4 years ago i used the Panasonic DVD-r to burn a DVD project and it worked. but now the dvd is not working. I'm getting a message error on disc
    Problem Solver:
  • 7 Answers
This is a common problem with optical media. It is because of the dyes used for recordable media begin to decay depending on the conditions they are kept in, and the quality of the dyes used.
unfortunately if the discs dyes start to lose their reflectivity, drives have a harder time reading the data off. you may want to try putting the disc in a different dvd player, or a pc-dvdrom reader, some drives are more sensitive than others when dealing with damaged discs, or those with a surface with low reflectivity.
Posted on Nov 16, 2008
I get an error message to use a blank or erasable DVD
I would try simply copying one of the already completed discs using a stable and well known burning program like Nero. Programs like Pinnacle can be very temperamental when exporting their projects to disc.
Jul 19, 2010 | Gear Head 8XDVDEXT DVD External Slim...
Panasonic DMR E20 Produces a line of distortion along the bottom
Sounds like you see head switching from the tape. Most TV are over scanned enough to hide it.
Aug 30, 2009 | Panasonic DMR-E20 DVD Recorder
Can not read disc
I mainly use my DVR to record TV shows on DVD-RAM discs (Panasonic brand or Maxell). I've had no problems with the DVD-RAM discs. However, today when I put a DVD-R disc in the recorder, I got an "Incompatible Disc" error message. I tried a second disc from the same set, and got the same message. I tried out some of the DVD-Rs that I recorded last year and I could read them. Tried a DVD-RAM. That was OK. So, I tried another DVD-R disc. That one is OK. I don't know if the problem is that these DVD-Rs are getting a little old (2 years??) or if the recorder is developing its own problems reading discs.
Dec 03, 2008 | Panasonic Diga DMR-EH75V DVD...
Problem with HD writer 2.0E
The reason for this error is that there is a conflict between HD Writer and other software on your computer. I was trying to find a solution for weeks before Panasonic advised me to remove other DVD burning software on my computer. I therefore removed Pinnacle and DVD decrypter (which I believe was causing the problem), reinstalled HD Writer and then everything worked fine. Note however that the DVD-RW discs I had tried to use before were corrupted and couldn't be reformatted and therefore once you have removed the other software and reinstalled HD Writer, start again with new DVD-RW discs. Good Luck.
Jul 23, 2008 | Panasonic HDC-SX5 DVD Camcorder
"No Disc" error message
remove the cover of the unit and try to clean the lens with a soft clean dry cotton swab or if you have a compress air cleaner, just blow it. most of the time cleaning can solved this kind of problem. good luck!
Feb 21, 2008 | Panasonic DVD-S29 DVD Player
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
DVD+R will not play
2 Things 1 You need to Finalize the disc to play of a DVD player check that out with your DVD burn program. 2 Check the DVD players capability with certain discs, not all payers will run 'burned disks' sometimes even the brand of disk matters or whether it is + or- type There are may variables with the DVD firmware. Finalize first the the first step.
Jul 31, 2007 | Emerson EWD7004 DVD Player
DVD Player will not play 20th Century FOX disks
The Panasonic is not "region restricted". This is a security safeguard by studios to keep people from region 1 from using region 3 content. Some material is released in other countries first and later in others. This keeps other regions from using the content from other parts of the world before it is relaesed by the studio there. Your Zenith is not a region free player and the Panasonic is. There is sometimes hacks on Videohelp.com for DVD players to be set to "region free" but not all DVD players are built with it. SONY is another non-hackable DVD player.
Jun 09, 2007 | Zenith DVB412 DVD Player
My RCA 8310 DVD+R/+RW -VCR Combo will not format and record on a +R disc
I purchased this RCA 8310 about 2 years ago. I have recoreded hundreds of dvd's. If I try to use anything but a Imation brand DVD+R, 8+ speed, I get the same error. It will not work with a 16+ dvd.
May 23, 2007 | RCA DRC8300N (DRC8300NWITHREBATE) Burner
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
