outside Speakers, check for this if they have been fine right along
Mar 20, 2009 | Televison & Video
No sound
Sometims the speakers are switchable in the menu, make sure you have them switched on
Feb 26, 2009 | JVC AV-27530 27" TV
Speakers
Tvs are wired differently these days. Your old Zenith for example probably had a selector switch that allowed you to change from internal or external speakers, bandpassing the audio from the internal amplifier to the audio out connectors. Your Sharp on the other hand may be controlled by customer menu to perform the same function as the external switch. Go into the menu and sub-menu of the audio and see if it gives you any choices for selecting internal or external speakers... If it doesn't it probably will not bandpass the already amplified signal, which means if you want to listen to your Tv on those external speakers you'll first have to pass the audio sample through an amplifier.
Hope this helps.
Bill
Nov 14, 2007 | Sharp 25N-M100 25" TV
Acer AL1715 17" LCD Monitor Logo
166 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
