FixYa.com
Tags:
Panasonic PT-43LC14 43 in. Rear Projection HDTV Television
PT-43LC14 No Picture, chirping sound when turned on
posted by TinaM on Dec 11, 2006
I have a almost brand new (maybe 50 hours) PT-43LC14 Panasonic HDTV. Problem is When I turn power on with remote light flashes green, then starts a chirping noise every 30 seconds or so. No picture, no sound. It worked fine the last time we used it and then a friend watched it and now it won't come on. Any help would be greatly appreciated before I call someone out.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Dec 12, 2006
FixYa! (100)
Leadtech
Rank:Guru Guru
Rating: 88%, 343 votes
Begfore calling a servicer, pull the bulb out and check if it is broken. The chirping you hear could be the ballast trying to fire the lamp. If it is blown, make sure you clean the vent filters when replacing it.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Dec 11, 2006
FixYa! (100)
techman
Rank:Guru Guru
Rating: 87%, 6564 votes
Most of the time, when there is a chirping comming from a TV set, there is a short somewhere inside the TV set. That chirping noise is the TV's power supply starting up and shutting down because of a heavy load on the power supply. These sets have no user replaceable parts inside them, so play it safe, and call out a pro to assist you in this repair. good Luck
PS Please do not forget to rate this thread.
Can you Help with these Projection Televisions problems?
Panasonic PT-43LC14 43 in. Rear Projection...
rear projection samsng sp42w4hl
i have got the tv working and... Answer This...
PT-43LC14 43 in.... Problem
My Lamp blew out. I replaced... Answer This...
Panasonic TC SD Card reader...
I create aslide show of... Answer This...
No picture no sound
No audio and no visual. Only a... Answer This...
Panasonic tv cord shortage
My panasonic pt-XXXX... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
