Question about DISH Network 301 DTV Receiver
Want to use my old dish set top as dtv tuner
I have old set top boxes that were for dish. i want to use them as dtv tuners for local channels only. without sat subscription it wont let me tune local dtv channels from the seperate antenna in.
    Problem Solver:
  • 17 Answers
The antenna ports on these receivers are only analog pass thru's they will not convert to digital.
Posted on Nov 17, 2008
Trying to hook up a digital antenna but no channels coming in
You need to get a connection from a local cable or wireless service with a set top box to be connected to the input. Please check with your local operator and see if the set top box is needed for the digital feed.
Otherwise you might need a dish with the LNB to be used to the TV. Digital tuner means that the tuner is working to scan and memorising the full band width of the channels with digital processing and thus faster and crisp.
Check the details of the TV from a forum:
http://reviews.cnet.com/direct-view-tvs-crt/philips-32pt9100d-32-crt/1707-6481_7-31473699.html
Oct 22, 2011 | Philips 32PT9100D 32" TV
Tv tuner will ot detect digital signal in windows media center, vista
All US TV signals are now digital, but most TV tuners are like our old TVs - analog. Are you sure your tuner is a DTV tuner? If not, you will need to replace it or get a DTV converter. A DTV converter will not let your computer pick the channel and time though.
But one footnote. Broadcast digital TV is often not the same a cable digital TV. If you get a cable digital signal it is encrypted to the actual serial number of the receiving box. No broadcast DTV converter can do this. This is how the cable company now controls the number of receivers and one has to pay for EVERY set.
Apr 23, 2010 | Sony VGC-LT16E VAIO 22" All-in-One Desktop...
I don't know how a program it, since you change digital.
So far as I know the HLN series does not have an ATSC tuner, thus no over the air (OTA) reception. You can probably still get a $40 coupon for an OTA ATSC to NTSC converter. Note that will NOT get you high definition (HD). With Dish you can get HD receivers that do get OTA ATSC both HD and SD. With Direct, no OTA AFAIK. With cable you would need a QAM tuner, not in your TV AFAIK to get clear channels as required for locals. Otherwise cable needs a Set Top Box for digital and scrambled channels although the standard definition (SD) non-scrambled channels work with your NTSC tuner. Too bad there seem to be no ATSC to 5-cable RCA or HDMI HD converters except Dish. -Ken
Aug 10, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Do I have digital tuner?
No, this set does not have a digital tuner. The TV must be an HDTV in order to have a digital tuner built in.
Dec 31, 2008 | Sylvania 6720FDF
Programming a ATSC DTV tuner on a RCA Universal Remote
Try a code for a "satellite receiver" of the same manufacturer of your DTV tuner. I've heard of a cross-remote complaint with the DirectTV box and the DTVPal box. Note, your DTV tuner may say RCA, but it could be manufactured by a common DTV tuner maker. The system looks very close to a Zinwell. Don't have an RCA model to try the codes out, though.
Dec 27, 2008 | Televison & Video
I need to know if the rca 27f500tdv needs a dtv box for signals
If your set is less than two years old .. you will have a digital tuner and will not need a converter.Only older sets with analog tuners will require a converter box.
Dec 05, 2008 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Oct 17, 2008 | Emerson EWV603 VHS VCR
Digital tuner
I believe it does have a tuner
Sep 27, 2017 | Hitachi 50UX52B/53K 50" Rear Projection...
Unable to detect some local DTV channels
chec kthe settings
they might be at fault
Sep 06, 2008 | Computers & Internet
Tv Tuners
Hey jp62388,
According to information provided by the manufacturer, this model TV should have a built-in NTSC/ATSC and QAM tuner. These should allow you to receive locally broadcast digital TV signals without the use of a set-top box or digital converter box.
If you're concerned about your TV's specifications, the most important thing you'll need to look for is a built-in or integrated ATSC tuner. NTSC is the old analog standard that is to be phased out in early 2009, while ATSC is the new digital standard that is to be used within the United States and Canada as NTSC’s replacement.
Should you have any other questions or concerns, I'd strongly suggest checking out the FAQ section of the federal government’s official DTV transition website:
http://www.dtv.gov/index.html
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 03, 2008 | Televison & Video
DISH Network 301 DTV Receiver Logo
250 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
