Question about Sanyo DP42746 42 in. Plasma Television
Finding AV channel to connect DVD to TV
Lost manual to 42" plasma Sanyo TV.
Trying to connect to a Panasonic DVD player, can't figure out how to access the AV channel on the TV to 'see' the DVD player to do set up.
    Problem Solver:
  • 10 Answers
First check if you are plugged in the right place,(you're tv as 2 a/v inputs).then you should be able to acces a/v by the menu button on you're remote,or even on the t.v. itself.well good luck then buddy,hope this helps.. btw,are you plugged in a/v (yellow,white,red) style,s-video(1cable)style,componentstyle(green,blue,red).check that out man!
Posted on Nov 16, 2008
Finding the AV Channel on a TV
There may not be one on your TV. If your TV has audio and video input jacks then keep changing channels going from high channels to lower ones. When you get to Channel 2 then the next one down should be AV. If your TV doesn't have the A/V input jacks, then you'll need a modulator. This will take the audio and video outputs of the DVD player and put them on TV channel 3 or 4 and insert it into the antenna connection of the tv.
Jan 23, 2014 | Televison & Video
Dvd hookup
It sounds that you are connected the TV with DVD player Via AV cable. In this case, no RF channels won't go. You have to select its AV option. Check it. Refer the user manual for TV.
Aug 12, 2013 | RCA F19251GY 19" TV
What is Monitor Out on 42'' Hitachi plasma TV (42HDT50)
Monitor Out connects audio and video signals to an external monitor with corresponding inputs as noted in the document.
Mar 07, 2017 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
Cant get my tv to display my dvd player.when i hook the jacks to tv it doesnt work,the jacks are red,white and yellow
look at the point where you are trying to put the plugs into the tv are you matching colours if so are you sure its an input .?? ..... the easiest way is to use the inputs at the front of the tv(if it has one) and change it through your AV channels (hopefully you knew to chage to av?
Dec 15, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
No video but audio is fine on Sanyo 42" DP42746 TV
If you unplugged the Ysus board, then you need to replace the Ysus board, or both sustain boards. This is the part: The part is often available on Ebay, or from manufacturer. Look also at Vance baldwin or Partstore. To do a good job the Sustain boards should be tested by a tech , following service manual. It is almost for sure sustain board by the way.
Oct 12, 2009 | Sanyo DP42746 42 in. Plasma Television
We have a panasonic 42 inch plasma, less than 3 weeks old. When connected to our play station or dvd player, there is a white line at the top left of screen, only half way accross then stops. Tried...
Try changing the video output mode of the playstation and dvd player from CVBS (often called composite or video) to RGB. this should sort the problem.
Oct 06, 2009 | Panasonic Televison & Video
DVD player now showing in black and white
Make sure your av channel is av2 and not av2s as this will give b/w playback
Sep 13, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
I am trying to record on my sanyo dvw6000 and all i am getting is snow
"snow" shows that the channel you are recording isn't tuned in, or the av socket is in correct on the tv. Use AV-2 on the tv as this sends a signal out.
May 29, 2009 | Sanyo DVW-6000 DVD Player/VCR
Akira TV Problem
Now you will have to carry set to shop there is alot to reprogram in set in order to get it to re down load infromation.
Dec 03, 2008 | Akira SV-4201 42 in. Plasma Television
No video
try checking what your dvd is set on ie rgb pal or nstc, then check in your tv manual what inputs it accepts
Mar 25, 2008 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Sanyo DP42746 42 in. Plasma Television Logo
195 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
